  Vacuum leak?
Vacuum leak? by Wacko1Jacko12
Started on: 05-17-2024 08:00 PM
Replies: 10 (271 views)
Last post by: Jason88Notchie on 05-22-2024 01:42 PM
Wacko1Jacko12
Report this Post05-17-2024 08:00 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
I am having an issue where I will drive my car around for a while, and park somewhere. Come back and my car will start up and go up to 600RPM and then it will go down and die. I found out if I wait for about 30 minutes, I can start it up and it drives okay. Also, on my tachometer, sometimes it can be 0 RPMs in park (but engine is running) and sometimes it seems like it struggles to keep RPMs. Seems like on colder days my engine struggles to keep right amount of RPMs in the beginning but runs fine when driving more, and on hot days it seems worse I believe. I want to look at the codes but sadly I cannot even see them. Tried doing the paperclip test but the "check engine light" never even comes on to see the codes. Grant it I have a digital dash the owner put in previously and have no idea if he installed everything properly for it.
I also noticed on the back of my vehicle I have an air breather where a vacuum tube used to be on the back of the engine, could this be an issue? I hear a whistling sound somewhere and I believe it's just this.
Report this Post05-17-2024 08:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Considering the previous owner also monkeyed around with the breather system, there's no telling what all has been done to this car.
Did you ever get the PROM and MAT situations resolved?
Plug a scanner and/or a cable for WinALDL into the ALDL port and find out what's going on with this engine.
Wacko1Jacko12
Report this Post05-17-2024 08:34 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am ordering chip from sinister performance pretty soon (got in contact via email).
I wired up the MAT sensor and installed the original air intake canister (w/ its bracket, put a filter in there as well). Here are images of what I ended up doing for that:
I ordered a OBD1 scanner (comes with CD for drivers and cable) from Phonedawgz, should be here tomorrow or Monday.
I am not sure where in Tuner Pro you can see the codes however. I watched the videos he made about how to see real time values, but not sure where it says the codes?
Report this Post05-18-2024 01:57 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Vac leaks can cause 3 problems most times...
Leak is very small so ECM just adjust IAC to counter that but still has a vac leak & may affect other things.
Leak is Bigger to cause High Idle.
Leak is so Big Idle surfers or kill the engine. Example: Problem w/ brake booster vac line can do this but bad booster itself often does either of the above.
see https://web.archive.org/web...ierocave/vacleak.htm
cartercarbaficionado
Report this Post05-18-2024 02:35 AM Click Here to See the Profile for cartercarbaficionadoSend a Private Message to cartercarbaficionadoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi everyone,
test your icm and spray non flammable brake clean over the lines while running to find a vaccumm leak
my tach was bouncing around like yours due to a faulty icm and broken wiring to my tach filter
the whistling sound is not that breather since I have one on mine I installed a few days ago after my rubber intake boot split and I had to replace it, it is definitely a vacc leak or a broken intake gasket
Wacko1Jacko12
Report this Post05-18-2024 08:23 AM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you all for your suggestions, I sprayed around the vacuum lines and did not notice anything. However, I did find what appears to be where a vacuum line used to be and it is not even plugged up!
It was right under the throttle body. Should I just cap this off? I would rather understand where it went first and see if I need to reroute that line. Does anyone know where this vacuum line goes to? It also appears there is one capped off next to it as well.
Thank you for telling me about the brake booster, I had all my break lines and calipers rebuilt/checked. When I got it back from the shop the brake still felt spongy maybe that vacuum leak is a result or maybe its just the brake booster itself.
Report this Post05-18-2024 08:52 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
For now, just cap it off.
Report this Post05-18-2024 11:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hear a whistling sound somewhere...
I did find what appears to be where a vacuum line used to be and it is not even plugged up! It was right under the throttle body. Should I just cap this off? I would rather understand where it went first and see if I need to reroute that line. Does anyone know where this vacuum line goes to? It also appears there is one capped off next to it as well.
CLICK FOR FULL SIZE
No wonder you hear "a whistling sound".
The smaller of the two ports on the underside of the TB is supposed to be connected to the EGR solenoid. The larger port is supposed to be routed to the fuel vapor canister. Does your engine still have either? Whomever worked on this Fiero prior to you buying it shouldn't be allowed access to a toolbox.
[This message has been edited by Patrick (edited 05-18-2024).]
Wacko1Jacko12
Report this Post05-22-2024 12:39 PM Click Here to See the Profile for Wacko1Jacko12Send a Private Message to Wacko1Jacko12Edit/Delete MessageReply w/QuoteDirect Link to This Post
1. I ended up plugging it off and replacing the cap next to it (old one was deuterated). My engine does not have a fuel vapor canister and cruise control. I know I do not need the EVAP canister, but I would like it back in (I like things original).
2. I then started my car and could still hear a whistle noise but not as bad (somewhere else there's a leak I bet). I will take a look based off this diagram. Thank you for sending that!
3. I then used Tuner Pro RT to see some data, surprised I did not see anything about the EGR and no-fault codes at all (hope I am reading it correctly). If there was an alarm, does it say FAULTED near the code?
-Makes me believe whichever owner at the time actually properly deleted the EGR on the chip (SHOCKED!).
4. Based off this data, is there anything concerning? I am not sure what most of these values are supposed to be close to during idle.
[This message has been edited by Wacko1Jacko12 (edited 05-22-2024).]
Total ratings: 200
Report this Post05-22-2024 01:09 PM Click Here to See the Profile for 82-T/A [At Work]Send a Private Message to 82-T/A [At Work]Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hah... oh man...
Only other thing I'd add here is that if you can, I'd try to find an original air canister to throttle body connector. That dryer hose really isn't great. The factory (replacement) connector is much better and will give you the correct flow you need... it's also a more gradual transition from large to small.
Jason88Notchie
Report this Post05-22-2024 01:42 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
MAT=air temp in the intake
O2=voltage reading represents lean/rich. 200-800 millivolt is average range.
TPS=throttle position sensor. At lowest point around .5v at idle.
And about 4.5v WOT. (wide open throttle) .25v at idle looks to me too low. With JUST THE IGNITION on press throttle all the way to the floor. If less then 4ish, I suspect a faulty TPS sensor.
