Earlier this summer, I started the process up upgrading my 36" 16ga shear for a 52" 16ga on. The 36" Pexto sold a while back, but it took a while before I found a 52" one in a price range I wanted to pay. It has the front/rear arms/supports and backstop, but I will likely remove all of them and put them in storage for now.
It was in New Lenox, and there happened to be a guy selling a black notchie clip and taillights about 25 miles away, so it became a multi-part trip.
This will allow me to replace the last panel remaining with the yellow stripe. Only took 13 years...
Went ahead and removed the hood, lights, and front facia for better access to the various projects for the front end.
One of those projects is to clean up the power distribution at the battery. With it under the front headlight that area is getting busy with the following items having battery conenctions (Starter, Haltech Rebel LS, 5 channel Amp, Radiator Fan. These will allow me to limit the wires under the healight and shorten many of the cable runs. I also plan to install two jump lugs in a more accessable location.
I am sure you mentioned it before at some point, but did you notice a difference with the drilled holes in the headlight area?
Back on page 19 is when I did that mod. At that time the headlight covers were popping up around 80 mph and the hidden vent took that to about 90 mph. Helped some. When I put the stock air dam back on there, that raised the limit some more to around 115 mph. Eventually I added the hood vent and enlarged it some in the last year so they stay closed at 135 mph. I have broken two drivers side heatlight cover brackets in the last 2 yeas. Once I was running 80 down a 2 lane and a semi was coming the other direction at 55+. The other one popped up aroung 125 mph during a tuning run.
Eventually, I will add a front splitter, but that will make it challenging getting into and out of my driveway.
Slowly making progress due to other commitments and the cold...
I am always looking for ways to improve my fabrication processes.
The thin wall alumimum tubes are hard to bend smooth. The lock bolt on the bender either dents or just slides on the bender. So the first process change was to use a shaft collar to hold the end of the tube.
Here is what you get with just the proper die and the shaft collar - kink city:
The next change was then to find and source a 36" long spring that can go inside the tube to support it during the bend. It takes some twisting of the spring to reduce its OD to feed it in, and even more effort to remove at the end.
Here is the new coolant crossover with much better bend quality:
Also welded up the charge pipe and added the blow-off valve.
Got the coolant crossover tube painted black, the cradle drilled/tapped for the clamp to support it, and the hose cut for the driver side. Just need to finish a few other things before I seal up the heat shrink clamps.
The hot side of the charge pipe has also been texturized. Again, just need to finish up some other things and I will heat shrink the connectors.
Also added some insulating material to the A2W intercooler. One layer on the Air side, 2 layers on the water side, then texturized it as well.
Remade the front transmission mount so I have it in AutoCAD and to make it lighter (3 oz). The original mounts were made before I got the CNC plasma, and didn't bother remaking them at the time.
I think I will go ahead and rework the rear transmission mount as well as the intermediate shaft. The intermediate shaft has about 12" of 1/2" wall steel tube inside it, so that might shed 4-5 lbs.
I am trying to get all the parts reworked than need powedercoating, so I only setup the sand blaster cabinet and power coat area 1 time.
[This message has been edited by fieroguru (edited 02-15-2026).]
What are you doing with the old mounts? Are they for sale? Asking for a friend.....
I am going to hold onto it for a while. It really doesn't help anyone w/o the tubular cradle.
Originally posted by dskebo:
to bend them pipes I pack them with sand and cap the ends it makes perfect bends.
I have done that in the past too, but for this application I would have to weld caps on the aluminum tube. The spring was $23 + shipping and the bends were quick to make after that.
I have been slacking on updates... but slowly making progess.
The frozen boost A2W intercooler type 26 has been istalled:
Installed a 15 row heat exchanger on the fuel return line. Temps in the fuel tank were reaching 140+ degrees due to the large fuel pump and return fuel system upgrade. At some point I might switch to returnless and PWM, but for now this was a pretty simple fix that will help lower fuel temps.
Added a couple of battery terminals in a more accessable location with the battery under the the passenger headlight.
Removed the heater core return line that dumped into the passenger coolant tube and reconnected the heater core return to the passenger coolant tube up front. I already have a 3/8" restrictor on the hot supply to the heater core (reducing its flow) and the car is never driven in temps below 50 degrees, so I don't need much heating capacity, but didn't want to just eliminate it entirely.
