  1988 LFX Build Lessons Learned/How to (Page 3)
1988 LFX Build Lessons Learned/How to by RandomTask
Started on: 04-17-2021 08:03 PM
Replies: 103 (4253 views)
Last post by: Will on 12-07-2025 09:30 AM
RandomTask
Total ratings: 150
Report this Post11-22-2021 09:25 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was bumping Daryl's thread; glad you figured it out. I went with https://www.keislerautomation.com/ for my harness. You could build your own, but for his price (~$900), saved a LOT of headache.
Parts are with the powder coater now. After that, hopefully finishing it up! More pics to follow
RandomTask
Total ratings: 150
Report this Post12-07-2021 09:39 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Getting new front suspension bits ready for swap this weekend. Going to finish the front SS brake lines while I'm at it.
I'm not a fan of thr gloss black from the por 15 on the cross member but fot the cost delta of what everything else cost to powder coat, it's hard to beat.
Trinten
Report this Post12-07-2021 11:21 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking sharp! That looks like some OEM, NOS, out of the box stuff right there!
It's like one of those pictures that everytime you go to a car show, you'll be like "why can't you look as good as you did in *that* picture!"
(I know, most people don't look under cars at car shows, but every now and then you see that guy who's brought the dressing mirror and/or the drive up car stands to raise one side of the car.)
RandomTask
Total ratings: 150
Report this Post12-08-2021 11:37 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! I do it more for the rust protection and hoping to keep the car for a while. That and all the suspension stuff was/is original so 30+ years and~120k miles old.
On thing I'm trying are the front shocks. We have absolute -crap- for selection. I really want some bilsteins so I was browsing their catalogue and they have some that are usually used on '67 camaros that should work for us. The unknown is the damping ratio.
Anyway, I bought a set to see if they physically fit. I'll report back on ride quality.
Total ratings: 236
Report this Post12-08-2021 12:01 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I remembering poorly or are the upper control arms on the wrong sides?
RandomTask
Total ratings: 150
Report this Post12-08-2021 02:43 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
They're on the correct side. I'm still hunting for the smaller mounting shaft washers. Because of this, I haven't pressed the front bushing back in yet.
MikesFirstFiero
Report this Post12-14-2021 02:28 PM Click Here to See the Profile for MikesFirstFieroSend a Private Message to MikesFirstFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you considered KYB shocks? I've used them in a couple of cars, including my Fiero, with good results. RockAuto has them at about $30 each. For the rears the 85-87 will work but you must grind off a sharp edge near the top bolt hole. Someone already has a posting of doing that.
RandomTask
Total ratings: 150
Report this Post12-27-2021 11:28 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
Will have to load pics from my phone but was able to get everything buttoned back up. All the new SS brake lines installed (Now I want to do the clutch line; go figure.), brakes rebuilt and back on, and back on the ground.
Was talking to my wife last night for the next steps.
1.) Do the dash. RIght now I have a manual oil pressure gauge with a jury rigged installation. Planned on picking out an aftermarket dash (IE AiM) and installing so I can monitor everything real time.
2.) Drop car off at a shop for four wheel alignment+help figure out why car is going stupid in closed loop.
3.) Switch body panels for Aero parts (Still on the hunt of someone generally local parting out a GT)
4.) Mr. Mikes seats.
5.) Paint. Let the kid pick the color. She wants it red w/ a #10 on the side. No idea why, but that's what's going to happen. Will also need a new windshield as one on car currently is properly cracked.
La fiera
Report this Post12-27-2021 06:35 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking of swapping a 3.6 V6 into my BMW, for similar reasons. The biggest engine available in the E46 BMW was a 3 liter straight-6, with just over 220 HP. I could swap in an engine from an M3, but that would be stupid-expensive, and the M3 engine is about 100 lb heavier (iron block).
Or I could swap in a GM 3.6 V6 which weighs less than the BMW 3.0 L6, and makes about 70 more HP. Hmmm...
