Only have 2 sizes for external lines, 3/8 & 5/16
Need right Type of hose.https://www.fiero.nl/forum/.../HTML/144395.html#p6https://www.fiero.nl/forum/Forum2/HTML/146240.htmlVent & Return line can use same low pressure "rubber..."
Feed line should be R9 on any high pressure like Fiero V6. Many just "standardize" feed line to R9 even on low pressure systems like duke etc w/ TBI only need 9-13PSI to run.
Notes:
● Some "low fume" Fuel Hoses may need different clamps etc because have thicker walls. EPA etc often requires "low fume" rubber when replace old rubber. (Not just AC that need "barrier" hose.)
● Most of J30Rxx are Not rated to take E15 to E85 fuel. The whole car are Not rated for that even when some "convert" old vehicles to run E85.
"Flex Fuel" vehicles have many "mods" to handle straight gas to E85 & back even before the adding fuel sensor etc to set timing & fuel maps for amount of ethanol @ any time.
Good luck finding Fill Hoses. (Liquid & Vent hose.) Even if you find right material, formed 90° bends are not easy to get.
You can't use coolant rubber as fuel fill hoses.