Upgraded from a 3-core champion to a 4 core radiator. Had to further mod the upperr and lower brackets and isolators for it to fit, but it does. The end caps go from 2-1/2" to 2-7/8, and the depth of the core goes from 2" to 2-3/8".
Almost done with the installation of the front mount frozen boost type 101 heat exchanger: Here is one of the earlier test fits:
Up to about 90 miles since I got it back together and just doing some shakedown runs
The car needs to go on a diet as it tips the scales at 2980 lbs (1320/1660 44%/56% F/R split) w/o me. My goal is to have it weight just shy of 2899 lbs.
The car has the LS4/F40, twin disk clutch, Turbo with A2W intercooler and heat exchanger, 3 mufflers, helmholz tube, 4 core radiator, 17/18 wheels, 13" brakes, sound deadening on the floors, side/door panels, and roof, 5 channel amp, 8" sub and dual 6-1/2" speakers in the doors, power window, power locks, cruise and A/C. So it has everything to make excessive power, while keeping the car a very nice daily driver.
I really love "feeling" the music in this car!
Also need to swap out the notchback panel to get rid of the last of the yellow stripe (it used to go from bumper to bumper).
Damn! What's your guess on 1/4 mile time? This thing is turning into a Fiero beast
Planning to run the 1/4 mile a on the HRPT in a couple of weeks. I have also picked up a Dragy Pro so I can monitor progress w/o the 2 hr drive each way to the nearest 1/4 mile drag strip.
I will likely keep bumping the boost until it does 135 mph in the quarter as that is 7200 rpm in 3rd and plenty fast.
Mac valve for the boost controller failed, so I am running just on the wastegate spring currently. 14 psi, 14 degrees of timing, 93 octane, and the car weighs 3200 lbs with me in it. Here is a datalog (100 rows of data/sec) from a 3rd gear pull. 80-120 mph in 3.88 seconds. After the 2-3 shift it took about 1.6 seconds to get to 14 psi and follows the timing changes. I probably need to lower the timing in the lower boost/rpm range to help the turbo spool faster.
As I prepare for more WOT runs and tuning I made a couple of brackets that will aid in those efforts. The one on the left is a bracket to mount the Dragy Pro accelerometer. I wanted it somewhere out of the way, so it could just live in the car w/o drawing a lot of attention.
Here it is installed on the shifter console:
The larger bracket, is a cell phone mount bracket on the center console. The bracket does't use any screws, but is clamped in place by the console pressing it in the groove of the carpet and front/rear supports.
I have a gopro mount in my back window near that spot, it makes for cool footage. congrats on surviving powertour!
------------------ "I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Took the car on another 500 mile work trip to WI last week and the best tank of gas was 26.7 mph. Only issue was it started setting a no-home error. It would sync and home for the first start of the day, but as it warmed up, it would set the error. Did some some logging the crankshaft and cam sensors and found that the cam sensor signal was falling out as it warmed up.
24X crankshaft position with 1X camshaft postion sensor - everything working and full sync:
24X crankshaft position with no camshaft postion signal and half sync.
With the half sync, the ecm reverts to batch fire and waste spark which runs fine, but negates the benefits of timing injectors (below 2500 rpm) to start spraying fuel only once the exhaust valve is closed. This is one of the keys to good fuel economy with a performance camshaft.
Changed the camshaft position sensor and it was back running error free, so I decided find an answer to something someone asked. I had posted the 80-120 mph time, and the questions was what it could do from 60-130mph. 6.94 seconds. This log went right up to the 7500 rpm limiter and 140 mph... Still more in it, but I need to fix the boost control mac valve before so boost comes on faster than just with the wastegate spring.
I have said it many times before.... but this car is AWESOME!
After I had my fun and saw the delayed boost response, that motivated me to finally replace the mac valve for the boost controller. Took about 1.5 hours because it is over the passenger intermediate shaft and I had to remove the wastegate muffler to access it. Here is a reminder of where it is mounted:
Now that the Turbo LS4/F40 Fiero will go 140 mph in 3rd gear at 7500 rpm, I need some gauges that will work for these elevated limits. Working on a solution for that!
