Alright this is my first time posting here on the forum. I'm a new member. I have been lurking for some time now, reading up on the northstar swaps and gathering any good info i can find. The best info i have found cam from a member who's name was something like Ajaxman or somethiing close. He posted several diagrams for the early northstar (1993 obd1) which have been a great help for me. The engine I have is out of the 1994 ETC model. The ECU pinouts seem to be correct even tho the wires are different colors which is not a big deal im sure. I am getting stuck on a few things tho and im pretty sure I could figure them out but i would like some reassurance.
On the oil pressure sending unit I have a 4 wire pigtail coming from it instead of 2 like all the others i have seen. That is the one that came on the engine when i pulled it.
I was thinking the spec stage 2+ clutch would be enough because it says its rated to over 400 ftlbs of tq, but it looks like most people are using the stage 3+??
As far as I have investigated it sounds like this year pcm has different processors for the engine and transmission, so the engine should run without the tranny/speed wiring?
On ajaxmans post for his 93 he posted that the fuel enable pin for the ECU coming from the pass key system might work with 2.5v? I dont want to run any sort of VATS or passkey. What voltage can I run to the fuel enable input to allow the engine to run? And i would just leave the starter inhibit output disconnected.
I haven't been able to get ahold of any forum members or companies who mess with these computers. Who is my best bet?
I will continue to search. I hope to add some pics soon but the system on this thread is different then i'm used to so i will follow the instructions and get it going as soon as possible. thanks guys
you only need two wires for the oil pressure, maybe just one (id have to look at mine , i believe it is only 1 wire) the others if for fuel pump relay and cuts the fuel when the oil pressure drops. No idea on the trans wiring or clutch , I run the 4t80e . As far as the passkey , I have mine wired up with the caddy key cylinder in a hidden location and just pull the key when in storage, have thought about eliminating it and using a resistor relay and push button..
87GTseries 1 3800sc (7.597 @88.53 1.579 60ft) (series II swap in progress) 85GT Northstar/ 4t80e 86GT 3800 n/a---sold Northstar Rebuild
A little more information about your Northstar Fiero configuration would help us.
Based on what you have said, you have an early 1994 Eldorado with an OBD1 computer and you are planning to run it with a manual fiero transmission. Is that correct? Or are you running the newer 6 speed G6 tranny?
You want to know what clutch to use, how to defeat the pass key/security, and if you can run the engine without the automatic transmission VSS? Is that correct?
The N* will run on a variety of computers and the stock computers can be altered based on your running configuration of choice.
OF course I already spelled Fiero wrong in the title. crap.
Correct you are right on track. The 5sp fiero transmission. Its not the getrag and i know it will have shift cable location issues and its not as strong but it's what im going to start with. I would like to run the stock computer. The engine/trans is already in the car with the subframe modified of course, and the engine bay as well. I also have the corvette fuel pump in the tank already and already used the factory fiero harness to crank the starter. Im waiting to buy the flywheel/clutch till I actually here this thing fire.
yes I would like to know how to get around the passkey. I had no idea of it when i pulled the engine/computer so it is long gone. It looks like when the passkey is activated it sends a signal voltage to the ecu to allow fuel flow. AJxtcman says here that the voltage required to allow the ECU to fuel could be 2.5v but it was never verified... does anyone know if this is true?
6th post down he said: 2C8 - PASS-Key decoder Fuel enable input. 2.5V? or Run it to A3 of the PK module.
Ok so I can just run the 2 wires on the oil sender then.... I have yet to see the sender with 4 wires like mine in any diagram or picture. weird. Also I dont have a diagram for the EVAP solenoid. its only 2 wires though. one wire goes to the ecu but im not sure if the other is 5v return 5v reference or just a ground. I think i'm making this more complicated than it is haha.
Typical oil pressure sender wiring - add a 4th pin (the one missing) as ground. I usually run all the wires to the oil pressure switch thus making the oil pressure switch a back up to the fuel pump relay.
Different color wires at the PCM than your pin out are a red flag. GM uses a fairly standard color set for it's sensors. The EGR is one place however that it seems to fail on this.
Passkey requires a signal, not just a voltage. Run this to the PCM passkey input. Yes drop the starter inhibit relay from the wiring.
The other end of your EVAP Solenoid goes to switched power. Most (not all) Pink wires go to +12v switched.
Gray +5v is generated in the PCM and is only used for sensors. Solenoids and relays run off of +12v. On almost all the PCM grounds the device to turn it on. The exception to this is the fuel pump relay. On the fuel pump relay the PCM sends out +12 v on the Dk. Green/White wire and the other end of the fuel pump relay coil needs to be grounded.
The PCM NEEDS a VSS input. Most PCMs will run the engine at a high idle without it. The PCM needs to know when IT should be adjusting idle (throttle closed and vehicle stopped) and when it should not be adjusting idle (throttle closed and coasting down a long incline). You can T wire the VSS output of the transmission to both the PCM and speedo. Note - sometimes the PCMs ground the VSS differently than the speedo. If after hooking it up you get no speedo and scanning the PCM shows no vehicle speed, reverse the two wires to the PCM and try again.
