You have DIS engine w/ miss fire?
Exactly what was replaced & what brand & part # for new part?
Clean/fix all ground bolted/screwed to anything in engine bay & coat w/ silicone or permatex green label brake grease.
PIM/ICM Must have the shield. If not coils will damage the PIM have problems or start a fire.
"Cheap" Copper core AC or Autolite works.
Warning: DIS
Hates some "high end sparkplugs."
But these "cheap" plugs can rust fast depending on driving conditions etc.
See
https://web.archive.org/web...~fierocave/gmdis.htmhttps://www.fiero.nl/forum/...HTML/146263.html#p10But seems autolite no longer make the "Double Platinum" APP666 & AC still list 41-816 @ $10 per plug @ most outlets.
When pulling any spark plugs...
Clean the hole before ever try using a wrench.
Turn them 1 turn max and clean again because you often loosen a lot more crap.
get some "canned air" if don't have any type of compressor to blow out trash and rust.
HD Lowes and sim often have it in cleaning or electric section.
