Update System
  Totally O/T
  Coolest planes (Page 2)
Coolest planes
by 2.5
Started on: 12-16-2021 01:50 PM
Replies: 60 (1533 views)
Last post by: Valkrie9 on 11-12-2026 12:52 AM
cvxjet
Report this Post Click Here to See the Profile for cvxjetClick Here to Email cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the Pilot explaining how he was thrown out of his SR-71 as it broke apart at mach 3;
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
We took off from Edwards at 11:20 a.m. and completed the mission’s first leg without incident. After refueling from a KC-135 tanker, we turned eastbound, accelerated to a Mach 3.2-cruise speed and climbed to 78,000 ft., our initial cruise-climb altitude.
Several minutes into cruise, the right engine inlet’s automatic control system malfunctioned, requiring a switch to manual control. The SR-71’s inlet configuration was automatically adjusted during supersonic flight to decelerate air flow in the duct, slowing it to subsonic speed before reaching the engine’s face. This was accomplished by the inlet’s center-body spike translating aft, and by modulating the inlet’s forward bypass doors. Normally, these actions were scheduled automatically as a function of Mach number, positioning the normal shock wave (where air flow becomes subsonic) inside the inlet to ensure optimum engine performance.
Without proper scheduling, disturbances inside the inlet could result in the shock wave being expelled forward–a phenomenon known as an “inlet unstart.” That causes an instantaneous loss of engine thrust, explosive banging noises and violent yawing of the aircraft–like being in a train wreck. Unstarts were not uncommon at that time in the SR-71’s development, but a properly functioning system would recapture the shock wave and restore normal operation.
On the planned test profile, we entered a programmed 35-deg. bank turn to the right. An immediate unstart occurred on the right engine, forcing the aircraft to roll further right and start to pitch up. I jammed the control stick as far left and forward as it would go. No response. I instantly knew we were in for a wild ride.
I attempted to tell Jim what was happening and to stay with the airplane until we reached a lower speed and altitude. I didn’t think the chances of surviving an ejection at Mach 3.18 and 78,800 ft. were very good. However, g-forces built up so rapidly that my words came out garbled and unintelligible, as confirmed later by the cockpit voice recorder.
The cumulative effects of system malfunctions, reduced longitudinal stability, increased angle-of-attack in the turn, supersonic speed, high altitude and other factors imposed forces on the airframe that exceeded flight control authority and the Stability Augmentation System’s ability to restore control.
Everything seemed to unfold in slow motion. I learned later the time from event onset to catastrophic departure from controlled flight was only 2-3 sec. Still trying to communicate with Jim, I blacked out, succumbing to extremely high g-forces. The SR-71 then literally disintegrated around us. From that point, I was just along for the ride.
My next recollection was a hazy thought that I was having a bad dream. Maybe I’ll wake up and get out of this mess, I mused. Gradually regaining consciousness, I realized this was no dream; it had really happened. That also was disturbing, because I could not have survived what had just happened. Therefore, I must be dead. Since I didn’t feel bad–just a detached sense of euphoria–I decided being dead wasn’t so bad after all. AS FULL AWARENESS took hold, I realized I was not dead, but had somehow separated from the airplane. I had no idea how this could have happened; I hadn’t initiated an ejection. The sound of rushing air and what sounded like straps flapping in the wind confirmed I was falling, but I couldn’t see anything. My pressure suit’s face plate had frozen over and I was staring at a layer of ice.
The pressure suit was inflated, so I knew an emergency oxygen cylinder in the seat kit attached to my parachute harness was functioning. It not only supplied breathing oxygen, but also pressurized the suit, preventing my blood from boiling at extremely high altitudes. I didn’t appreciate it at the time, but the suit’s pressurization had also provided physical protection from intense buffeting and g-forces. That inflated suit had become my own escape capsule.
My next concern was about stability and tumbling. Air density at high altitude is insufficient to resist a body’s tumbling motions, and centrifugal forces high enough to cause physical injury could develop quickly. For that reason, the SR-71’s parachute system was designed to automatically deploy a small-diameter stabilizing chute shortly after ejection and seat separation. Since I had not intentionally activated the ejection system–and assuming all automatic functions depended on a proper ejection sequence–it occurred to me the stabilizing chute may not have deployed.
