  Cooling temp gauge reading compared to sensor (Ohms)
Cooling temp gauge reading compared to sensor (Ohms) by J Gunsett
Started on: 04-20-2024 12:50 PM
Replies: 3 (235 views)
Last post by: Vintage-Nut on 04-23-2024 11:26 AM
J Gunsett
Report this Post04-20-2024 12:50 PM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Somewhere many years ago I found a chart "Temp vs. Resistance for GM Sensors". The chart call out for a temp of 260 degs is 75 ohms. In the 85 tech manual it states 260 degs is 55 ohms. Going to the other end the chart stares 100 degs is 1600 ohms and the tech manual states 1365. What is correct?
Jack
Report this Post04-22-2024 09:16 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most pages here & elsewhere post Ω value but many are Wrong for What goes with...
Is Only for ECM sensors. see https://web.archive.org/web...fierocave/ecmqrg.htm
Dash Temp Gauge have different sender Ω values even tho still NTC thermistor based.
But Dash Gauges often are "bad" from wiring problems...
see https://www.fiero.nl/forum/Forum2/HTML/146784.html Fuel, Engine Temp or Oil Pressure gauges have problems?
⚠️ Even after you check/fix gauge issues, Dash Temp Numbers mean very little. GM never bothered to calibrate that gauge.
J Gunsett
Report this Post04-23-2024 08:54 AM Click Here to See the Profile for J GunsettClick Here to visit J Gunsett's HomePageSend a Private Message to J GunsettEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks theore for the comment, all good information.
Jack
Vintage-Nut
Report this Post04-23-2024 11:26 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
J Gunsett
My Source:
https://www.fierofocus.com/fierosails/tempgage.htm