Anyway, I didn't mean to derail your thread. Are you going to take video of the engine running?
Another route is using just the cams from the M3s. I used to do that cam swap back late 90's early 2000's for the stock endurance racers and it was worth about 30hp.
Add to that, that you can get stock ITB's for the in line 6 with a Megasquirt, H beam rods which are available and balance the entire assembly and rev it to 8200rpm. That would be a killer set up at the track and on the streets to have fun! Oh, and make it manual!
RandomTask
Total ratings: 150
Report this Post03-12-2022 03:46 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
So update; I'll get pics loaded soon. Placing order for dash this weekend. Settled on the AiM MXG Strada. Designing a new dash to plop in.
Moved battery up front. Buddy cutting out box dimensions as we speak.
Discovered headlight module was roached. Replaced relay inside.
POR-15'd front of car.
Installed rivnuts on all the holes the trim usually uses for those stupid plastic nuts.
Seems like slow progress, but once dash get's in and installed, car can go to and be made 100% driveable (hopefully). So getting to the final stretch! Items after that are all for appearance (coil overs, wheels, paint, etc)
RandomTask
Total ratings: 150
Report this Post06-29-2023 02:36 PM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been a long time since I bumped this thread. Car runs and drives. Had the exhaust fabbed and put on. Still goes ape crap after it goes into closed loop. Tuner looked at it and realized it was pulling ~60* of timing. . .
I have a strong suspicion of what it is; been concentrating on building my dream garage so this has been on the back burner.
So right now it just sits waiting for me to work on it
[This message has been edited by RandomTask (edited 06-29-2023).]
Trinten
Report this Post06-30-2023 10:24 AM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool that the problem was found. Sucks that it was an issue the tuner did, thankfully he caught it and it didn't damage the engine.
Where are the pics you mentioned wanting to put up almost 4 months ago?
rglasco101
Report this Post06-30-2023 03:16 PM Click Here to See the Profile for rglasco101Send a Private Message to rglasco101Edit/Delete MessageReply w/QuoteDirect Link to This Post
did you have to make any mods to your cradle? I could not really tell from the pictures and honestly may have missed it
RandomTask
Total ratings: 150
Report this Post08-30-2023 12:14 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
To be clear, it wasn't the tuner. My suspicion is the following:
1.) The LFX ECU -must- get a PWM signal from the driveline else it thinks the engine is working but not moving the car. To do this, I had to install a voltage up resistor on my hal effect sensor. I either got the wires crossed or I put the wrong resistance on it.
RandomTask
Total ratings: 150
Report this Post08-30-2023 12:16 AM Click Here to See the Profile for RandomTaskSend a Private Message to RandomTaskEdit/Delete MessageReply w/QuoteDirect Link to This Post
RandomTask
Member since Apr 2005
I did nothing to the cradle short of weld the two engine mounts onto it. I purchased the trans mounts from someone who fabricated them for the F40.
The only crap thing about this is that the purchased F40 mounts prevent the use of the rear sway bar. Pickhard performance (sp) has been working w/ Paul to replicate what his fiero uses; I will be picking one of these up once they come for sale.
fredtoast
Report this Post08-30-2023 08:12 AM Click Here to See the Profile for fredtoastSend a Private Message to fredtoastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Currently driving a '13 Impala. Love this engine. Pulls hard, revs high, and gets 26 MPG in a car that weighs 3800 lbs. And even though I love the rumble of a V8 I want to keep my Fiero a little more "stealth".
I can't use my current car as a doner because it is too nice. But definitely planning on using the LFX.
NGJohnsonIII
Report this Post06-07-2025 07:42 AM Click Here to See the Profile for NGJohnsonIIISend a Private Message to NGJohnsonIIIEdit/Delete MessageReply w/QuoteDirect Link to This Post
With the permission of RandomTask I'm picking this thread back up. My father and I have been Fiero people since about 1998 but it's been a while since either of us had one on the road. We ended up picking up RandomTask's 88 LFX swapped Formula and are trying to finish the project. First off, I'd like to thank RandomTask for all of this help and for selling us his baby. I promised to bring it to Summit Point for an HPDE event so he can drive it after we get it going, and I intend to keep that promise!
