  4.6 Northstar Swap Project (Page 6)
4.6 Northstar Swap Project by copperhens
Started on: 10-09-2018 08:09 AM
Replies: 210 (6732 views)
Last post by: copperhens on 10-20-2022 07:58 PM
Total ratings: 236
Report this Post02-03-2022 03:19 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Internet-man:
Wow! So cool. How loud is that thing?
Being able to keep the trunk is a must for any engine swap, for me. So a point for N* on that
It's fun but not objectionable? The X-pipe takes it down 3dB by splitting each pulse into two pipes and then the cats provide additional muffling. I don't run mufflers, but fitting mufflers would make it even quieter.
Keep in mind that both my and copperhens' exhausts will NOT work with the stock Caddy automatic. You need a manual transmission to free up the engine bay volume for the exhaust in order to keep the trunk.
Report this Post02-03-2022 05:43 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! So cool. I'm keeping photos of this for future reference. How loud is that thing?
If you can weld, then keeping the truck with most engine swaps just comes down to creativity and commitment.
My LS4/F40 swap has a turbo and dual muffler exhaust hanging off the rear manifold and clears the stock trunk. Took a lot of effort, but ultimately was worth it to me.
copperhens
Report this Post02-08-2022 08:11 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a video of a cold start on my Northstar with exhaust. It is a 2 1/2 in stainless steel dual exhaust with 40 series flow masters, which are pretty big. I have half a trunk left with my exhaust set up, I just need to put in a (removable for access) trunk pan.
https://youtu.be/AYWP8npsHkc
copperhens
Report this Post10-17-2022 08:11 PM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Northstar is still alive… and has a new look.
Total ratings: 236
Report this Post10-17-2022 08:26 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like you didn't cut the wheel houses yet.
Total ratings: 463
Report this Post10-18-2022 02:09 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by copperhens:
Here is a video of a cold start on my Northstar with exhaust. It is a 2 1/2 in stainless steel dual exhaust with 40 series flow masters...
That sounds really nice!
And now it looks pretty good too! You and the crew are doing a great job.
Total ratings: 236
Report this Post10-18-2022 02:10 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
]https://images.fiero.nl/use...6FA363A.jpeg
Do you have more photos of the assembly process? After watching Russ' thread about doing one, it looks like there's a lot of effort required to get it to go together.
[This message has been edited by Will (edited 10-18-2022).]
copperhens
Report this Post10-20-2022 10:59 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks! It’s coming along and I haven’t forgotten about it. Next year it will DEFINITELY be on the road to get some miles under it since it has a body now.
copperhens
Report this Post10-20-2022 11:03 AM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
copperhens
Member since Oct 2016
We took this body off of another Fiero. It is the same type as Russ’s where the rear is grafted onto a GT rear clip. So a lot of the bolts install like a regular Fiero rear clip. It took only two days to take this body off the other Fiero and put it onto mine. It was not as hard as we thought and it lines up pretty nice.
I should’ve taken more pictures.
Total ratings: 236
Report this Post10-20-2022 11:07 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking that setting up one of those kits from scratch is a LOT of work and should get a few posts
copperhens
Report this Post10-20-2022 07:58 PM Click Here to See the Profile for copperhensSend a Private Message to copperhensEdit/Delete MessageReply w/QuoteDirect Link to This Post
As it turns out, I don’t have the patience to do bodywork on a whole kit lol.
