CVXJET, Your compressor set is like the set I bought.
Late-Formula, I was thinking about cutting off some length on the draw bolts, but came up with plan "B"..
I used (1) compressor of the set to begin the arc I needed which got me half way there. I then used the flat handle end of a looooog adjustable wrench and was able to pry the bottom of the spring across the top of the perch. I then used the floor jack to lift the control arm high enough to connect the upper ball joint. The aid of a car lift also made things go better.
Don't clap yet. How much effort should it take to swing the spindle assembly across its arc? A few years ago I replaced the upper & lower ball joints and today I had to use both hands with considerable effort to swing them. I regreased everything and they're still tight. I have power steering so I never notice anything at the wheel inside. Yes, the tie rods were also disconnected. Other vehicles, I can swing the spindle with barley any effort when the tie rods are disconnected.
What gives? And thanks for the info on the springs..
ps: Maybe I should start a new topic on the tight spindles..
Spoon
"Kilgore Trout once wrote a short story which was a dialogue between two pieces of yeast. They were discussing the possible purposes of life as they ate sugar and suffocated in their own excrement. Because of their limited intelligence, they never came close to guessing that they were making champagne." - Kurt Vonnegut [This message has been edited by Spoon (edited 07-31-2023).]
