  Help with HIGH IDLE
Help with HIGH IDLE by etoangel
Started on: 03-28-2025 10:35 AM
Replies: 6 (109 views)
Last post by: etoangel on 03-29-2025 04:45 PM
etoangel
Report this Post03-28-2025 10:35 AM Click Here to See the Profile for etoangelSend a Private Message to etoangelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey y’all, just got a fiero (1984 2m4) and love it, drove it for 150 miles no problem but then it randomly shut off while I was driving and I had to push it into a parking lot. it still turned over and the tachometer reflects engine turn over but the oil temp gauge is pinnned to the highest temp. I dug around and I thought oil sensor might be the culprit went to fix it and then it worked. Now I have another issue to tackle: the high idle. At first I thought it was a Idle control valve issue so I bought a replacement and it did nothing. I pulled the icv and plugged the hole and idle was still super high so that tells me I have a huge vaccum leak. So I replaced all of the vaccum lines with new ones and there's still a crazy high idle (2500 rpms). I put the car in diagnostic mode and it appears that the ecm is not communicating with the icv properly because I don't hear any clicking and trying to re-teach the idle did nothing. I have a replacement MAP coming in (I don't think anything is wrong with this one but the part is cheap enough that it's not hard to replace) and I also have a PCV valve coming in because mine crapped the bed (and its a 2 dollar part).
Does anyone know of any other ways of checking if the ecm is communicating properly with the ICV? and/or checking if the ICV is working?
Should I just say F it and stick a plug in the icv valve and drive it that way? I really don't wanna mess up my transmission by slam-fking it into gear when it's at 1000 rpms.
Car info:
100k miles on the dot. not molested in any way (that I know of) Fuel is good and clean Oil is good full and clean Engine temp is fine and was the whole time I was driving.
Idles high when not in gear. Doesn’t really effect drivability, just annoying.
Wasn’t blowing hot air from climate control.
Any and all help is appreciated. I just wanna get back on the road. 😊
[This message has been edited by etoangel (edited 03-28-2025).]
Total ratings: 465
Report this Post03-28-2025 02:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by etoangel:
...the oil temp gauge is pinnned to the highest temp.
Oil temp gauge? Is this something aftermarket... or do you actually mean the oil pressure gauge?
Probably just a poor electrical contact then.
What hole exactly did you plug?
Is there a functional 195° thermostat installed?
What temperature is the CTS reporting to the ECU? (Not what the temperature gauge might be indicating.)
etoangel
Report this Post03-28-2025 03:27 PM Click Here to See the Profile for etoangelSend a Private Message to etoangelEdit/Delete MessageReply w/QuoteDirect Link to This Post
The IAC hole
I am not sure if the thermostat is functioning properly
Do you know how I can check this? ECM doesn't currently have any codes.
Total ratings: 465
Report this Post03-28-2025 04:05 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Plugging the same hole you removed the IAC valve from accomplishes nothing.
This recent thread will probably answer all of your questions - 2.5L high idle
steve308
Total ratings: 59
Report this Post03-28-2025 08:41 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you happen to pull / check for codes? If no, it could save you a lot of guessing.
etoangel
Report this Post03-28-2025 08:47 PM Click Here to See the Profile for etoangelSend a Private Message to etoangelEdit/Delete MessageReply w/QuoteDirect Link to This Post
No codes last I checked. After installing the new thermostat tomorrow I will try to pull some codes again.
etoangel
Report this Post03-29-2025 04:45 PM Click Here to See the Profile for etoangelSend a Private Message to etoangelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update, apparently there was no thermostat installed before. I installed a new one and a new PCV valve. The engine finally heats up past 100 but now if I sit and let the car idle (which the car still idles at around 2500 RPM) after about a minute, I get a check engine light. Gonna check what the check engine light is for and will update.