However, I quickly determined I was falling vertically and not tumbling. The little chute must have deployed and was doing its job. Next concern: the main parachute, which was designed to open automatically at 15,000 ft. Again I had no assurance the automatic-opening function would work. I couldn’t ascertain my altitude because I still couldn’t see through the iced-up face plate. There was no way to know how long I had been blacked-out or how far I had fallen. I felt for the manual-activation D-ring on my chute harness, but with the suit inflated and my hands numbed by cold, I couldn’t locate it. I decided I’d better open the face plate, try to estimate my height above the ground, then locate that “D” ring. Just as I reached for the face plate, I felt the reassuring sudden deceleration of main-chute deployment. I raised the frozen face plate and discovered its uplatch was broken. Using one hand to hold that plate up, I saw I was descending through a clear, winter sky with unlimited visibility. I was greatly relieved to see Jim’s parachute coming down about a quarter of a mile away. I didn’t think either of us could have survived the aircraft’s breakup, so seeing Jim had also escaped lifted my spirits incredibly.
I could also see burning wreckage on the ground a few miles from where we would land. The terrain didn’t look at all inviting–a desolate, high plateau dotted with patches of snow and no signs of habitation. I tried to rotate the parachute and look in other directions. But with one hand devoted to keeping the face plate up and both hands numb from high-altitude, subfreezing temperatures, I couldn’t manipulate the risers enough to turn. Before the breakup, we’d started a turn in the New Mexico-Colorado-Oklahoma-Texas border region. The SR-71 had a turning radius of about 100 mi. at that speed and altitude, so I wasn’t even sure what state we were going to land in. But, because it was about 3:00 p.m., I was certain we would be spending the night out here.
At about 300 ft. above the ground, I yanked the seat kit’s release handle and made sure it was still tied to me by a long lanyard. Releasing the heavy kit ensured I wouldn’t land with it attached to my derriere, which could break a leg or cause other injuries. I then tried to recall what survival items were in that kit, as well as techniques I had been taught in survival training.
Looking down, I was startled to see a fairly large animal–perhaps an antelope–directly under me. Evidently, it was just as startled as I was because it literally took off in a cloud of dust.
My first-ever parachute landing was pretty smooth. I landed on fairly soft ground, managing to avoid rocks, cacti and antelopes. My chute was still billowing in the wind, though. I struggled to collapse it with one hand, holding the still-frozen face plate up with the other.
“Can I help you?” a voice said. Was I hearing things? I must be hallucinating. Then I looked up and saw a guy walking toward me, wearing a cowboy hat. A helicopter was idling a short distance behind him. If I had been at Edwards and told the search-and-rescue unit that I was going to bail out over the Rogers Dry Lake at a particular time of day, a crew couldn’t have gotten to me as fast as that cowboy-pilot had.
The gentleman was Albert Mitchell, Jr., owner of a huge cattle ranch in northeastern New Mexico. I had landed about 1.5 mi. from his ranch house–and from a hangar for his two-place Hughes helicopter. Amazed to see him, I replied I was having a little trouble with my chute. He walked over and collapsed the canopy, anchoring it with several rocks. He had seen Jim and me floating down and had radioed the New Mexico Highway Patrol, the Air Force and the nearest hospital.
Extracting myself from the parachute harness, I discovered the source of those flapping-strap noises heard on the way down. My seat belt and shoulder harness were still draped around me, attached and latched. The lap belt had been shredded on each side of my hips, where the straps had fed through knurled adjustment rollers. The shoulder harness had shredded in a similar manner across my back. The ejection seat had never left the airplane; I had been ripped out of it by the extreme forces, seat belt and shoulder harness still fastened.
