  1987 mera rebuild (Page 2)
1987 mera rebuild by LEEEZARD
Started on: 02-18-2013 06:42 AM
Replies: 93 (3243 views)
Last post by: LEEEZARD on 07-01-2013 01:54 AM
LEEEZARD
Report this Post02-18-2013 02:39 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Sage:
Lots of great pics/info! Added to favorites. Thanks for taking the time.
HAGO!
thank you sage. im pretty sure im the only one in the last decade, maybe longer, that has been this deep in a mera. i know more details than most ppl should, lol. i found my other mera pics of my car as was being disassembled on one of my other computers. i will load them up later on here.
[This message has been edited by LEEEZARD (edited 02-18-2013).]
Rodney
Total ratings: 267
Report this Post02-18-2013 03:18 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by LEEEZARD:
mera replica tailpipes
These are my original Corporate Concepts OEM tailpipes I took off my 88 Mera laying on my brick patio at my old house. I used them to make the reproduction Mera tailpipes I now sell. I started making them because Bob Bracey stopped making his and no one else was making them. They had rust holes in them that I patched and brazed on. I later changed my exhaust and I now have chrome dual resonator tips. I cut the steel crash plate some and notched both sides of the trunk so they come straight back, up and out the openings. They have that large offset as they have to go around the trunk and then out the openings. These Corporate Concepts tailpipes were very well made and were very high quality tailpipes. The outlets were both perfectly round. Mandrel bent. Precision made. I think ceramic coated. Mine rusted from the inside out I'm sure. Bob Bracey later on sold reproduction Mera tailpipes for a while but the one pipe (the ones towards the middle) was somewhat smaller and slightly oval from using a standard exhaust bending machine and looked low quality. They were also not ceramic coated. My reproduction Mera Tailpipes are made with a receding mandrel and are also both perfectly round on the outlet like the originals.
Why is the muffler end of the tailpipe expanded much larger than it needs to be to go on to the muffler outlet pipes? This worked like a ball joint and allowed the pipes to be moved left and right so they would in the center of the body opening. This is why they had the 4 wide slots cut into them.
Why did some exhaust pipe ends stick out farther in the exhaust openings and some were close to flush to the body and hardly stuck out at all? At the Mera reunion I noticed some tail pipes stuck out much farther on some Mera's and less on others. We talked about this in the past and think it was because there was a very loose tolerance on the GM exhaust system when it was made. On a standard Fiero this is not very noticeable. It shows more on the Mera. Possibly it was the difference between an 87 and 88?? One would have to look at Meras with OEM exhausts on them yet.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
LEEEZARD
Report this Post02-18-2013 03:27 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you rodney, good information sharing.
Rodney
Total ratings: 267
Report this Post02-18-2013 03:36 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
more from the library
What rims were these used on the 86 Mera for these sales flyer pictures?
None. They were quickie (maybe fiberglass) mock ups using a real 308 Ferrari rim (One of the 2 real 308 Ferrari's they used to make the buck [overlay modeling clay on a Fiero chassis] to make the Mera panel molds) to make a quickie mold. They were only used for pictures. Left on they would have fallen off if driven.
What happened to the buck that was used to make the panels? The clay parts were removed and the original Fiero parts were reinstalled and they sold it. I'm not sure what year it was. The development of the Mera started in 1985. So it could have been an 1985 Fiero they used. I have pictures somewhere of that. I have pictures of one of the real 308's sitting next to the buck when they were doing the clay work.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Sage
Total ratings: 71
Report this Post02-18-2013 04:12 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Rodney:
Would like to see those pics sometime should you be inclined.
HAGO!
LEEEZARD
Report this Post02-18-2013 04:23 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
some old photos of 7071 being taken apart;
LEEEZARD
Report this Post02-18-2013 04:26 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
Member since May 2011
LEEEZARD
Report this Post02-18-2013 04:29 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
LEEEZARD
Report this Post02-18-2013 04:31 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
danno this ones for you, its that same black textured tape yours has on the bottom...
LEEEZARD
Report this Post02-18-2013 04:35 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
LEEEZARD
Report this Post02-18-2013 04:38 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
LEEEZARD
Report this Post02-18-2013 04:43 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
HAGO!
i dont have pics of the buck. but thanks to danno, we have pics comparing the 308 to a mera.
