  Difficulty shifting: '85 gt w/ muncie 4-speed
Difficulty shifting: '85 gt w/ muncie 4-speed by Xexyz
Started on: 01-31-2016 08:59 AM
Replies: 13 (370 views)
Last post by: jaskispyder on 02-01-2016 08:39 AM
Xexyz
Report this Post01-31-2016 08:59 AM Click Here to See the Profile for XexyzSend a Private Message to XexyzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had problems shifting, especially into 1st, 2nd, and reverse ever since I had the engine rebuilt in my 85 GT. The problem seems random; sometimes it'll shift smoothly and without a problem, others it doesn't want to go into gear and I'll have to shift back and forth to get it to go into gear. Is it difficult to adjust/replace the shift linkages? (assuming that's the problem)
[This message has been edited by Xexyz (edited 01-31-2016).]
Total ratings: 291
Report this Post01-31-2016 10:11 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does it grind into reverse?
Does it shift better if you double pump the clutch?
Look for air in the clutch line.
Xexyz
Report this Post01-31-2016 10:26 AM Click Here to See the Profile for XexyzSend a Private Message to XexyzEdit/Delete MessageReply w/QuoteDirect Link to This Post
No grinding, and I'm pretty sure it doesn't shift better if I double pump.
SCRebeck
Report this Post01-31-2016 10:27 AM Click Here to See the Profile for SCRebeckSend a Private Message to SCRebeckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Try Bloozberry's method he posted here. He says to use 3rd gear, but my repair manual says to use 1st. I used 1st and it is definitely better, but not perfect.
Pancake
Report this Post01-31-2016 01:52 PM Click Here to See the Profile for PancakeSend a Private Message to PancakeEdit/Delete MessageReply w/QuoteDirect Link to This Post
How are the motor mounts? Given that you just had a rebuild I'm curious if the motor is sitting differently. I know my 85 GT is a PITA to get into 2nd and 1st is almost impossible to find when the back of the car is loaded (reverse or on a hill) because my dogbone is pretty much shot and the motor can flex oddly. When the weight is on the nose I can pretty easily find 2nd and a 2nd-1st shift usually works.
I'm pretty sure my is a combination of needing new cables and needing to bleed the system too, but again the ability to even find 1st and 2nd varies depending on the weight load. It's really fun stuck at a light uphill
[This message has been edited by Pancake (edited 01-31-2016).]
Xexyz
Report this Post01-31-2016 02:42 PM Click Here to See the Profile for XexyzSend a Private Message to XexyzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting; when I had the rebuild done I had new mounts put in since the old ones were shot. I hope that's not the reason for my problems since that sounds like a difficult problem to fix.
tebailey
Report this Post01-31-2016 03:52 PM Click Here to See the Profile for tebaileySend a Private Message to tebaileyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sounds like a cable problem, what fluid are you using in the tranny?
Total ratings: 465
Report this Post01-31-2016 05:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Xexyz:
Correction: It's an Izuzu 4-speed. I thought the 4 speed was the Muncie.
You need to correct your correction. It is a Muncie.
Pancake
Report this Post01-31-2016 06:10 PM Click Here to See the Profile for PancakeSend a Private Message to PancakeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shouldn't be with new mounts. The only reason mine does it is the mounts are bad enough it can flex a lot. Have you checked cables like others have suggested? They're a known failure point
Xexyz
Report this Post01-31-2016 09:28 PM Click Here to See the Profile for XexyzSend a Private Message to XexyzEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sure. I didn't do the work, and it was done about 10 years ago or so.
Ok, now I'm confused, lol. My Chilton manual said the Muncie was a 5-speed that the Fiero didn't get until '87.
Total ratings: 465
Report this Post01-31-2016 10:08 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
In a Fiero, the only Isuzus available were 5-spds (used with the 4-bangers except in '84). Muncie supplied both 4 and 5 spds, depending on the year.
Report this Post01-31-2016 10:26 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The sooner you throw away your Chilton, the smarter you will be about your Fiero. That book has hundreds of errors/omissions. Haynes is slightly better, and even the official GM service manual (publisher is Helms) has a few mistakes.
[This message has been edited by Gall757 (edited 02-01-2016).]
viperine
Report this Post01-31-2016 11:16 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, it does make a nice knee pad or headrest when you gotta get down and dirty to fix the car it was intended for!
How are you shifting? Are you hitting the clutch pedal fast and furious style, or are you letting your synchros do their job? My 86 GT Muncie gave me a hard time getting into gear when the shift (not select) cable started fraying. The problem wasn't much at cold startup, but when warm, the cable could flex a whole lot more. After I replaced the cable and transmission mounts, I still struggled. The issue was then, I failed to adjust the cable at the transmission even after following the correct procedure. It ended up just taking a LOT of trial and error to find that sweet spot for the cable's stud to be located in the bracket. All said and done, I've replaced both cables with Rodney Dickman's replacements (awesome quality), replaced the bracket the cables attach to (broke the original trying to install Rodney's brass bushings, agh!!), fluid change with synchromesh, and have yet to install the shifter rebuild kit. So, with the prospect of new motor and tranny mounts, you might have a similar course of action to take. I do not recommend the brass bushings unless it's a last resort. That bracket is uber hard to find if you break it!
jaskispyder
Total ratings: 205
Report this Post02-01-2016 08:39 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would replace the fluid, first. Some people will put 90W gear oil in the tranny..... which is wrong. Syncromesh or 5w-30 is what is needed.
