Buddy, I was wondering about the black molding (as I know there's two styles)... but doesn't it come off the fenders? Or is it just the door skins it comes off of?
[EDIT] I did some research and found the following Here
Originally posted by mbramble:
The piece of molding on the front fender is held in place with two tin nuts on the backside of the fender. You must remove the fender to remove the molding.
So it would appear then that the black molding can be transferred from one fender to another.
[This message has been edited by Patrick (edited 04-18-2024).]
A few years ago (well, almost 15), I put a fender from a bumper-pad 85 or 86 onto my 88GT following a small fender-bender. I used my original aero piece from my car, and the lower aero skirt was from the Fiero Store. That bright red door is an '84, which actually IS different by the way (the top of the door skin attaches differently than the later years). Everything fit together perfectly.
I put a fender from a bumper-pad 85 or 86 onto my 88GT following a small fender-bender. I used my original aero piece from my car...
I'm curious... what modifications did you need to do to attach the aero piece at the bottom? Was it just a matter of drilling a couple of mounting holes? And except for the required holes, there was no other difference between the fenders where the aero piece attached?
I don't remember exactly, unfortunately. I do recall that the aero piece on the door was supposed to be riveted to the door panel, but instead of rivets, I used small stainless Allen bolts. I may have done the same for the aero piece that goes on the fender. Yes, I had to drill the holes. I do know that the lower edge of the fender is supposed to be riveted to the metal unibody, and the rocker panels (aero or otherwise) are supposed to be riveted also, and I used plastic rivets from Harbor Freight for that (actual plastic rivets, not push pins). Too bad I didn't snap any pictures but it was back in 2009.
I had a look at some Fiero front fenders I have here. I forgot to double-check how the black molding is attached , but it does appear that the bottom of the fender where the aero trim attaches is the same on all years/models (except for the holes required for mounting the aero trim).