The car sat for a few years and after figuring out it wouldn't start due to the ECM not being powered, we fixed that issue, installed a fresh battery, and she fired right up but still dies after warming up and makes some timing chain noise before stalling, which makes me think the VVT is acting up. We're getting DTCs for an O2 sensor, accelerator pedal, oil pressure sending unit, and clutch pedal position. We replaced the accelerator pedal, which cleared that code, and we're replacing the bad O2 sensor, which should clear that code. The ECM isn't receiving an oil pressure signal, as the oil filter relocation kit removed the oil pressure sending unit. We ordered a new sending unit and will tie it into the filter relocation kit, but we're having a hard time finding the sending unit connector in the wiring harness. I'm hoping this might solve the issue with the car pulling too much timing when it warms up. I purchased HP Tuners and plan to remove the clutch pedal position sensor function as I'm told it's not needed, is that accurate?
Does anyone have any additional information on how to get the VSS signal to the ECM on the F40 when it's not equipped with a factory VSS?
Thanks!
Trinten
Report this Post06-07-2025 08:20 PM Click Here to See the Profile for TrintenSend a Private Message to TrintenEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey NG!
Welcome to the boards, glad to see you picked up a project and are already making progress!
As I am terrible with PFF's native search, I'd say use google, preface your search with site:fiero.nl and search for F40 VSS. There's more than a few guys here that have swapped in F40s (FieroGuru is one that springs to mind for me, and his threads are always full of great technical info). So you'll likely be able to chase down that answer there.
Good luck!!
rbell2915
Report this Post06-08-2025 07:50 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck on wrapping this up!
Total ratings: 236
Report this Post06-09-2025 08:25 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Cool! Congrats on the new acquisition!
I'm in Springfield, VA and I'd like to see the car at some point.
NGJohnsonIII
Report this Post06-13-2025 01:48 PM Click Here to See the Profile for NGJohnsonIIISend a Private Message to NGJohnsonIIIEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely! I've sent you a PM
NGJohnsonIII
Report this Post12-05-2025 06:39 PM Click Here to See the Profile for NGJohnsonIIISend a Private Message to NGJohnsonIIIEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's been a long time since I updated this thread and I haven't made a lot of progress, but I have made some. We discovered that the PCM didn't have an oil pressure input, and I hoped that might be why the car was running rough when the engine was warm, so we removed the oil filter plate and remote oil filter and installed a factory oil filter adapter and oil pressure sending unit and re-pinned one of the secondary O2 sensors to send the oil pressure signal to the PCM. While that didn't fix the issue with the engine pulling too much ignition timing advance when warm, at least now we can monitor oil pressure via an OBD II scanner or HP Tuners.
This is my first experience with HP Tuners so I'm very much still learning. I was able to easily remove the clutch pedal DTCs and I compared a factory 2014 LFX Camaro tune from HP Tuners repository, made a few changes to get the existing tune back to stock, and flashed the PCM. My "factory" tune still didn't fix the timing issue. I forced the PCM to run in open loop only, still no luck. Every time the engine runs decent until the coolant temp increases, then you can watch the VCM Scanner advance the timing to 60 degrees and the engine stalls.
I posed on HP Tuners looking for some help and advice but neglected to save a log file so other tuners can watch what is happening. It will probably be a few months before I get the opportunity to do that but that seems to be my next step. Unless anyone else has a good LFX tune file I could try to use!
Report this Post12-05-2025 07:38 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Overall an excellent swap job but the concerning part is I read that the LFX engines do not have the best readability record. That is according to the car wizard . It may be on high mileage engines though. Not sure what to believe.
Total ratings: 236
Report this Post12-07-2025 09:30 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well my bad... I completely flaked on replying.