I also noted that one of the two lines that supplied oxygen to my pressure suit had come loose, and the other was barely hanging on. If that second line had become detached at high altitude, the deflated pressure suit wouldn t have provided any protection. I knew an oxygen supply was critical for breathing and suit-pressurization, but didn’t appreciate how much physical protection an inflated pressure suit could provide. That the suit could withstand forces sufficient to disintegrate an airplane and shred heavy nylon seat belts, yet leave me with only a few bruises and minor whiplash was impressive. I truly appreciated having my own little escape capsule. After helping me with the chute, Mitchell said he’d check on Jim. He climbed into his helicopter, flew a short distance away and returned about 10 min. later with devastating news: Jim was dead. Apparently, he had suffered a broken neck during the aircraft’s disintegration and was killed instantly. Mitchell said his ranch foreman would soon arrive to watch over Jim’s body until the authorities arrived.
I asked to see Jim and, after verifying there was nothing more that could be done, agreed to let Mitchell fly me to the Tucumcari hospital, about 60 mi. to the south.
I have vivid memories of that helicopter flight, as well. I didn’t know much about rotorcraft, but I knew a lot about “red lines,” and Mitchell kept the airspeed at or above red line all the way. The little helicopter vibrated and shook a lot more than I thought it should have. I tried to reassure the cowboy-pilot I was feeling OK; there was no need to rush. But since he’d notified the hospital staff that we were inbound, he insisted we get there as soon as possible. I couldn’t help but think how ironic it would be to have survived one disaster only to be done in by the helicopter that had come to my rescue.
However, we made it to the hospital safely–and quickly. Soon, I was able to contact Lockheed’s flight test office at Edwards. The test team there had been notified initially about the loss of radio and radar contact, then told the aircraft had been lost. They also knew what our flight conditions had been at the time, and assumed no one could have survived. I briefly explained what had happened, describing in fairly accurate detail the flight conditions prior to breakup.
The next day, our flight profile was duplicated on the SR-71 flight simulator at Beale AFB, Calif. The outcome was identical. Steps were immediately taken to prevent a recurrence of our accident. Testing at a CG aft of normal limits was discontinued, and trim-drag issues were subsequently resolved via aerodynamic means. The inlet control system was continuously improved and, with subsequent development of the Digital Automatic Flight and Inlet Control System, inlet unstarts became rare. Investigation of our accident revealed that the nose section of the aircraft had broken off aft of the rear cockpit and crashed about 10 mi. from the main wreckage. Parts were scattered over an area approximately 15 mi. long and 10 mi. wide. Extremely high air loads and g-forces, both positive and negative, had literally ripped Jim and me from the airplane. Unbelievably good luck is the only explanation for my escaping relatively unscathed from that disintegrating aircraft.
Two weeks after the accident, I was back in an SR-71, flying the first sortie on a brand-new bird at Lockheed’s Palmdale, Calif., assembly and test facility. It was my first flight since the accident, so a flight test engineer in the back seat was probably a little apprehensive about my state of mind and confidence. As we roared down the runway and lifted off, I heard an anxious voice over the intercom. “Bill! Bill! Are you there?”
“Yeah, George. What’s the matter?”
“Thank God! I thought you might have left.” The rear cockpit of the SR-71 has no forward visibility–only a small window on each side–and George couldn’t see me. A big red light on the master-warning panel in the rear cockpit had illuminated just as we rotated, stating, “Pilot Ejected.” Fortunately, the cause was a misadjusted microswitch, not my departure.
Zeb
Total ratings: 52
Report this Post Click Here to See the Profile for ZebSend a Private Message to ZebEdit/Delete MessageReply w/QuoteDirect Link to This Post
The SR-71 just seems to generate great stories.
I was flying the SR-71 out of RAF Mildenhall, England, with my back-seater, Walt Watson; we were returning from a mission over Europe and the Iron Curtain when we received a radio transmission from home base. As we scooted across Denmark in three minutes, we learned that a small RAF base in the English countryside had requested an SR-71 fly-past. The air cadet commander there was a former Blackbird pilot, and thought it would be a motivating moment for the young lads to see the mighty SR-71 perform a low approach. No problem, we were happy to do it. After a quick aerial refuelling over the North Sea, we proceeded to find the small airfield.
