  Water Pump job continues.
Water Pump job continues. by kjelle69
Started on: 01-18-2025 02:36 PM
Replies: 12 (306 views)
Last post by: 82-T/A [At Work] on 01-27-2025 07:06 AM
kjelle69
Report this Post01-18-2025 02:36 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am making a timing cover clamp like the one that Rodney Dickman have in his shop.
So far so good, stay tuned :-D
Report this Post01-20-2025 10:04 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good but just remember to apply sealant to the bolt or bolts that go into the water jacket or you will have a leak. Also highly recommend that you tape a plastic garbage bag over the fiberglass in the engine compartment where you work near the water pump. If not you will get itchy.
Its also good to use new bolts (if the old ones came out rusty) when replacing the pump. You could probably get by with standard hex head bolts but be sure to torque to specifications.
Report this Post01-20-2025 05:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just one water pump bolt requires any sealant.
This is the self-explaining diagram that I use to remind myself which bolt it is.
reinhart
Report this Post01-24-2025 12:10 AM Click Here to See the Profile for reinhartSend a Private Message to reinhartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whenever I've bought a auto parts store rebuilt pump (your $20 special) they've always come with that timing cover clamp. TBH I don't think I ever used it but never had a problem. Maybe it's different in Sweden as to not coming with the clamp, but I imagine the parts come from the same place we get them here.
kjelle69
Report this Post01-24-2025 04:51 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
At last. Man that M8 Torx bolt was stuck and no room to work at all. A big pipe wrench did the job...
No clamp included, I made my own from some iron bars. Similar to Rodney Dickmans.
Next step, try to remove the plug from the old pump and remove the pipe from the new to be able to plug it and then cleaning of the gaskets.
Must get me some new screws to replace the torx ones.
[This message has been edited by kjelle69 (edited 01-24-2025).]
Vintage-Nut
Report this Post01-24-2025 05:21 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
BTW - Rodney Sells Hex Head Flange Water Pump Bolts to Replace the Factory Torx Bolts:
https://rodneydickman.com/p....php?products_id=414
[This message has been edited by Vintage-Nut (edited 01-24-2025).]
kjelle69
Report this Post01-25-2025 01:51 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
I managed to get the old plug from my old pump loose.
Now I am trying to remove the pipe from the new pump, anyone who has some suggestion in how to do this?
I have applied heat and much force but it wont budge at all.
kjelle69
Report this Post01-25-2025 02:20 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
kjelle69
Member since Feb 2004
Maybe...
[This message has been edited by kjelle69 (edited 01-25-2025).]
Vintage-Nut
Report this Post01-25-2025 02:38 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Normally the pipe has male threads into the pump; but I don't see the last threads on your pipe.
Perhaps *this* pipe doesn't have threads...soldered in?
[This message has been edited by Vintage-Nut (edited 01-25-2025).]
kjelle69
Report this Post01-25-2025 04:48 PM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's not soldered but seems like some kind oy glue, relatively hard. I feel that I give up and go for an end plug instead.
I found some reinforced silicone plugs 20mm that I ordered from ali.
Report this Post01-25-2025 05:34 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might be better off using this style of plug in the end of the pipe.
CLICK FOR FULL SIZE
kjelle69
Report this Post01-27-2025 06:26 AM Click Here to See the Profile for kjelle69Send a Private Message to kjelle69Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good idea, I'll think I will put both this and the reinforced end plug..
[QUOTE]Originally posted by Patrick:
Total ratings: 200
Report this Post01-27-2025 07:06 AM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
That'll definitely work... if you do that, that thing will NEVER leak. The pipe would burst at the welded seam before it managed to get anything out the end!