Try Ryan Gick - sp1@gmtuners to see if he can program the PCM.
Many late OBD1 PCMs look for a load on the devices it controls. Most OBD2 pcms do also. You may get trouble codes that turn on the MIL light, and may also reduce power without the electrical loads the transmission would produce.
ok I ordered that bypass and that was what I was looking for all along but it seemed like the ones I cam across still needed to the passkey module. -thank you. So when I go to wire that will I use the 30 or 50hz or have a switch to switch between the 2?
I will attach the oil sender diagram I have with the wire colors I have. Also will attach some of the diagrams from AJxtcman's post with my changes to some wire colors/terminal labels. The wires all seem to end up at the same pin and match up to the correct sensor or module, so I assume they are correct.. You'll have to look close to see what I have written down as different colored wires or terminal letter labels. I guess the wire I have labeled brown is more of a tan and it looks like it may of had a black line on it but not sure. But i assume it has the same purpose as the one on the diagram of course. I have the grey wire(d) from the sender going to pin 1b13 (fuel pump feedback) which also ties into the fuel pump relay. I think the pink(c) must be switched 12v? blk/wht(b) obviously to ground. So does that leave pin a on my diagram to go to the oil pressure gauge/light?
On my evap solenoid I have a Green/yellow wire and a tan wire. The green/yellow looks like green/white now maybe from age/oil haha, but it does go to ecu pin 3E12 (evap solenoid control). So you think the tan wire should go to switched 12+? maybe its really faded pink.
On the VSS I will need to create some circuit to convert it to what the PCM needs correct? I have seen it floating around here it looks like it can be built from radio shack with resistors and such right?
I tried gmtuners with no reply yet. Matthew Howell with Howell Engine Developmentes got back to me and said they can delete the transmission codes and such.
here are some pics of what im working with here just to have a visual. My build is kinda grungy compared to most of the ones I've seen here all cleaned up nice and such haha.
Also if anyone has a recommendation or link for a good firewall insulation/heat mat (im not sure what the actual name is) it would be helpful!
VATs bypass - You will have to see which frequency works with your PCM. Once you do that then just hard wire it.
Oil Pressure Sender - Yes pin A - Tan/Black - goes to C203 E - Oil Pressure Gauge/light. If your 84 has an oil pressure light only, then make sure to use an oil pressure sender for a light.
Evap solenoid - Yeah sometimes they used Dk. Green/Yellow instead of Dk. Green/White. The other wire is indeed Pink. Yes it runs to +12 switched.
So it sounds like I won't be able to use this sender except for what the pcm needs or I am not sure if it would throw a code.. Should of kept the one off the fiero engine to install into one of the oil cooler ports that will be plugged. So let me get this straight... the VSS on the fiero 5 spd can be wired straight to the N* pcm hi and lo speed sensor input? But I will need to use the speedo conversion to go from the ECU to the c203?
The C203 is the 2 smaller plugs under the console. The C500 is the big plug that connects the body wiring to power right? the c500 is in my last picture i think. I didn't know they were different but thanks for the heads up! I have yet to look at or come across any of the diagrams for either of these connectors, however i will need to very soon.
Usually the A - B portion of the oil pressure sender wires only to the oil pressure light / gauge. Usually the C - D portion of the oil pressure sender is only used as a back up to the fuel pump relay. So none of the oil pressure sender pins usually connect to the PCM.
The Purple and Yellow wires are tagged High and Low referring to their electrical properties. That is one is ground and one is signal. They are not a high speed and low speed wire however. Yes the Fiero VSS should be able to provide a signal input to your PCM.
Also when building an 84 harness I use a relay controlled by the pink ECM power wire to activate two more fused power circuits - one for the injectors and one for the other engine/transmission power requirements other than the MAF. I put the MAF on the pink wire that runs to the ECM and now also runs to this relay.
Fuse the injectors at 10A. Fuse the second circuit at 20A.
The ignition power wire on C500 I use for ignition power. I install a fuse at C500 (20A) since GM failed to fuse that circuit in the Fiero.
[This message has been edited by phonedawgz (edited 11-20-2014).]
ok I spend about an hour searching for this thru a few different threads... Can I use the factor exhaust crossover or will it run into the trunk? I really dont feel like test fitting it again to find my answer.. i see most people are running under the long axle instead of using the caddy crossover that goes over the axle.
i am using the factory crossover and have full trunk.
Are you using the factory rear manifold? When I was first doing my swap, it looked like the factory rear manifold outlet pointed right into the trunk. The rear manifold could be turned upside down, but then it pointed right at the rear cradle crossmember.
No i started with a 4spd but there was no way of making that work, it was just too far off. This is the Isuzu 5spd.