Walter had a myriad of sophisticated navigation equipment in the back seat, and began to vector me toward the field. Descending to subsonic speeds, we found ourselves over a densely wooded area in a slight haze. Like most former WWII British airfields, the one we were looking for had a small tower and little surrounding infrastructure. Walter told me we were close and that I should be able to see the field, but I saw nothing. Nothing but trees as far as I could see in the haze. We got a little lower, and I pulled the throttles back from 325 knots we were at. With the gear up, anything under 275 was just uncomfortable. Walt said we were practically over the field-yet; there was nothing in my windscreen. I banked the jet and started a gentle circling maneuver in hopes of picking up anything that looked like a field. Meanwhile, below, the cadet commander had taken the cadets up on the catwalk of the tower in order to get a prime view of the fly-past. It was a quiet, still day with no wind and partial gray overcast. Walter continued to give me indications that the field should be below us but in the overcast and haze, I couldn’t see it. The longer we continued to peer out the window and circle, the slower we got. With our power back, the awaiting cadets heard nothing. I must have had good instructors in my flying career, as something told me I better cross-check the gauges. As I noticed the airspeed indicator slide below 160 knots, my heart stopped and my adrenalin-filled left hand pushed two throttles full forward. At this point we weren’t really flying, but were falling in a slight bank. Just at the moment that both afterburners lit with a thunderous roar of flame (and what a joyous feeling that was) the aircraft fell into full view of the shocked observers on the tower. Shattering the still quiet of that morning, they now had 107 feet of fire-breathing titanium in their face as the plane levelled and accelerated, in full burner, on the tower side of the infield, closer than expected, maintaining what could only be described as some sort of ultimate knife-edge pass.
Quickly reaching the field boundary, we proceeded back to Mildenhall without incident. We didn’t say a word for those next 14 minutes. After landing, our commander greeted us, and we were both certain he was reaching for our wings. Instead, he heartily shook our hands and said the commander had told him it was the greatest SR-71 fly-past he had ever seen, especially how we had surprised them with such a precise maneuver that could only be described as breathtaking. He said that some of the cadet’s hats were blown off and the sight of the plan form of the plane in full afterburner dropping right in front of them was unbelievable. Walt and I both understood the concept of ‘breathtaking’ very well that morning and sheepishly replied that they were just excited to see our low approach.
As we retired to the equipment room to change from space suits to flight suits, we just sat there-we hadn’t spoken a word since ‘the pass.’ Finally, Walter looked at me and said, ‘One hundred fifty-six knots. What did you see?’ Trying to find my voice, I stammered, ‘One hundred fifty-two.’ We sat in silence for a moment. Then Walt said, ‘Don’t ever do that to me again!’ And I never did.
A year later, Walter and I were having lunch in the Mildenhall Officer’s club, and overheard an officer talking to some cadets about an SR-71 fly-past that he had seen one day. Of course, by now the story included kids falling off the tower and screaming as the heat of the jet singed their eyebrows. Noticing our HABU patches, as we stood there with lunch trays in our hands, he asked us to verify to the cadets that such a thing had occurred. Walt just shook his head and said, ‘It was probably just a routine low approach; they’re pretty impressive in that plane.’
Impressive indeed.”
Total ratings: 436
Report this Post Click Here to See the Profile for maryjaneSend a Private Message to maryjaneEdit/Delete MessageReply w/QuoteDirect Link to This Post
Things I see every week here as everything from Blackhawks, Cobras, Chinooks, C130s, C-17s and more routinely make practice approaches to the Ft Hood Robert Gray Army airfield.
Valkrie9
Report this Post Click Here to See the Profile for Valkrie9Send a Private Message to Valkrie9Edit/Delete MessageReply w/QuoteDirect Link to This Post
_
[This message has been edited by Valkrie9 (edited 09-17-2026).]
Valkrie9
_
_
_
_
Ary Glantz - Long-EZ builder
_
jslade Cozy MK IV
Aircraft Spruce and Specialty
_So I watched it on Utoob..
I think that Cozy 4 is a Cool Plane !
Yep !
_
_
So,
a Cozy 4 sized Berkut with an Automotive Engine, Constant Speed Prop + Reduction Gearset.
