  GM Connector Behind Instrument Cluster
GM Connector Behind Instrument Cluster by Mykola
Started on: 01-20-2017 09:41 AM
Replies: 2 (160 views)
Last post by: theogre on 01-20-2017 11:36 AM
Mykola
Report this Post01-20-2017 09:41 AM Click Here to See the Profile for MykolaSend a Private Message to MykolaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need the name or part number of the connectors that run to the back of the instrument cluster and connect to the board for oil pressure and etc. Someone before me cut out those connection pieces. If any one has even a picture or any info on where to get these, that would be great. Thank you.
Chris Eddy
Report this Post01-20-2017 11:26 AM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You might get lucky and find them available for sale, if you can track down the right numbers.. but you are better off going to Epay or starting a new adventure in a junk yard.
Report this Post01-20-2017 11:36 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is just one of many "standard" Packard plugs (Most to all plugs have PED on them for Packard Elect Division.) but very hard to find new for this type. Is not a part most people would used so never sold thru aftermarket. I'm betting Hard to find thru dealer parts too.
You will need to get used ones from about any GM car's dash from 70's to 90's and maybe more and splice as a "pigtail" end(s).
When at yard, Cut wires as long as possible so can spread out the splices so everything fits under dash trim.
I would get 3-4 plugs so you are sure to have enough pins.
Back side plugs are same thing but 1 is 10 pins, other 18 pins.
Not all pin positions are used even tho Fiero 18 dash plug look like it should.
Pins are removable you can match wire color and put pin in the right location. GM use most of same colors for each signal, power, etc, but moved pin positions as needed.
Is better and smaller to properly solder and use heat shrink tube.
Solder gun (like Weller 8100 or 8200 models) w/ ~100w is needed to heat the wires fast w/o major damage to insulation.
see https://www.fiero.nl/forum/F...HTML/138962.html#p11
