From left to right, New Gasket (part # VG70), EGR Tube to Plenum, EGR Tube to EGR Valve.
EGR Gaskets. Can I replace both EGR Tube gaskets with new (part # VG70) gaskets. On the EGR Tube to Plenum gasket, why is opening smaller compared to the EGR Tube to EGR Valve gasket? Where can I buy the EGR Tube to Plenum gasket?
I bought a new EGR Valve, it cames with
Orifice Washers. If the original EGR Tube to Plenum gasket is not available should I attempt to use the old gasket (this is where I think I have a vacuum leak) or use two new (part # VG70) gaskets on the EGR Tube and the new EGR Valve with the same size orifice hole as the original gasket?
If the original gasket is available, do I nee to use a orifice washer at all with the new valve?
