I found took the 3d file of the win stands and modified it. Shrunk it down about 18 mm, and printed new stands with some carbon fiber reinforced filament. Much better
[This message has been edited by Awalker W02 (edited 07-24-2025).]
. After the acquisition of my Formula in 2013, my '84 was "retired" and has been sitting under a tarp in my backyard for a dozen years. I wanted to drive it to my new place 50 miles east of here, and I was a little concerned with what I might need to do to make the car roadworthy again.
I borrowed the battery and a set of tires/wheels from my Formula, and with just the replacement of one sticking front brake caliper, I was able to make the trip with no issues whatsoever. Not only that, but I had forgotten how great the tweaked suspension feels on my '84. Even the lil' duke (with a 5-spd) felt good. Damn, I was impressed!
A photo of my '84 from years ago at autocross...
[This message has been edited by Patrick (edited 07-28-2025).]
It’s starting to look like a car again. Carpet in. Seat in. Engine put together - still needs tuning. Way too much fuel. Timing needs dialed in. I’m still learning how to use the Aces software.
Once the interior is zipped up I’ll install some glass.
Today I was tired of the stick holding the trunk 🤨 !! Problem solved .on my 84 .
Who's still selling these ? At some point while mine was off the road, the torsion spring broke, so I need to go to the 2-strut setup. I've got 1 gas strut on there already that I got from Rodney way back, but it doesn't look like he's still restocking those.
Got mine at Princess Auto in Canada , here the length I went for . But Napa auto carries them on this number . Hope it helps somehow 👍 …. Rob
Made a beefier (and better looking) dogbone mount for the 3400
If you are good with a welder. Part 3400/ part 4 cylinder bracket, part 6 cylinder braket. You can use the stock V6 dogbone. If it's only mounted to the 1 cylinder head and your motor moves during excelration, you will stip out those botls in the side of the head, trust me I know from experience. I only use 2 of the three bolts on the far cylinder head. I haven't had any issue with this set up in 15 years.
I Got Rodney's 'Electric Window Helpers' {Heavy Relays} Installed which are now "Out of Stock / All sold"
Rodney Dickman: Field tests have shown that even those that have installed new electric window switches still show a significant increase in electric window speed after these units have been installed.
It is true, without changing the system except adding the relays; the windows are faster now than before...
------------------ Original Owner of a Silver '88 GT Under 'Production Refurbishment' @ 136k Miles
Finally got to the point that I'm doing little things and driving instead of big huge things and not driving. Using this as a starting point I popped some 6.5s in the dash, under the deck itself, using a couple 3d printed brackets I whipped up, a couple short bolts and nuts, and some cardboard shims. I didn't think to get pictures, but it turned out "okay." I also took the clips off the 4x10s and soldered them to the new speaker terminals so I didn't have to do any wiring inside the car. I'm using the AM/FM/cass out of a 1986, but I think I'm just gonna get something more modern in the near future.
Went and ran some errands and then of course I get home to find the passenger side coolant tube has started a small leak. Less than ideal.
Four coats of gloss black / Three coats of clear coat Will end up with ceramic wax tomorrow after it stops raining.
Do NOT wax a new paint job!
The paint needs to cure before sealing it; the curing time can vary based on several factors, including the type of paint, environmental conditions, and the thickness of the paint.
Generally, it is recommended to wait 30 {hot/summer} to 90 {colder/winter} days before waxing the paint; this waiting period allows the paint to fully cure and harden.
I went the powder coating route...
[This message has been edited by Vintage-Nut (edited 09-25-2025).]
i installed a 1986 gt 7/8 inch front antisway bar on the back of my 87 base coupe.i used this webpage as a how to.https://fierozone.tripod.com/weekend/swaybar/index.html . the swaybar links he recomended at ten dollars are now 27 dollars so i reused all the old hardware.i did cut it down to length and buy new 5/16 grade 8 long bolts.the 'rubber'used parts appeared to have already been changed to poly.i like that it all looks 'factory'.
[This message has been edited by richard in nc (edited 10-05-2025).]
Started out for a car show in Pullman this morning only to turn around 20 minutes later, when the heater core I suspected was going finally started dripping into the cabin. Least I caught it early -- had one ready to swap out, all good tonight.
Hey, do you have a full-on picture of your car? It appears to have the old-school Gulf Porsche "livery" (I guess is what they call it).
replaced my wheel from a guy who recovers on ebay. excellent work. looks factory. bit expensive , but there arent many trimmers that even do wheels anymore. i asked for the thick padding, and it changes the whole feel of the car... like a vintage modern supercar feel
[This message has been edited by domer94 (edited 10-24-2025).]
Replaced coolant crossover tube on 88 GT V6 and replaced the 2 transmission mounts on the other 88 GT, replaced the distributor pickup coil and clutch master cylinder
I pulled the 86 out of storage for a quick detail, and I had a bit of help. Over the winter I plan on doing some detail work, like cleaning up and repainting the louvers and maybe getting some touchup paint for the scuffs and a fresh air cleaner.
i changed the auto transmission and engine mounts on my 1987 2.5 because there was a clunk shifting into reverse.the engine mount looked terrible.be aware that the 1987 auto mount rockauto sells is the wrong one.the fiero store has the right one.i installed the rubber sheet on the passinger side.the old one was gone.i tried to fix the hanging rear coolant pipe same side.the bottom plate had completely rusted away.the frame mount was still these on the back end but totally gone on the front.i put a 'new' bottom plate on it so its at least got one bolt holding it now.
I put some stickers of my car club on the sun roof:
It's in preparation for the Ouest Motor's Festival where my Fiero will be on display with a whole load of classic cars. https://ouestmotorsfestival.com/
------------------ "Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero https://youtu.be/hUzOAeyWLfM
