  proper pocedure for installing fuel pump so gauge is working
proper pocedure for installing fuel pump so gauge is working by Wayne Renninger
Started on: 11-07-2023 07:31 PM
Replies: 7 (301 views)
Last post by: fieroguru on 11-09-2023 06:59 AM
Wayne Renninger
Report this Post11-07-2023 07:31 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
This week I nstalled 2 fuel pumps, 1 4cyl and 1 v6 both gauges read totally straight past full. I tested both for fuel pumps working but did not check gauges. What did I do wrong? Is there a procedure to follow to assure gauge works before reinstalling the tank?
Report this Post11-08-2023 10:13 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
@ C502 on "firewall..." Unplug, car side, short pink & black wires. Should = Empty on gauge.
more see https://www.fiero.nl/forum/Forum2/HTML/146784.html resistor test
Do Not short tan, tan/white, there to anything or will blow fuse for the pump. Check power w/ test light or meter to the black wire.
[This message has been edited by theogre (edited 11-08-2023).]
Wayne Renninger
Report this Post11-08-2023 05:41 PM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
Both gauges worked before I changed pumps, I'm just asking what could I have done wrong with installation?
Total ratings: 465
Report this Post11-08-2023 06:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you'd give us the courtesy of responding to earlier suggestions in your previous threads, such as Here, we might better be able to advise you.
[This message has been edited by Patrick (edited 11-08-2023).]
buddycraigg
Total ratings: 478
Report this Post11-09-2023 12:05 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're kinda a prick sometimes.
But I like your humor for the most part.
Report this Post11-09-2023 12:25 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Doesn't matter if work before.
Test gauges to see if they still work w/o sender & wire to that.
Total ratings: 465
Report this Post11-09-2023 02:01 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Only "sometimes"? I'll take that as a compliment!
Total ratings: 260
Report this Post11-09-2023 06:59 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you drain the tank completely when you change the fuel pump, then you can use a multimeter on the tank connector and check the sender to make sure it goes between 0 and 90 ohms. Test this with the tank right side up (to simulate the empty condition), and then test it again with the tank up side down (to simulate the full condition). This also identifies the stuck float condition.
Once you do this, then you know the sender works and the wiring to the connector is good. Then if it does not work in the car, then it is from the connector to the cluster. SInce it works on ohms and needs to see zero, then grounds are critical. The plastic film with all the electrical traces is flakey at best. If the connectors to it have been off, then check to make sure all the copper fingers into that connector cavity are straight. It is quite common for them to move around upon disassembly and cause issues on reassembly.
