  The Mall
  WTB: V6 tach
WTB: V6 tach by sdgdf
Started on: 09-15-2023 02:38 AM
Replies: 11 (159 views)
Last post by: Cliff Pennock on 09-18-2023 09:32 AM
sdgdf
Report this Post09-15-2023 02:38 AM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need a V6 tach. Not something off ebay, one that actually came from a car. May buy entire cluster if that's all you'll sell.
thefierofarm.com
Report this Post09-15-2023 09:58 AM Click Here to See the Profile for thefierofarm.comClick Here to visit thefierofarm.com's HomePageSend a Private Message to thefierofarm.comEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you need the 85 or the 86-88? I likely have either one. Send me a pm if you are still looiking.
That Todd Guy
steve308
Total ratings: 59
Report this Post09-15-2023 02:43 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Tach boards are availabe on e-bay. Easy to swap in.
richard in nc
Report this Post09-15-2023 05:52 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats good to know.mines way off.
sdgdf
Report this Post09-15-2023 05:52 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah but I've bought 2 and it hasn't solved my problem. My mechanic friend says at this point its the little motor on the tach dial or something wrong with my tach signal. Right now its probably easier/cheaper for me to swap the entire tach than mess with the other theory which seems to indicate my icm is bad? Car has a 3800SC so it doesn't have a tach filter or something.
sdgdf
Report this Post09-15-2023 05:54 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
sdgdf
Member since Sep 2012
86-88, not the horizontal looking one from 85.
PhatMax
Report this Post09-16-2023 07:04 PM Click Here to See the Profile for PhatMaxSend a Private Message to PhatMaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you change the tach filter ? By the dist…
steve308
Total ratings: 59
Report this Post09-16-2023 09:52 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
You might have mentioned the engine swap in your original post. 3800sc guys should be able to help.
Vintage-Nut
Report this Post09-16-2023 10:00 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Different Vehicle / Similar Issue
My '92 Honda Speedometer had issues, I found tiny pins and their contacts from the PCB to the motor was the problem.
By cleaning these pins/contacts solved the issue.
I don't know if this will fix your tach, but these 'tiny' contacts in my speedometer was the problem...
Original Owner of a '88 GT and under 'Production Refurbishment'
sdgdf
Report this Post09-17-2023 05:35 PM Click Here to See the Profile for sdgdfSend a Private Message to sdgdfEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah I kept pressing on the board and it makes good contact with the pins. My problem is either heavy throttle or high rpm makes my tach go to 0. That and my tach is inaccurate at higher rpm, I adjusted the screw on the board so idle is correct but it reads way high otherwise. I've tried 3 tach boards. Makes me wonder if the icm is bad on the 3800sc. I'm using the analog tach signal from it. The digital signal in the pcm is accurate, is there a kit/writeup on how to wire my tach up with that?
[This message has been edited by sdgdf (edited 09-17-2023).]
Vintage-Nut
Report this Post09-17-2023 06:19 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're sure that the issue is the tach.....
Maybe 'J Gunsett' can fix it!
Who rebuilds tachs? by longjonsilver
https://www.fiero.nl/forum/Forum1/HTML/099762.html
Cliff Pennock
Administrator
Total ratings: 699
Report this Post09-18-2023 09:32 AM Click Here to See the Profile for Cliff PennockClick Here to visit Cliff Pennock's HomePageSend a Private Message to Cliff PennockEdit/Delete MessageReply w/QuoteDirect Link to This Post
This. If you are using the wrong tach filter (from the L4) then your tach will be way of.
