  Is anyone useing an aftermarket ecu with their 2.8 V6
Is anyone useing an aftermarket ecu with their 2.8 V6 by sleek fiero
Started on: 01-02-2023 07:58 PM
Replies: 16 (684 views)
Last post by: sleek fiero on 01-09-2023 09:10 PM
sleek fiero
Report this Post01-02-2023 07:58 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just wondering what ecu's are being used on 2.8 V6 cars besides the stock ecu
pmbrunelle
Total ratings: 63
Report this Post01-02-2023 08:03 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM 7730
Haltech E6GMX
MegaSquirt 2
MegaSquirt 3
jdv
Report this Post01-02-2023 09:02 PM Click Here to See the Profile for jdvSend a Private Message to jdvEdit/Delete MessageReply w/QuoteDirect Link to This Post
$12p on a gm 7165
fierosound
Total ratings: 286
Report this Post01-02-2023 10:40 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by jdv:
$12p on a gm 7165
Same. Runs an MPFI system I built for my Indy's SD4
https://www.fiero.nl/forum/...L/000077-6.html#p226
[This message has been edited by fierosound (edited 01-02-2023).]
Xenoblast
Report this Post01-02-2023 11:32 PM Click Here to See the Profile for XenoblastSend a Private Message to XenoblastEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ive thought about making a speeduino work on my fiero, I even bought one and had most of the board soldered together.. In theory it shouldnt be that hard to do because all the speeduino guys use all the same gm sensors.
I bought an lq1 before finishing tho so i have another abandoned project
sleek fiero
Report this Post01-03-2023 12:37 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I started with a 1227730 and a set of batchfire coils. It ran well but did not produce the power I expected. I have an autoprom chip writer from Moates but still could not get good results. I bought an Emtron sl6 and built a new harness and used Bosch sensors and finally got the results I hoped for. Adrian Norton from Emton remote tuned it on a dyno dynamics dyno. Now I really wish I had not played around with all the other junk. anybody wants some Moates gear and a couple of 1227730 ecus just pay for the shipping and its yours.
pmbrunelle
Total ratings: 63
Report this Post01-03-2023 02:53 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
A programmable ECU is simply a means to run an engine with a certain AFR and ignition timing.
How can one ECU make more power than another ECU, if AFR and timing are the same?
claude dalpe
Report this Post01-03-2023 09:52 AM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good point Patrick,
I think it's the tune that is the key to the power you want and not the ECM
Me with my 3.5 LX9 and 7730 ECM spent a lot of time tuning the ECM to get the power all over the rev range
The stock tune for my 7730 is from a 1992 Chevrolet 3.1 V6, it can't work with a 2005 3.5 LX9 without a lot of changes in the tune
We start with a 140 HP engine to go with 210 HP rated by GM
sleek fiero
Report this Post01-03-2023 10:45 AM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I did not explain myself very well. I found the Emtron gave me more options, most importantly I am able to use 2 lambda o2 sensors for very accurate air/fuel ratio sensing . Iam also running 2 knock sensors ,fuel pressure and fuel temp. Air intake temp and air pressure sensors before and after the 56 mm Bosch throttle body. I machined and installed a crank trigger wheel and used an LS crank trigger.. I took the old distributor and machined a wheel for it and built a cam sensor out of it. As for throttle pedal I modified a Nissan 370zx pedal to fit .Definitely it has been a lot of work but it was fun and I learned lot about tuning. the car is 85 gt and has full suspension package that the Fiero store used to offer .My 2.8is Bored and stroked to 3.208 liters and is balanced , Diamond 10.5/1 forged pistons , scat rods and new 3.1 crank. Crower 03050 cam , stainless valves, performance springs and roller tip rockers. Headers and Ocelot stainless exhaust. Champion 3 core aluminum rad with ac delete. 235/17 Yokohama tires on RTX rims.
I have had the car for 29 years .
claude dalpe
Report this Post01-03-2023 11:28 AM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry but you spent lots of money and time for maybe a few more HP
$ 2 700 for your Emtron sl6 ECM + all your fabrication for crank and cam sensor + the Nissan pedal
All of that for bring a 2.8 (3.1) to the limit !
I don't want to tell you that you didn't do well As you say you had fun doing it that's very important
Did you run the dyno test to see the difference between different ECU's and tune?
sleek fiero
Report this Post01-03-2023 01:21 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did not dyno the GM 1227730 but I did dyno the Emtron.146 hp at 242 kms /hour and 266 ft lbs at 118 kms / hour at the wheels . It is a lot more responsive on the road. No it does not make sense the amount I have invested except here in Canada I get to keep my collectors plates and I get very cheep insurance with my plates ($200 US per year) because its a numbers matching engine ..Normal insurance would cost 1200 US up here. Besides it's been a fun project and now I know every inch of my car. my tuner says that if I want to change from premium pump to race fuel we could gain quite a bit more power but I want to keep it as a street car.
claude dalpe
Report this Post01-03-2023 03:48 PM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now I understand more why you chose this engine and this amount of money for reach more HP.
Here in Quebec I can do a swap and the insurance is still low do you try Hagerty insurance
My insurance send me a evaluator from this company every 4 years and he fix the price for my insurance
And they know I have a engine swap
I have a normal licence plate I can go every where with my fiero for $280CA/year
Enjoy your fiero
sleek fiero
Report this Post01-03-2023 04:20 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Claude thanks for your response. here in BC we don't have private insurance. The Provence has a monopoly on insurance with their own insurance corporation.We have no choice but to buy insurance from them.
La fiera
Report this Post01-05-2023 11:51 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtube.com/watch?v...arXZ0&feature=shares
This is my 2.8L with my own custom cam, CNC ported heads, custom sheet metal intake, headers, stock bottom end and Factory stock ECU programing.
sleek fiero
Report this Post01-06-2023 12:56 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
definitely nice numbers. Does it drive nice on the street or is it more for track use ? Who did your cam and heads ?
La fiera
Report this Post01-06-2023 05:53 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Sleek!
It is a street legal track car, so I drive it around to local car shows. I modeled the cam profile for it but since I had no way to tune the ECM I had to compromise. Now I have full control of the tuning and it's not a problem anymore. The heads were done by an old friend that used to work for Ford on the Ford GT40 that went to lemans in the 60's.
sleek fiero
Report this Post01-09-2023 09:10 PM Click Here to See the Profile for sleek fieroSend a Private Message to sleek fieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats cool . We have a great track here ( Area 27 ) that I would like to take mine to and do some testing but its like $600 per day and its just out of my reach so it's just for the street for now.
