  wont stay running unless keep giving throttle (Page 1)
wont stay running unless keep giving throttle by 87fiero2017
Started on: 05-20-2017 11:40 AM
Replies: 48 (1924 views)
Last post by: shemdogg on 07-06-2017 07:59 PM
87fiero2017
Report this Post05-20-2017 11:40 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
well i picked up my first fiero this spring. its a 87 with the 2.8 with auto trans. hasnt seen the road legally since 97. lol. i put a new fuel pump and did the bypass. car will start but wont stay running unless i keep giving throttle. once in a while it will backfire through the intake. i checked fuel presssure just in case and thats in spec. i had someone mention the car could be flooding and check the fuel regulator. i just took that out and no rips. any ideas you guys can give me would be great
henryj53
Report this Post05-20-2017 12:10 PM Click Here to See the Profile for henryj53Send a Private Message to henryj53Edit/Delete MessageReply w/QuoteDirect Link to This Post
Been here, done this. Ok first place to start is look at the harmonic balancer, car has been sitting for almost 10 years they will dry out and come loose, check your cap, rotor and wires as well as cleaning up the distiburator if have one, if not check coils or coil, clean throttle body , ckeck vacuum lines and the check all the sensors, TPS, IAC, EGR....also make sure both intake plenums are tight, if not replacement of gaskets will need to be done and torque them down, after that then you should have eliminated all from the equation
By the way has nothing to do with fuel pressure
[This message has been edited by henryj53 (edited 05-20-2017).]
Total ratings: 465
Report this Post05-20-2017 03:06 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, they can come loose (been there, done that)... but unless the ignition has been re-timed after the balancer's outer hub has spun, the spun hub itself will not affect the engine's ability to run.
henryj53
Report this Post05-20-2017 06:10 PM Click Here to See the Profile for henryj53Send a Private Message to henryj53Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes they can, have an 86 and 87 might be the non distributor type, if so if the outer ring comes loose, had it happen on a 85 cavalier with a 2.8 the balancer was loose and rubbed on timing cover throwing timing off enough for it not to run correctly because of the positioning sensor, my 86 the balancer was bad and caused a slight knocking that could be picked up by the anti knock sensor and advanced timing to compensate
[This message has been edited by henryj53 (edited 05-21-2017).]
87fiero2017
Report this Post05-20-2017 08:17 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mm ok. I'll check the balancer. Has new cap and rotor and plugs. No vacuum leaks that I have found.
henryj53
Report this Post05-20-2017 09:07 PM Click Here to See the Profile for henryj53Send a Private Message to henryj53Edit/Delete MessageReply w/QuoteDirect Link to This Post
Your TPS sensor should have 5v with key on and when move the lever should be about 1.5v out put should be able to put test probes from the wire entry and get a signal without poking thru wire insulation itself
shemdogg
Report this Post05-21-2017 12:03 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
old gas? throw a new fuel filter at it? I had a fuel system cleaning done by my local shop, car runs awesome now
shem
Total ratings: 465
Report this Post05-21-2017 03:41 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...the outer ring comes loose, had it happen on a 85 cavalier with a 2.8 the balancer was loose and rubbed on timing cover throwing timing off enough for it not to run correctly because of the positioning sensor, my 86 the balancer was bad ond cuased a slight knocking that could be picked up by the anti knock sensor and advanced timing to compensate
None, I repeat none of which applies to the 2.8 in a Fiero.
[This message has been edited by Patrick (edited 05-21-2017).]
henryj53
Report this Post05-21-2017 12:14 PM Click Here to See the Profile for henryj53Send a Private Message to henryj53Edit/Delete MessageReply w/QuoteDirect Link to This Post
May not apply to the Pontiac Fiero, but does apply to the 2.8, seeing they were the same GM engine just different location in the car and that was what was talking about, not weather it applied to one car or the other just the engine being they same
Total ratings: 465
Report this Post05-21-2017 10:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
May not apply to the Pontiac Fiero...
