Easier then above...
C2/p4 grounds other things... Like the clip to ground temp gauge.
jump top clip on temp gauge to bottom clip for fuel gauge. You can follow both traces in this...
CLICK FOR FULL SIZE |
Most any old network/phone cable w/ solid wire can be used.
Strip ends only.If a bare jumper moves can short 12V to ground and cook the board.
To attach...
I think push wire in the dash then look at other side to catch big ear or back of clip then push back so can twist tight on board side.
Less risk damaging the clips or have jumper get loose.
Small hole is clearance for screws on the gauges... If screw hits the jumper can cause minor reinstall issues. So don't just push hard when gauges don't fit flat.
If C3/p11 traces look thin near idiot lights then jumper to the tach bottom clip next to C3 bottom.
Nothing draws many amps so short jumper should be ok.
big jumper should be glued w/ RTV silicon. short jumper is optional.
