If it is AC clutch wires...
The Plug to the coil have a diode to stop major back feed power surges that can blow ECM Radio and more.
Same reason many Car Relay coils have diode built into them but AC coil is way Way bigger that dumps 600+ volts and plenty of amps when coil is turn off. Enough to jump the AC Relay contacts to kill that and other things.
Very likely that diode broke too and must be replace.
Is why many "pigtail" for AC coil has the diode and wires connected.
Example: Dorman 85143
https://www.dormanproducts.com/p-20711-85143.aspx