Well yeah, and that's all I was pointing out to the OP.
Report this Post05-22-2017 01:00 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hasn't been driven legally in 20 years? There may be a lot of things that need inspected, checked for ohms, filthy gas tank plugged injectors, huge mouse nest in muffler, plugged cat, etc.
Vacuum leak?
[This message has been edited by 2.5 (edited 05-22-2017).]
87fiero2017
Report this Post05-25-2017 12:30 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
well tested one theory out having a clogged exhaust. not that. legally it hasnt been driven. still gotta test the tps sensor. now bout the cold start injector? if that dont work would that cause my conditions?
Total ratings: 465
Report this Post05-25-2017 03:39 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
87fiero2017
Report this Post05-25-2017 05:04 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well unplugging the cold injector made it worse so not that. ..
Total ratings: 465
Report this Post05-25-2017 05:50 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well unplugging the cold injector made it worse so not that...
Worse? The cold start injector is only active while the engine is being cranked... and only below a specified temperature.
87fiero2017
Report this Post05-25-2017 07:15 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok.. well this motor isn't looking good.. Wonder if I got compression issues. Trying to find a 3.8 sc car nearby but no go yet
Total ratings: 465
Report this Post05-25-2017 07:34 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
i put a new fuel pump and did the bypass...
What's the "bypass"?
Did you check your fuel pressure... both while the engine is running and after it's turned off? Maybe you have an injector or two (or more) that's leaking bad?
87fiero2017
Report this Post05-25-2017 09:08 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
I did the hot wire relay. Well engine only runs for a few seconds then stalls out.i was reading about 45ish pressure
Total ratings: 465
Report this Post05-25-2017 09:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
engine only runs for a few seconds then stalls out. i was reading about 45ish pressure
And? How quickly does it drop?
87fiero2017
Report this Post05-25-2017 09:46 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well key on it was good. And running I believe it was too. I did a physical inspection of the regulator and didn't see any rips..
Total ratings: 465
Report this Post05-25-2017 11:37 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What does that have to do with checking for leaking injectors?
87fiero2017
Report this Post05-26-2017 07:05 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Around the o-rings?
Total ratings: 465
Report this Post05-26-2017 02:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Around the o-rings?
Damaged injector O-rings can create vacuum leaks. Leaking injectors lose fuel.
87fiero2017
Report this Post05-26-2017 04:53 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
No I'm good there
87fiero2017
Report this Post07-02-2017 08:04 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
well figured i let you in on progress. friend of mine gave me his camaro 2.8 block and trans. well he had new injectors in there. i noticed nothing else i could really use. i just tried starting it and it runs...well it idles at 3500 rpms but it idles. lol. tried swapping around iac's but no change. so i plugged in my scanner and looked at datastream. if im reading right tps is at 3.76 volts..could that be my problem? from what ive seen i should be at .5
1986 Fiero GT
Total ratings: 54
Report this Post07-02-2017 10:01 PM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The TPS should send a voltage between roughly .5V and 4.5V proportional to throttle percentage. If it's reading almost 4V with no throttle applied, the sensor has failed.
87fiero2017
Report this Post07-03-2017 09:13 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok. well i just tried removing tps and the screws broke . ill have to drill out the throttle body for new screws...fun..
Total ratings: 291
Report this Post07-03-2017 11:27 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just swap throttle bodies from your friends 2.8.
Your off reading of your TPS isn't going to cause the engine to run fast. The ECM barely uses the TPS readings. It uses it to 1 - determine if the engine should be idling (TPS <.6ish) and if it is then tries to adjust idle speed using the IAC - and 2 - to determine if you just stabbed the throttle so it knows it needs to add extra fuel to accellerate the engine.
Your off reading could be that the sensor failed or it could be a bad connection between the TPS and the Black wire of the connector. Key on engine off and scanning watch the TPS reading. Unplug and then reinsert the TPS connector. Does that maybe fix the problem? Try moving the throttle by hand (still engine off but scanning) and see if the reading moves like it should.
