  Totally O/T
  tips on how to split 6in dia PVC pipe (Page 2)
tips on how to split 6in dia PVC pipe by maryjane
Started on: 07-14-2017 10:00 AM
Replies: 50 (650 views)
Last post by: texasfiero on 07-17-2017 04:34 PM
cliffw
Total ratings: 292
Report this Post07-16-2017 12:14 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
... Chuck Norris is from Oklahoma...
He has a ranch in Navasota Texas.
Walker, TEXAS Ranger, .
cliffw
Total ratings: 292
Report this Post07-16-2017 08:21 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
cliffw
Member since Jun 2003
... a sawmill would charge me more than it's worth to me, assuming they would even do it. They push the logs thru the cut path with some 'grippers'--you'll sometimes see the marks the grippers leave in the finished boards. I doubt they want their chips contaminated with plastic either--they sell them to companies that make mdf and other composite 'wood' products).
Ah, I see, your bovine will be triggered by gripper marks, .
Think about it Don, ... some PVC ships in mdf products, is that a bad idea or a very good one ?
LitebulbwithaFiero
Report this Post07-16-2017 08:29 AM Click Here to See the Profile for LitebulbwithaFieroSend a Private Message to LitebulbwithaFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Chainsaw it is then, but Chuck Norris is from Oklahoma...
If you do it with a chainsaw, just make sure you have the pipe secured some how. No need for you getting into a bad situation.
And it matters not where Norris is from, but the way the Texans try to live up to his likeness
RayOtton
Total ratings: 54
Report this Post07-16-2017 08:34 AM Click Here to See the Profile for RayOttonSend a Private Message to RayOttonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, good we have a solution.
Now would a certain somebody FIX THE DAMN PICTURE that's causing the sidescrolling thing.
Again.
Unless of course you MEANT to do that, just for me.
cliffw
Total ratings: 292
Report this Post07-16-2017 09:05 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
You from Michigan can think that but ... think about it ... why did Chuck Norris decide to be a Texas Ranger, ? You might enjoy reading about the history of the Texas Rangers.
cliffw
Total ratings: 292
Report this Post07-16-2017 09:07 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
cliffw
... just make sure you have the pipe secured some how.
Can't do that. It might leave gripper marks and trigger a stampede. Umm, protest.
sardonyx247
Total ratings: 219
Report this Post07-16-2017 09:13 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Chuck Norris only has to tell the pipe to split, and it will.
Report this Post07-17-2017 11:58 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, I do have a lot of it laying around and need to use it as a bumper of sorts in a long alleyway inside my cattle pen. It would be hard to describe unless one is familiar with cattle handling facilities. It's going to take some abuse from the cows, but it's either this or cut up a bunch of my pen and rebuild it.
I see, something like cow-pinball then
Keel
Report this Post07-17-2017 02:41 PM Click Here to See the Profile for KeelSend a Private Message to KeelEdit/Delete MessageReply w/QuoteDirect Link to This Post
v-notched cradle and a band saw.. and just feed..
Gary W
Report this Post07-17-2017 03:46 PM Click Here to See the Profile for Gary WSend a Private Message to Gary WEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you do use a circular saw, try a fine-toothed blade - backwards. Did a bunch of PVC sheeting that way, and it's a lot less likely to chip and rip the saw out of your hand. Same with a table saw. Flip the blade.
texasfiero
Total ratings: 82
Report this Post07-17-2017 04:34 PM Click Here to See the Profile for texasfieroSend a Private Message to texasfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
What Gary W said....
