  Stripped T50 screw.
Stripped T50 screw. by kjelle69
Started on: 01-19-2025 12:09 PM
Replies: 18 (273 views)
Last post by: cliffw on 01-21-2025 12:24 PM
kjelle69
Report this Post01-19-2025 12:09 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any creative idéas of how to get it out ?
Report this Post01-19-2025 12:17 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are several ways to get that bolt out. You can weld another bolt to it and use a wrench on the new hex bolt head but if you have no welder; a small Stilson wrench or a small pair of vice grips may be able to remove it. A stud remover socket wrench may also work.
[This message has been edited by Dennis LaGrua (edited 01-19-2025).]
da.slyboy
Report this Post01-19-2025 12:19 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cutting or grinding off the head then weld a nut onto the stud when you pull the water pump off.
kjelle69
Report this Post01-19-2025 12:29 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was actually thinking of welding a nut to the head or take the T-50 bit and weld it to the screw.
Is there any things that could generate problems when welding on the engine? Sensors, ECM etc ?
[This message has been edited by kjelle69 (edited 01-19-2025).]
pmbrunelle
Total ratings: 63
Report this Post01-19-2025 01:08 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to use some common sense, but in general you won’t create problems welding on the engine if you imagine the path of the current and avoid having the current pass through bearings or things like that.
I think that grounding to the engine block, timing chain cover, or gearbox casing could all be good choices.
da.slyboy
Report this Post01-19-2025 01:17 PM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
That could work if the bolt isn’t too stuck. You may lose some of the heat transfer from the stud to the threads, which is useful for breaking free stuck bolts. As long as the battery is disconnected, I’ve never had issues with welding on the engine block.
Report this Post01-19-2025 01:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you decide to weld a part on the engine I would disconnect the battery cable and run a chain placed on the ground cable to the floor We've welded exhaust systems and brackets while everything was connected without any problems but in theory electronic pulses under certain rare conditions have the potential to damage the ECM .
Mike in Sydney
Report this Post01-19-2025 04:49 PM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
DIsconnect the battery and unplug the ECM to be safe.
Vintage-Nut
Report this Post01-19-2025 05:07 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lisle Tools: Stuck Bolt and Stud Remover {Available Individually or a Set}
"Drive the proper size remover over the bolt head, nut or stud. The remover spline cuts into the bolt head or threads for a sure grip."
https://www.lislecorp.com/s...and-stud-remover-set
[This message has been edited by Vintage-Nut (edited 01-19-2025).]
richard in nc
Report this Post01-19-2025 07:17 PM Click Here to See the Profile for richard in ncSend a Private Message to richard in ncEdit/Delete MessageReply w/QuoteDirect Link to This Post
id try vise grips first.it looks like theres something there to grab.or the right sized easy out.
sleek fiero
Report this Post01-19-2025 09:44 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are my eyes deceiving me .That looks like the the screws that hold on the timing plate not the water pump or timing cover. sleek
kjelle69
Report this Post01-20-2025 02:54 AM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
No, it's the lowest bolt to the left, the one that's supposed to gp into the water jacket according to this image, number 4
kjelle69
Report this Post01-20-2025 02:57 AM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
kjelle69
Member since Feb 2004
I ordered a set of those. If that's not enough I'll weld.
Vintage-Nut
Report this Post01-20-2025 07:35 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI - Only ONE bolt needs sealant / #4
BTW - Rodney Sells Hex Head Flange Water Pump Bolts to Replace the Factory Torx Bolts: https://rodneydickman.com/p....php?products_id=414
And remember to hold the timing cover in place when removing the pump: https://rodneydickman.com/p....php?products_id=557
[This message has been edited by Vintage-Nut (edited 01-20-2025).]
Frenchrafe
Report this Post01-20-2025 08:59 AM Click Here to See the Profile for FrenchrafeSend a Private Message to FrenchrafeEdit/Delete MessageReply w/QuoteDirect Link to This Post
As others have said:
If you weld, then totally disconnect the battery. Put the welder earth cable connection on the engine block as close as possible to the bolt in question.
As long as the electronics are not charged up, then you shouldn't have any problems with the sensors.
"Turbo Slug" - '87 Fiero GT. 3800 turbo. - The fastest Fiero in France! @turboslugfiero
https://youtu.be/hUzOAeyWLfM
cliffw
Total ratings: 292
Report this Post01-20-2025 11:09 AM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Link ? What's it called ? I would like to add it to my collection of tools I never use, but want to have in case, .
Vintage-Nut
Report this Post01-20-2025 01:27 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
You want a link and a name? Well, you have two three links now!
BGS Technic Site: Screw Extractor Set 9170 | for damaged T-Star (for Torx) T10 - T55 | 11 pcs
https://www.bgstechnic.com/...chparam=9170&&order=
Smaller BGS Technic Set 5284
https://www.bgstechnic.com/...x-T10-T40-7-pcs.html
AMAZON: BGS 9170 | Screw Extractor Set | for damaged T-Star (for Torx) T10 - T55 | 11 pcs.
https://www.amazon.com/BGS-...T-Star/dp/B06Y4WLQ2Q
[This message has been edited by Vintage-Nut (edited 01-21-2025).]
Report this Post01-20-2025 05:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Moved to other thread.
[This message has been edited by Patrick (edited 01-20-2025).]
cliffw
Total ratings: 292
Report this Post01-21-2025 12:24 PM Click Here to See the Profile for cliffwSend a Private Message to cliffwEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Vintage-Nut:
You want a link and a name? Well, you have two links now!
You a good man. My compliments to your parents, and you.