Not inexpensive, nor easy, more complexity, more redundant systems.
Ballistic parachutes, Inflatable floatation sponsons.
_
_
[This message has been edited by Valkrie9 (edited 10-28-2026).]
Valkrie9
Valkrie9
Personal Flight, Commuter Convenience.
[This message has been edited by Valkrie9 (edited 06-25-2026).]
Valkrie9
_
_
_
Yeah, this is the coolest plane, built in the '40s, some kind of an achievement.
Brilliant !
Someone should design a 150 % scale replica, to carry heavier payloads.
Carbon/Kevlar composite construction twin aluminum engines.
Planes of Fame Museum | Chino, California.
Valkrie9
Valkrie9
cvxjet
I have played guitar since I was 7 years old....never was very good, but early (Approx' age 11-12) I could play "Leaving on a Jet Plane" and "Proud Mary". After I was discharged from the Navy, I started working at NADEP Alameda repairing aircraft (S-3 and A-6) My father worked there for (Basically) his whole career... I was reading Air Progress magazine at a very early age, and have been "Plane crazy" always.
In 1982, I found a guitar that I really liked- some similarities to Brian May's guitar (He and his father built his guitar- has been MRI'd and X-rayed to find out why it sounds like it does) The guitar I bought was an Ovation Preacher....Ovation is famous for building ACOUSTIC guitars that are plastic-backed, but after much success selling them, Ovation wanted to expand into the solid-body ELECTRIC guitar market; Because they were starting out (In solid-body) they were building extremely high-quality guitars but selling them at a lower price...I did not realize I had bought such a good guitar until around 2010, when I was looking it up on the internet- Two sites showed it getting revues as high as the best guitars (I was shocked!)
I want to make clear that two of my biggest interests were >Playing guitar< and airplanes....So, what could possibly be a >>Connection<< between these two interests?
The Ovation guitar company is owned/run by Kaman music company...Kaman was started by Charles Kaman....He had earlier started Kaman Aircraft which built several important helicopters....And he started using composites for the rotor blades on Kaman helicopters.
Being a guitarist, he decided to try building a guitar using those same composites....this was very successful, so he then started selling composite-backed guitars thru his new company, Ovation guitars.
I was amazed to find out that my guitar has a link to my aviation addiction....
[This message has been edited by cvxjet (edited 07-19-2026).]
Valkrie9
[ Marine Pilot Found on Rural Washington State Road After Ejecting from his F/A-18. ]
Rare to get footage, fluke, like.
Probably useful at the inquiry.
Yeah..
Total ratings: 436
An expensive Lawn dart
Total ratings: 202
Report this Post Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Valkrie9:
_
I had a model of one of these when I was a kid! I had no idea what it was, but it looked awesome. I never painted it... but it came in basic gray anyway.
Valkrie9
Meanwhile,
deep underground in huge man-made caverns,
the 21st century version of the XB-70 is being fabricated by robotic laminators, applying aramid fibers in ceramic geopolymer matrixs, impervious to the heat of air friction at low altitude M5 velocity !
steve308
Total ratings: 58
Report this Post Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
This bad boy..
Valkrie9
[ PaperHobby ]
[This message has been edited by Valkrie9 (edited 09-28-2026).]
Valkrie9
Why the Avro Arrow was cancelled, maybe.
Notorio
Report this Post Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
When my 'ship comes in' I'd like to trade it in for one of these: Lockheed Electra 10E
Notorio
And if there's enough money left over, a Grumman Widgeon too
Valkrie9
Unobtainium...
_
Amphibians are cool planes.
[ Volmer VJ-22 Sportsman T+G Auckland Harbour, New Zealand ]
_
[ Thurston Teal ]
_
[ Lake Buccaneer ]
_
[ Six Amphibious Planes You Could Build in Your Garage ]
[ Pima Air and Space Museum ]
Pereira Osprey II, a beautiful design.
[This message has been edited by Valkrie9 (edited 11-15-2026).]
PFF Merchandise | Fiero Gallery | Fiero Headlight Control Module