I was thinkin more along the lines of spacing the throttle body or moving the cable mount to the drivers side a couple inches and making some small adapters to move the selector arm mounts over the same distance.. is that unheard of?
Russ544 made an offset adaptor plate and described it in this short thread. Apparently the photos are no longer linked correctly so you may be able to PM Russ and get them emailed to you. I bought one of Russ's ITB setups so I no longer had the interference issue to deal with. Check page 11 of the thread that Will posted above for one option of working around the release arm interference.
hmm well i did find a 5sp getrag transmission about an hour away, so I am going to look at it friday... they want $250 for it and it has 100k on it so it might be a better deal then trying to complicate things with adapters or ITBs.. plus it's stronger as far as I have read. I also received my firewall insulation as well as a serpentine and idler pulley today yay. Still waiting to hear back about deleting the trans codes from my pcm. Clutch & flywheel on their way as well
got the new 5spd today. its pretty rough. I ended up only paying $50 for it since the case is broken where the upper clutch fork bushing is. looks like an easy repair with a proper sleeve. It is missing quite a few things like the shift cable end retainer/slave cylinder/throwout bearing and mounts. Im hoping i will be able to find the other half of what holds the cables in place
ok so I will be using that kit from him. But i will need the shft cable/slave bracket as well from the fiero store correct? I was wondering what mounts the select cable, or if that is included in rodneys kit... I took a look at the "transmission identification" thread here on the forum and there is a small bracket that looks like it's bolted onto the end of the case that retains the select cable
Is there any reason I would use a fiero getrag slave over the 88 cavalier slave? I plan on buying the cavalier one for the price and the fact they have a 1.25 bore instead of a 15/16.
Also the clutch release bearing I received with the clutch seems to be to big for the trans. its way to big on the input shaft. Im going to look for a cavalier bearing and see if its correct
That large bore slave is for the "internal release arm" linkage. If that's what your transmission has, then go for it. If you have a Fiero or other older FWD transmission, then you'll have the "external release arm" linkage and you'll need the smaller slave. You can't use the bigger slave on the external arm setup because it doesn't push far enough. You shouldn't use the smaller slave on the internal arm setup because it would dramatically increase pedal effort.
I suppose i will need longer bolts probably a 20 or 25mm for this application.. Spec has yet to get back to me on the fasteners to use, so I will go by this. Also the factory bolts i took off seem to be black/hardened bolts, should I match that with the new longer bolts, or would that matter.
I have the clutch fork out at the moment but you can see where it goes and where the case is broken. It has a clutch fork with a cast arm on it and a mount for an external slave cylinder so im pretty sure its not the hydraulic bearing kind.. if it is I might of missed the buss
okay I took a closer look at that input shaft and it looks like there used to be a sleeve there but it must of been destroyed. It really looks like something bad happened to this tranny like a clutch came apart or something. I think I might start looking for another getrag because getting this tranny into the subframe and shifting would cost $750 at least, and that's without touching anything inside of it.
new input bearing on its way from Rodney. Split the case and found that the diff bearings have quite a bit of pitting on them, so I will need to replace those. I really would like to get an LSD for this thing while its apart
I use 12.9 hex head (NOT socket cap) x 25 bolts on mine and use the stock torque to yield procedure... BE CAREFUL about the length. DO NOT bottom out the bolts, as the holes in the crank flange are thru and the bolts bottom against the rear main bulkhead. The TTY process permanently stretches the bolt and the bolts CAN NOT be reused afterward. The flywheel is thicker than the flex plate, so the strain from the TTY process is slightly less than it is at the stock length. The stronger material makes up for that.
The only thing a limited slip really does in a Fiero is *maybe* help you avoid one wheel wonder burnouts.
[This message has been edited by Will (edited 12-14-2014).]
I can't really tell if you mean one wheel burnouts are common or not? My fwd spins both tires, and it does not have any sort of LSD. If we do spin tires, is it the LR?? lollolol
btw got rodneys input bearing/sleeve in today. it was actually fun to do. It was well worth the $150 imo. As far as quality and ease of installation! I'll keep chuggin along tho. Need to get the differential bearings done, if i can figure out how to set the preload on the bearings... i've read a few threads on it, and i just end of getting lost. I'll get it figured out. I do appreciate your ongoing participation in this thread Will.
The Fiero does NOT have a tendency to do peg leg burnouts.
However, I have opened up a 282 transmission in which the diff was worn beyond repair by someone doing peg-leg burnouts with it. The interface between the side gears and the diff carrier and between the spider gears and the carrier & cross pin is not well enough lubricated to take sustained high surface speeds such as in a one wheel burnout. A friction device can act to prevent that. I say friction device because there isn't a proper LSD available for the 282 at all.
alright had the engine back in and all hooked up to try and test start it with no luck. not sure what i'm missing but it has to be something simple. I have the VATS bypass hooked up. I am getting spark. I have pressure at the fuel rail, but im not sure if the bypass is working or not. Will have to go through the wiring again it looks like