LEEEZARD
Report this Post02-18-2013 04:45 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
[QUOTE]Originally posted by LEEEZARD:
i believe your info to be true. on the 308 cars the wheels that our cromodoras replicate were actually fcar campagnolos.
LEEEZARD
Report this Post02-18-2013 04:48 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
some of the early 80's real f308 cars had a vitaloni flag mirror with the exact part number that is shared with the mera vitaloni. but the bases of the mirrors are slightly different, likely due to how they bolt on the door surface. also alfa romeo used a vitaloni flag with the same part number on their spiders, but again the base was different due to how it bolts on.
LEEEZARD
Report this Post02-18-2013 04:51 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
while the mera1 taillights are mera specific, the backup lights are mid 80's ford escort wagon or mercury lynx backup lights. the 2.8v6 emblem is from a mid to late 80's s10 truck. the gts emblem is from a lebaron gts. the mera letters on the trunk is from mid 80's grand am se, or pontiac parisienne, or pontiac firebird's with chrome lettering.
LEEEZARD
Report this Post02-18-2013 04:54 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
with the exception of the body panels and how they attach, the rest of the mera is based solely off the fiero. some interior could be added, ttops from cars and concepts could be added, so on. but most is still just fiero. the 1987 mera's are gt's and some se's. the 1988 mera's early on were gt's/at least 6, and later in 88 were based on the formula's.
LEEEZARD
Report this Post02-18-2013 04:55 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
the 1986 6001 prototype is a se v6. pictured here with 7002
LEEEZARD
Report this Post02-18-2013 04:58 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
awhile back/maybe a yr or so... i talked to the owner of the prototype about me purchasing it. we could not come to terms. we werent off by far but its not a car you can take a loan out on, it would have been a cash purchase. likely someone could own that car for around 16-17grand or so if he still has it. danno has the contact info.
LEEEZARD
Report this Post02-18-2013 05:05 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
the general consensus is that there is 247 meras, 88 1987's and the rest 1988's. but there is some information that corporate concepts had some left over inventory of panels after they crushed their molds. and these panels were sold off. so some mera like cars likely exist and might not be that detectable other than construction brackets, mera sticker, or both. in the case of 7002 the theory is that danno has it although it does not have a sticker. but.... it has alll of the early proto traits and construction process that the stickered meras have. thus making a good assumption its a very early/7002 or maybe another proto or similar. too many clues on that car to be fake. imo.
post script; and rodney has stated that some of the early cars did not have mera stickers...
batousai666
Report this Post02-18-2013 05:16 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
OI!!! i want this tooo
the other one is broke, yes?? if i remember you are not using this right??
nice write up Pal!! you been busy!
LEEEZARD
Report this Post02-18-2013 06:32 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
danno consider it yours... im sure we can negotiate a fair price, like a penny or something lol.
LEEEZARD
Report this Post02-18-2013 06:39 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
this car went on her side, then upside down on her lid, it held together very well considering. had the frame checked and she was not off by far. almost all the damage was front suspension and cosmetic body panels. says alot about these little cars.
LEEEZARD
Report this Post02-18-2013 06:42 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
yes. and while all this info is in the mera in paradise thread and public info from there, this is likely the most info in one topic on a mera that has been put out in less than 24hrs in volume, in the last 26yrs.
batousai666
Report this Post02-18-2013 06:44 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
right on!! ship it today and give me a total ok tomarrow...will be good too
ha! thats cool thanks again ......i thought i never would see the OEM Pipes, and sails. not ever. so please be a bit generous to yourself when pricing everything. i am a cheap skate but i like you. youm good peeps!
you are right. the Mera Panels are way tuffer than the new Fieros, panels. unreal how thin the OEM Fiero ones are.
the doors and lids seem thick. but the wraps are thin....and light, which is alright!
[This message has been edited by batousai666 (edited 02-18-2013).]
batousai666
Report this Post02-18-2013 06:50 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
batousai666
Member since Jun 2009
that is true....i will go thru with a tooth comb to see wots wot and maybe do some quotes capture...if you dont mind?
LEEEZARD
Report this Post02-18-2013 06:51 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
post away danno...
