  1984 dew wipes
1984 dew wipes by Wayne Renninger
Started on: 08-11-2023 10:58 AM
Replies: 6 (369 views)
Last post by: buddycraigg on 08-26-2023 04:52 AM
Wayne Renninger
Report this Post08-11-2023 10:58 AM Click Here to See the Profile for Wayne RenningerSend a Private Message to Wayne RenningerEdit/Delete MessageReply w/QuoteDirect Link to This Post
!984 dew wipes? What is different then the other years and what do you have to do for them to fit?
Vintage-Nut
Report this Post08-11-2023 02:47 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dew Wipes in 1984 Fiero by FieroMeister
https://www.fiero.nl/forum/...020208-2-015218.html
Dew Wipes 1984 Fiero SE by Serilli
https://www.fiero.nl/forum/Forum2/HTML/142434.html
Early 1984 Dew wipes by Adjustso3
https://www.fiero.nl/forum/Forum2/HTML/134790.html
Edit: "The Door Gap" is the difference between '84 and '86-'88
BTW: GM Seals are better than 'Aftermarket' Seals (IMHO)
NOS OEM Door Outer Dew Wipes (Left + Right Pair)
https://fierogear.com/shop/...pes-left-right-pair/
[This message has been edited by Vintage-Nut (edited 08-11-2023).]
Total ratings: 328
Report this Post08-11-2023 09:09 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wayne. There is a slight difference in the 84 dew wipes and if you find them they will be expensive.. They would probably fit like the 85-88 units but its not the easiest job. The inner door panel must first come off. Some guys use the compact Dickman offset screwdriver to get at the screws that are not easily accessible. You will be removing and replacing screws working behind the window. The other technique is to mark and remove the window stops and raise the window high enough the reach the hard to get to screws. I prefer method two but some prefer method one. I would place a magnetic pick up tool below where you are working to catch any screws that fall into the door.
Vintage-Nut
Report this Post08-12-2023 01:32 AM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI - A good thread to replace the glass seals (a.k.a. dew wipes)
As Dennis LaGrua said; method two (like the video in the link below) takes a little more work, but really 'easier' than trying to get the screws out behind a pane of glass in the way....
How to replace inner and outer dew wipes. Videos. by 2.5
https://www.fiero.nl/forum/Forum2/HTML/139805.html
buddycraigg
Total ratings: 478
Report this Post08-24-2023 11:55 PM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
god.
There was a difference between the 84 and the rest but I can't remember it.
I never had a problem replacing them in an 84, and I have worked on a lot of 84s. My V8 is an 84.
And by the way, I used the short screw driver from Rodney.
Vintage-Nut
Report this Post08-25-2023 09:00 PM Click Here to See the Profile for Vintage-NutSend a Private Message to Vintage-NutEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Wayne,
Do you want to insert a comment?
Vintage-Nut
Original Owner of a '88 GT and 'Under Refurbishment'
buddycraigg
Total ratings: 478
Report this Post08-26-2023 04:52 AM Click Here to See the Profile for buddycraiggSend a Private Message to buddycraiggEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want to say there is a screw hole not in the right place. But I'm doing this from memory and have been out of the business for a long time.