The MAP is the main sensor the ECM uses to determine how much fuel to inject. It measures the air pressure in the intake and then injects the right amount of fuel. The ECM really doesn't care how the air got in there.
Your engine is running at 3500. That much air can only get in the intake three ways - 1 throttle is open - 2 the EGR to intake manifold tube is rusted out and severed - 3 the IAC passage is allowing it in.
Check to make sure the throttle is moving correctly. Do not adjust that throttle stop screw. Leave the cap on.
Assuming you still have the trouble, and assuming you haven't taken the throttle body off, then #2 is the most likely suspect.
Cut a strip of aluminum can the width of the UPC label. Take the dist cap off but leave the wires on and put it to the side. Loosen the two 10mm head bolts on the bottom of the intake manifold inlet that connect the EGR tube to the bottom of the manifold. It will be difficult but you can do it. You will swear a little however. Once loose, slip the aluminum strip between the tube's flange and the intake manifold. Then tighten the two bolts. Replace the cap and start the car. If your idle is now normal, the problem is a leaking EGR to intake manifold tube.
[This message has been edited by phonedawgz (edited 07-03-2017).]
87fiero2017
Report this Post07-03-2017 01:23 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Egr tube is good...I tried swapping out iac motors no change. Unfortunately I scraped the rest of the motor as well as the tps
Total ratings: 291
Report this Post07-03-2017 04:16 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, those are the only three places that can flow enough air to idle the engine at 3500 rpm. The IAC passage has an o-ring that can get out of place but that is on the engine side of the throttle body. Unless you or someone else had the throttle body off, that would not be a suspect.
Tell us when you get it which one it was.
87fiero2017
Report this Post07-03-2017 10:23 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Note first time owning a fiero but don't I should have to pump my brake pedal every time I start it to get it firm... hmmm
87fiero2017
Report this Post07-03-2017 10:56 PM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
87fiero2017
Member since May 2017
If I put my finger over the iac hole in the throttle body that should tell me it's failing right if it comes down on idle?
Total ratings: 465
Report this Post07-04-2017 03:57 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I put my finger over the iac hole in the throttle body...
...the engine should stall.
Total ratings: 291
Report this Post07-04-2017 07:44 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the problem with your very high idle is a stuck open IAC valve, putting your finger over the IAC air inlet will bring the idle down below a normal idle or it might even stall. If it doesn't you could still be looking at a dislodged o-ring where the IAC feed tube inserts into the throttle body or one of the other two suggestions I had listed earlier.
The o-ring can get dislodged if the throttle body is removed from the intake manifold and when it is reattached when the feed tube is inserted it pushes the o-ring out of its internal groove in the TB.
I have only seen this happen when someone removes the throttle body.
95% of the time it is a broken intake to EGR tube.
[This message has been edited by phonedawgz (edited 07-04-2017).]
87fiero2017
Report this Post07-04-2017 08:28 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Put my finger over the iac hole and it didn't change anything. So guessing my problem is somewhere else. Happy 4th by the way
87fiero2017
Report this Post07-04-2017 08:59 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
87fiero2017
My 87 don't seem to have that iac tube. Pretty sure my egr tube is fine. I'll take it off later and double check
Total ratings: 291
Report this Post07-04-2017 09:25 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is a whole lot easier to use the aluminum strip to block it off than it is to take it off. If the strip cuts the idle down, then you can take it off and look at it. If the strip does nothing then look elsewhere.
87fiero2017
Report this Post07-04-2017 09:53 AM Click Here to See the Profile for 87fiero2017Send a Private Message to 87fiero2017Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 465
Report this Post07-04-2017 03:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 87 don't seem to have that iac tube....
Now that would certainly explain a massive vacuum leak... and high idle!
Total ratings: 291
Report this Post07-04-2017 03:45 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think you can get the IAC tube out without taking off the throttle body. That said a while back you said injector o-rings. If they were not in place that could do it but I wouldn't think they would be missing but he did just replace the injectors.
