  4T60 conversion for a 3.4
4T60 conversion for a 3.4 by fierobear
Started on: 10-22-2025 01:46 PM
Replies: 15 (165 views)
Last post by: Dennis LaGrua on 10-29-2025 07:52 PM
fierobear
Total ratings: 382
Report this Post10-22-2025 01:46 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
My pushrod/iron head 3.4 has been mated up with a TH-125 and it is failing. I've been wanting to change to a 4 speed auto, especially because the RPM at freeway speed is 3,800. I'm told a 3.33 final drive ratio is the best for this application. I also need to know how you adapt the shifter to the 4 speed. Opinions, advice?
Report this Post10-22-2025 03:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No adaptation of the Fiero auto shifter is needed.
The detents for transmission range are built in to the transmission select shaft.
You will need to modify the length of the transmission select shaft arm, off the top of my head I don't remember the length needed.
hercimer01
Report this Post10-22-2025 05:40 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
richard in nc
Report this Post10-22-2025 07:19 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierobear
Total ratings: 382
Report this Post10-22-2025 09:29 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by hercimer01:
I did that swap in my eighty eight formula.Look at my link.
That was for an "E" transmission?
Report this Post10-23-2025 07:01 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
All of the respondents in this thread have used the 4T60.
Not the E version, which does not use a throttle valve cable.
Total ratings: 200
Report this Post10-23-2025 07:44 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is an old website that I used to maintain, but I have gearing information for the 4T60 here: https://www.pontiacperforma...icles/4T60_Info.html
And instructions and pictures how to adapt it to an 84-87 and 88 here: https://www.pontiacperforma...es/4_Speed_Swap.html
88 requires slight modification to the subframe, but for the 84-87, you just drill a hole to move a bolt.
fierobear
Total ratings: 382
Report this Post10-23-2025 11:52 AM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent information, VERY helpful. Thanks!
hercimer01
Report this Post10-23-2025 10:17 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
No. Where do you see "E"?
fierobear
Total ratings: 382
Report this Post10-25-2025 03:57 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some of the write up in the other thread seemed like there were issues that would come with an E transaxle.
Report this Post10-25-2025 04:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero ECU will not be able to control the 'E' version, as it is electronically controlled by a drivetrain computer such as an OBD1.5 ECU or and OBD2 PCM.
hercimer01
Report this Post10-25-2025 10:16 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Right, the TH440 (4t60) is a stand alone hydraulic shift automatic 4 speed trans. I could do 75mph at 2,300 rpm.
fierobear
Total ratings: 382
Report this Post10-27-2025 03:49 PM Click Here to See the Profile for fierobearSend a Private Message to fierobearEdit/Delete MessageReply w/QuoteDirect Link to This Post
THAT is a major reason I need a 4 speed. The damned 3 speed is doing 3,800 RPM on the Interstate at 80.
Noted on the E trans, what I figured. Don't need it anyway, no plans for paddle shift or anything fancy.
Report this Post10-29-2025 02:53 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
We did the 4T60 swap way back when and don't recall much except that it was an easy bolt in with a change of trans mounts, a new torque converter a couple of small wiring changes. Don't recall if the shift lever on the trans needed to be reversed so let me look at my old notes and post more info here later. My suggestion would be to use a rebuilt unit not a junkyard unit.
[This message has been edited by Dennis LaGrua (edited 10-29-2025).]
richard in nc
Report this Post10-29-2025 06:51 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
why did you change the converter?
Report this Post10-29-2025 07:52 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
82 TA has it right, You will need the transmission, new transmission mounts, the 4T60 torque converter w bolts, new std GM 4T60 transmission mounts, a new bracket for the shifter cable, a simple mod for the trans shifter arm and a rewire of the TC lock up solenoid. New trans cooler hoses are recommended.
Allow about a day to pull the powertrain to get it all installed.
