  Project 3400 Roller Cam Block (Page 19)
This topic is 22 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14   15   16   17   18   19   20   21   22
Project 3400 Roller Cam Block by lou_dias
Started on: 07-27-2006 06:49 PM
Replies: 846 (33274 views)
Last post by: lou_dias on 10-17-2025 04:47 PM
La fiera
Report this Post06-02-2017 10:35 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are you giving up on the 3.4 PR?? Come on Lou!!! You are my inspiration dude!! One of the things that I made me do my 3.4 is that you never lost hope!! Come on man!!
lou_dias
Report this Post06-05-2017 03:52 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL I think you are confused. My 3.5 will be a 3400 block bored to 3.7" with iron heads.
3.4 and 3400 pistons are similar but the 3400 pistons have a deeper dish...as do 3500(non-VVT) pistons. Hence I will use longer rods and shave down the top of the pistons to lower the dish dept to compensate for the longer rod. 2.8 flat top pistons can support .510" of lift and luckily, there is a roller cam available from WOT-Tech with that lift.
Longer rods will increase dwell-time near TDC. Allow for a higher revving bottom end as the angle of rod deflection is reduced.
La fiera
Report this Post06-05-2017 06:57 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh ok! LOL. I was going to get longer rods for mine but I decided not to. I have .533 lift on mine with DOHC pistons and the crown sticks out of the deck about .050 or so and I don't have a problem with interference. My 2.8 had flat tops and I had .512 lift and never had a problem either.
Blacktree
Total ratings: 350
Report this Post06-05-2017 08:58 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
^^^ That's good to know. I'll be using 3.4 F-Body pistons, which have a slight dish on top (about 0.1" deep). So that should give lots of valve clearance!
lou_dias
Report this Post05-26-2019 04:13 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had some axle-snapping fun yesterday. Made it to final race and snapped an axle on launch. End up with 2nd place trophy. First event of the season.
Also first race after switching to E85 and picking up 10 rwhp and 12 ft*lbs
[This message has been edited by lou_dias (edited 05-26-2019).]
Total ratings: 236
Report this Post05-28-2019 09:22 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
What tires are you running in the front?
La fiera
Report this Post05-28-2019 09:54 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Way to go Lou!! Nice Job!
lou_dias
Report this Post05-28-2019 08:05 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Here is the whole event in it's axle-snapping glory!
lou_dias
Report this Post05-30-2019 06:53 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is this #6 since 2009? I've lost count...
lou_dias
Report this Post05-31-2019 10:30 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Last month's not-done-tuning yet dyno:
After this I discovered someone had regapped my plugs back to .060 hence the misfires (are down to .050" now) and I also made some adjustments to lean out the top end some more but I haven't had a chance to go back to the dyno yet to "record" the results. Though the axle-snapping performance is telling...
Report this Post05-31-2019 04:28 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
That almost looks like it wasn't fully torqued.
lou_dias
Report this Post05-31-2019 04:39 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the torque setting? I've heard 200# and 100#... But part of the problem is the Arraut bearing isn't "right" where the spline doesn't go 100% thru it due to a spacer that is required...
Report this Post05-31-2019 05:42 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero is 200 lb-ft.
lou_dias
Report this Post05-31-2019 07:21 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same as in the back just a different brand. Nitto NT01 and Toyo R888
[This message has been edited by lou_dias (edited 05-31-2019).]
Total ratings: 236
Report this Post06-03-2019 02:41 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you had to work to tame lift-throttle oversteer?
lou_dias
Report this Post06-03-2019 07:15 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm using the same HELD kit, slalom front with bump-steer correction in the back except now 13 years later my front "heim" joints are loose as a spruce goose... Alignment is straight. I just play with tire pressures. Lower on the inside, rear is 23 and 28 psi.
La fiera
Report this Post06-03-2019 09:02 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
A locked diff or a tight peg legger like you call it fixes that problem. It also fixes the high speed braking rear wondering of the car.
[This message has been edited by La fiera (edited 06-03-2019).]
lou_dias
Report this Post06-04-2019 09:32 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
My front end is more of a problem... I need to replace the heim joints that hold the pivot bar of the upper arms... That's the only thing preventing me from hitting turn 3 at WOT right now... Rear end is planted pretty damn good.
La fiera
Report this Post06-04-2019 10:35 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Give the front end a bit of toe-in
lou_dias
Report this Post06-24-2019 07:43 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Couldn't launch the car on Saturday.
You can see my nose bounce on both launches. I think I under-revved the launch... My tach has been inaccurate for years.
lou_dias
Report this Post07-05-2019 03:32 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
"An inside look" at my car!
lou_dias
Report this Post08-27-2021 08:47 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry for no direct updates in a while.
The car may have 1 last race in it for this season in October if:
I only have valvetrain issues that can be fixed before then.
On the Memorial Day race of this year, the track was wet and I over-revved the motor on both launches. 2 weeks later when I had brought it back to the track the car had a noticeable power loss. It now seems to be running on 4 cylinders.
I am hoping it's just a valve-train issue that can be fixed. In the meantime I have started building up a 3.5L build but waiting on the custom pistons and rods from La Fiera.
