  A/C low and high pressure switch wire colors ?
A/C low and high pressure switch wire colors ? by Signupacct
Started on: 11-26-2023 10:21 PM
Replies: 9 (553 views)
Last post by: RWDPLZ on 11-28-2023 02:45 PM
Signupacct
Report this Post11-26-2023 10:21 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys
there are two wires going to the compressor for pressure switches, a low pressure switch and a high pressure switch. The two wires are different colors, one is black and the other is green with a white stripe. which goes to the high pressure switch and which colored wire goes to the low pressure switch.
I am retrofitting to a new four seasons compressor HR6 (new) and replacing with new switches but need to know which wire goes to each switch. Also I am putting in a new evaporator, dryer and condenser.
the following thread identifies them as colors I dont think I have. I have a dark green wire with a white stripe and a black wire. Is a dark green wire with a thin white sripe considered a lt. green color ? I would not think that would make sense.
ref: https://www.fiero.nl/forum/Forum2/HTML/139927.html
Joe k
P.S.: I did read the following post and was very helpful but I would like to confirm the color of the wires to each switch. ref: https://www.fiero.nl/forum/Forum2/HTML/129599.html
[This message has been edited by Signupacct (edited 11-26-2023).]
RWDPLZ
Total ratings: 306
Report this Post11-26-2023 11:08 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year and engine? Black wire is probably the one for the high pressure cut-out switch. You can verify this with a multimeter, check for continuity from the end of the black wire to one of the two sides of the clutch coil connector.
Signupacct
Report this Post11-27-2023 01:20 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a 1987 Pontiac Fiero GT with V6 engine
and again a Four Seasons HR6 new
see attached pics
there is a black cap connector on the end of a black wire and another that has a broken off piece of white plastic in it that is on a green wire with white stripe
RWDPLZ
Total ratings: 306
Report this Post11-27-2023 01:24 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
The black is the high pressure cut-out switch, and the green is the low pressure fan switch. You can see what the original switches look like here:
https://www.fiero.nl/forum/Forum2/HTML/117640.html
Signupacct
Report this Post11-27-2023 02:41 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
yes
First I want to commend you for your posts on this topic. I know it has helped a lot of people and has me immensely. You did really great work on it.
Do you know for certain that the black cap at the end of the black wire went on the red colored switch aka as high pressure switch. and that the green wire with the white stripe which has the broken white plastic inside attaches to the other switch with brass center and white plastic surround aka low pressure switch?
Aslo. I have seen in the postings that it might matter which switch goes in which receptacle in the back of the compressor and as the wiring may prefer one order over the other.
Thank you in advance for your help and patience.
[This message has been edited by Signupacct (edited 11-27-2023).]
Total ratings: 154
Report this Post11-27-2023 06:00 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It doesn't matter which port the switches are in. They read pressures off the same chamber inside the compressor. This info is courtesy of RWDPLZ in a response to me when I asked him the same question. I would also like to thank him for all the help and information he has provided.
RWDPLZ
Total ratings: 306
Report this Post11-27-2023 10:16 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you can tell on your old switches that the white one is broken, you can see the remnants of the stem around the terminal. The low pressure switch (which activates the fan when pressures get too high, if the fan somehow isn't already on) uses the same connector as the fan switch on V6 cars, that's the easiest way to remember. Plus the multimeter measurement I mentioned in the previous post.
RWDPLZ
Total ratings: 306
Report this Post11-27-2023 10:17 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
RWDPLZ
Member since May 2002
I had a whole thread with pictures of this, but it got nuked when the forum image server went down. Yes the switches can go in either port.
Signupacct
Report this Post11-28-2023 02:08 PM Click Here to See the Profile for SignupacctSend a Private Message to SignupacctEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI
I reached out to SMP whose A/C division is Four Seasons and confirmed everything there with the Product manager for the HR6 compressor lines and specifically the application to GM products including the Fiero. Yes the switches that are listed in the forum are correct. Also confirmed that the placement of the switches can be in either cavity as both are high pressure. They also confirmed as you guys have that the black wire goes to the blue or high pressure switch and the green wire with the white stripe goes to the purple switch or the low side.
Thank you all for the help. I would like to think that our forum is still a useful place to interact and share information and ideas, etc.
I found the folks at the Lewisville Texas location, 972 316-3100 to be extremely helpful, The offshore Four Seasons tech support group, not as much) particularly Rick the product manager. I got the impression that they welcome questions regarding their products. After learning about the considerable licensing effort to bring about the rear taillights, I have grown to appreciate any vendor going about the considerable task of providing replacement products to our Fiero community.
Also, RWDPLZ and others, are you sure the very thorough thread from RWDPLZ regarding A/C upgrade was lost to a server issue. I thought I ran into it in a search recently.
Joe k.
[This message has been edited by Signupacct (edited 11-28-2023).]
RWDPLZ
Total ratings: 306
Report this Post11-28-2023 02:45 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was able to restore most of the images in the parts list thread from images I had saved to my computer, but there are still some images you can see in the thread that are lost
https://www.fiero.nl/forum/Forum2/HTML/000652.html
