  Headlights acting up
Headlights acting up by Josh86gt
Started on: 05-02-2025 09:19 PM
Replies: 10 (153 views)
Last post by: Josh86gt on 05-03-2025 11:50 PM
Josh86gt
Report this Post05-02-2025 09:19 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I got this weird issue where when I want to put my headlights up I have to hold the switch at the halfway mark if I push it any further the lights will turn on but the motors will not move if I hold it halfway only the left headlight comes up if I get out of the car and turn the knob on the right headlight it will come up does anyone know what could be going on I have already replaced the headlight switch and that did not fix it
cartercarbaficionado
Report this Post05-03-2025 01:03 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
you might have some motor problems if they are the original 86 motors. push down on the not working ones knob and it may work for a second or probably not
Vintage-Nut
Report this Post05-03-2025 10:17 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member John W. Tilford had a headlight raise problem and posted three threads attempting to solve the issue.
Read his long headlight story which finally solved the problem by installing a new motor....
"Still having issue with driver side headlight not popping up..."
1) https://www.fiero.nl/forum/Forum2/HTML/148421.html
2) https://www.fiero.nl/forum/Forum2/HTML/148452.html
3) https://www.fiero.nl/forum/Forum2/HTML/148463.html
Gen 2 {87 - 88} Headlight motor Rebuild Instructions
https://www.fiero.nl/forum/...060811-2-066668.html
Gen 1 Headlight motor disassembly
https://www.fiero.nl/forum/...050119-2-045256.html
GreggDauer
Report this Post05-03-2025 09:15 PM Click Here to See the Profile for GreggDauerSend a Private Message to GreggDauerEdit/Delete MessageReply w/QuoteDirect Link to This Post
here's the trouble shooting steps I followed to diagnose my 84 headlights with similar issues.
http://www.fieros.de/en/articles/headlight.html
mine ended up being the isolation relay. kind of pricey for just a relay, but the head lights are worth it to me. I believe Rodney is the only one who sells them.
http://rodneydickman.com/pr....php?products_id=418
Report this Post05-03-2025 09:41 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
fiero store now carries them and the other associated relays
https://www.fierostore.com/...px?s=62620&d=273&p=1
Josh86gt
Report this Post05-03-2025 09:43 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just replaced my isolation relay months ago I doubt it is broken I also replaced the left side motor relay I can switch it to the right and see if that fixes anything but I'm still not sure about holding the headlight switch halfway
Josh86gt
Report this Post05-03-2025 10:24 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Josh86gt
Member since Oct 2024
Ok so I switched the motor control relay left to right and vise versa now they both come up but I still have to hold the switch half way
Report this Post05-03-2025 11:43 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
guess you had a bad connection on one of the relays. as for the switch im thinking they made it wrong or one of your wires is being flaky
Josh86gt
Report this Post05-03-2025 11:45 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought a new switch as well and I'd didn't change anything
I despise electrical issues
Report this Post05-03-2025 11:46 PM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
you and me both buddy....you and me both... at least both of your turn signals work when the head lights are on right?....why is that my major issue on fieros man.
Josh86gt
Report this Post05-03-2025 11:50 PM Click Here to See the Profile for Josh86gtSend a Private Message to Josh86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ya know I haven't checked I'll look at that in the morning