The other thing I am trying to fix is the handling. The rear HELD bump-steer correction arms are old have the heim joints are worn which is why I've been spinning out in turn 3/4 when driving hard rather that sliding out like an '88.
I ordered some parts from Grainger: 20F989 male rod end, RH, 3/4-16. That is based on information another ARRAUT rear bump-steer kit owner gave me. They need to be un-tack-welded and hopefully these are a perfect replacement and eliminate my wiggly behavior coming out of turn 2 and into 3 and 4.
So the car will be down another month. In the meantime I am adding some coil-overs to my red 3800SC-auto car so that may show up at the track again soon. F40 -> 4.9 swap is pending as well.
lou_dias
Report this Post02-23-2023 05:53 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long-story short, I lost compression in 2 cylinders.
Anyway here's the heads that were on that motor, the guides were warped so I had them drilled out and new guides were put in.
I will use these on my stock Formula once it's time to replace the 2.8...
https://rumble.com/v2aonfa-...-v6-heads-redux.html
Notorio
Report this Post02-24-2023 05:09 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Those 1.4" ID exhaust ports are incredible! Did you also do the custom mod to the middle intake??
Do you think you are now upper Intake limited? I guess the MPFI straight-shot intake must be quite a bit better than our stock, distributor-avoiding upper, yes??
lou_dias
Report this Post02-24-2023 06:11 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes, as I documented, I picked up 22 rwhp at 6000 rpm by notching the middle intake
I'm switching to a custom upper+middle combined intake for the next engine.
[This message has been edited by lou_dias (edited 02-24-2023).]
lou_dias
Report this Post09-06-2023 10:07 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
New build is finally getting closer to being done...
6" rods, custom pistons with 3.7" bore; titanium valves 1.8"/1.5" and a higher revving cam with ~.550" lift
fierosound
Total ratings: 286
Report this Post09-06-2023 11:08 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's an interesting oil filter adapter.
Tell me more.
[This message has been edited by fierosound (edited 09-06-2023).]
lou_dias
Report this Post09-06-2023 11:32 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It came with the used 3400 engine. It may hit our cradle and will probably get removed during the installation. I believe the donor was a 2000 Oldsmobile w/3400. It's 3.5L now. The machine shop was putting everything back on from the 3400 and I had to stop him. He had the 3400 water-pump on as well. I clipped that out of the pics... Ordering all new Fiero hardware.
[This message has been edited by lou_dias (edited 09-06-2023).]
fierosound
Total ratings: 286
Report this Post09-06-2023 07:49 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was wondering about that. It looks like it might.
But it's crowded in that area on my GT.
(NOTE: I have a later model small starter on engine now)
La fiera
Report this Post09-06-2023 09:33 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fierosound that looks like a work of art! What engine is that?
La fiera
Report this Post09-06-2023 09:40 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
Take some extra axles to the track because you'll go through them much faster now with that engine combo. Ask me how I know! And I don't know what clutch disk you have but a sintered iron disk would be perfect if you want to soften the punch on take off and be able to do it over and over. For your kind of racing I'd use a solid hub iron sintered clutch. You can slip it, dump it, etc and it will take the abuse. That way you don't look so predictable to your competitors. Can't wait to hear it roar!
jdv
Report this Post09-06-2023 10:25 PM Click Here to See the Profile for jdvSend a Private Message to jdvEdit/Delete MessageReply w/QuoteDirect Link to This Post
What type of exhaust gasket will you be using on this engine?
fierosound
Total ratings: 286
Report this Post09-07-2023 07:19 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! 3400 roller cam block with iron heads and Vortech supercharger. (built in 2000)
http://www.fierosound.com/34engine/3400details.htm
[This message has been edited by fierosound (edited 09-07-2023).]
lou_dias
Report this Post09-07-2023 04:41 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
aka my original inspiration!
lou_dias
Report this Post09-07-2023 04:43 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
There are individual Volkswagon gaskets I can use. There's also a larger gasket that comes with 3.4L Summit Headers that fit well.
fierosound
Total ratings: 286
Report this Post09-07-2023 05:17 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the VW exhaust gaskets as well. (not sure if they're available in Stainless Steel)
But I got these copper ones with the 1-5/8" hole that people were recommending. (4 in a package)
It's only once I got them that I noticed the stock exhaust gasket and heads only have a 1-1/2" outlet anyway.
1-1/2" rings also available - could have also used those. All installed - no leaks. YAY!!
lou_dias
Report this Post10-04-2023 10:07 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got holes closed up and had the Trueleo headers ceramic-coated. Also engine has been delivered to the shop for installation.
[This message has been edited by lou_dias (edited 10-04-2023).]
lou_dias
Report this Post01-31-2024 08:49 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's going in! Finally! And it didn't take 15 years!
[This message has been edited by lou_dias (edited 01-31-2024).]
La fiera
Report this Post01-31-2024 01:43 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Alright Lou! Can't wait to hear it roar!!
[This message has been edited by La fiera (edited 01-31-2024).]
Total ratings: 200
Report this Post01-31-2024 02:52 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! I just noticed this. Your passenger side driveshaft has some sort of support bracket with bearing... rather than I guess what the other Fieros have, which is an absurdly long driveshaft which can probably get somewhat easily unbalanced. This is pretty cool... was this custom, or is it specific to the transmission you're using?