LEEEZARD
Report this Post02-18-2013 07:11 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
i have the lights and mera letters on the shelf, easy to get to, but the sail panel is still on the car and the car is buried in the back right now. might be a few days before i can get that off. have to wade thru some pcars to get to it lol
batousai666
Report this Post02-18-2013 07:15 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
at your lesiure.....its still Winter afterall
and thanks for piling all the info in one page well 2 pages. i was too overwhelmed with the suff i have much less the monster "Paradise" Thread
plus i got no love for the '88 Fiero. all smug with its better suspention and all.....phooey
i got the Proto Mera and all the 1987's locked,now. Both, Mera and Fiero....inside and out.... someone else can do the '88 mera.
i guess i was born a 1987 Fiero guy
LEEEZARD
Report this Post02-18-2013 09:41 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
you still have more paper info than me. im just the guy who tore one apart.
batousai666
Report this Post02-19-2013 08:17 AM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
you know??
when you tore off your panels did you check then insides for maybe a wax pen or something with your 7071 on it??
that would be the cats ass....if i have even one panel with my number on it a truely Awesome, would be had if so
Fieromaineac
Report this Post02-19-2013 02:27 PM Click Here to See the Profile for FieromaineacSend a Private Message to FieromaineacEdit/Delete MessageReply w/QuoteDirect Link to This Post
per tommy;
It was not an idle threat. In 1987, Ferrari filed a suit against Corporate Concepts. They decided to settle out of court. This was their public release at the time:
MERA PRODUCTION TERMINATED UNDER CONSENT DEGREE WITH FERRARI
Detroit, Michigan (June 1, 1988) -- Corporate Concepts Limited announced today that it will promptly cease production of its "Mera" automobile body conversion under a consent decree it has entered into with Ferrari S.p.A to settle the trademark infrigement suit that Ferrari filed after the Mera was introduced. Ferrari's suit in the Federal District Court in Port Huron sought a permanent injunction against the Mera, alleging that its body and exterior appearance was a simulation of the Ferrari 308 and 328 automobiles. The consent decree provides for the production of a small number of additional Meras during a short phase-out period. (RELEASE ANY TIME)
I vaguely remember reading someplace where as part of the consent decree, all of CC's original modes had to be witnessed/destroyed by running over them with a bulldozer, or something like that. I'd wager, however, that at least some of the remaining unused panels went "underground" to give birth to the 308 Kit Car.
Tom
Here are the documents from Bob Bracey,
Dana (Mera 8151)
LEEEZARD
Report this Post02-19-2013 06:08 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you maineac, good info. more from the library;
LEEEZARD
Report this Post02-19-2013 06:12 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
LEEEZARD
Report this Post02-19-2013 06:14 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
more...
LEEEZARD
Report this Post02-19-2013 06:15 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
2 slat grill on dannos car;
LEEEZARD
Report this Post02-19-2013 06:16 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
LEEEZARD
more;
jaskispyder
Total ratings: 205
Report this Post02-19-2013 07:04 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the looks of the mera..... too bad they copied Ferrari so closely (business-wise)
batousai666
Report this Post02-19-2013 07:05 PM Click Here to See the Profile for batousai666Send a Private Message to batousai666Edit/Delete MessageReply w/QuoteDirect Link to This Post
more;
i has dreams that that is Mera X!!!! wonder if thems real Cromodoras??
ever notice how the interior shot in this brochure that "Mera" has no door bumpers, has the OEM Fiero mirror switch, and the SE style steering wheel??
awesome....toooo bad its a Manual Trans. i would have to wet myself, if not
Sage
Total ratings: 71
Report this Post02-19-2013 07:15 PM Click Here to See the Profile for SageSend a Private Message to SageEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good stuff! Really nice being able to see all this "nostalgia"/history on one of my favorite cars.
Thanks again to those who are sharing, I for one, appreciate it, and I'm sure there are others that share the sentiment.
HAGO!
LEEEZARD
Report this Post02-19-2013 07:42 PM Click Here to See the Profile for LEEEZARDSend a Private Message to LEEEZARDEdit/Delete MessageReply w/QuoteDirect Link to This Post
thank you sage. we, as in danno and i, even have a dvd sales type video.
