  Starts then dies
Starts then dies by Sean GT
Started on: 10-23-2015 11:30 AM
Replies: 16 (2933 views)
Last post by: CarolinaRigman on 10-26-2015 10:42 PM
Sean GT
Report this Post10-23-2015 11:30 AM Click Here to See the Profile for Sean GTSend a Private Message to Sean GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an 1986 GT 80k miles
Car sat for about a year (in garage) bad fuel pump.
I replace with new fuel pump yesterday. I drained old gas and cleaned out tank.
Replaced with new Bosch, and new filter. Put in 5 gallons fresh gas.
Car will start but will only run about 5 seconds then it will die.
I also tried it with starting fluid, but same thing.
You can hear the pump run, and it has 46 psi, no bleed down.
After I try to start it a few times, it will have to sit a few minutes, before it will try to run when I try to restart.
Has new pump relay, new oil sending unit.
Im lost as to what to try next.
thank you in advance.
cebix
Report this Post10-23-2015 11:57 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
So when you spray starting fluid when it starts to die it doesn't help? Do you see the injector spraying still? Is ignition alright?
TopNotch
Total ratings: 60
Report this Post10-23-2015 02:52 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
This test will need two people. Have someone crank the car while you spray the starting fluid. Keep giving it little spurts into the throttle body (not a constant spray), and see if you can keep it running. Post the result here.
Report this Post10-23-2015 05:39 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If the car quits on starting fluid, look for an ignition problem with the ICM, or related parts like ignition coil or pickup coil. Those pesky ICMs have so many ways to fail....this might be another one.
Sean GT
Report this Post10-24-2015 07:10 PM Click Here to See the Profile for Sean GTSend a Private Message to Sean GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
(TopNotch) I just tried to start the car, with a friend, using small spurts of starting fluid.
Car will not stay running even with use of starting fluid. It starts and runs for a few seconds. After I release the ignition key, its like it uses the gas in the
line then dies. When it dies you can hear the fuel pump re-prime, like its lost pressure, or like the fuel pump shut off, or injectors shut off.
Im not a mechanic so im just guessing at things.
As stated in first post, I have 46 psi with no bleed down.
ICM is new, Coil is new, plugs are new.
It ran fine up until the old fuel pump went out.
Dont know what to try.
Thanks again everyone for the replies.
Report this Post10-24-2015 07:50 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
New does not mean Good. Do you mean you have changed the ICM and the problem persists?
[This message has been edited by Gall757 (edited 10-24-2015).]
jimbolaya
Total ratings: 114
Report this Post10-24-2015 08:07 PM Click Here to See the Profile for jimbolayaSend a Private Message to jimbolayaEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is more truth in this one statement than in every thread on this forum combined. Especially if you buy from Advance.
Jim
mrfiero
Total ratings: 150
Report this Post10-25-2015 12:51 AM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
It sounds like your injectors aren't firing.....it could be because they are clogged or there is a wiring issue. The reason it starts then dies is because your cold start injector (CSI) is working. The CSI sprays gas when you first crank the engine over, but shuts off soon after. There is usually enough gas for the car to fire but not enough to actually run.
Check the fuse panel to make sure it's not a blown fuse. Then inspect the injector wiring harness.....unplug it and look at the terminals (they might be corroded). If you can't find anything wrong there then it is likely that the injectors have clogged up. A rebuilt set is fairly cheap.....I've found them on eBay for less than $100 a set (I think I paid $75 the last time I bought some).
Csjag
Report this Post10-25-2015 07:05 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I installed a new Bosch pump in my GT it was doing the same thing. It turned out that I had reversed the polarity on the wires to the fuel pump and the pump was running backwards.
CarolinaRigman
Report this Post10-26-2015 01:01 AM Click Here to See the Profile for CarolinaRigmanSend a Private Message to CarolinaRigmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before you remove anything, crank the engine and watch the oil pressure guage.
If it reads halfway up the guage or say 25 psi you should have enough oil pressure
to keep the pump energized,if not you need to add a manual guage with a tee at you sending unit
and watch it as you crank it, also takes two people. I've installed bad sending units also.
It's better than pulling the tank again with no resolution to the problem.
I've been working on my 85 for a few years and put 3 pumps in it from sitting!
Also you should have a elec. plug there close to the relay area to energize the pump manually.
Check your repair manual for the location. That might tell you if the pump is the culprit!
Good Luck! If this doesn't help take two aspirin and call back!
Doug
Total ratings: 465
Report this Post10-26-2015 01:40 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are two coils... the ignition coil and the pickup coil. Which one did you replace?
The pickup coil (in the distributor) should be changed when the ICM is changed. It's a relatively inexpensive component.
sardonyx247
Total ratings: 219
Report this Post10-26-2015 03:19 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Doug
This shows you have an 84, the pump test connector on 85-88 is in the ALDL.
To the OP have the ICM checked at any autoparts store, I have been sold bad ones before.
If it runs then dies check spark output, (use a timing light or just an old plug) You only need 4 things to start a car compression, timing, spark, fuel, since it does start for an instance I would rule out timing and compression, That leaves fuel and spark, just to help you narrow it down.
Sean GT
Report this Post10-26-2015 09:10 AM Click Here to See the Profile for Sean GTSend a Private Message to Sean GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If fuel pump was wired (reverse polarity) would it still show good fuel pressure?
Oil pressure at cranking is 40psi +
Ignition module was replaced.
Total ratings: 465
Report this Post10-26-2015 12:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you've previously mentioned that...
... but you never answered my question.
[This message has been edited by Patrick (edited 10-26-2015).]
Csjag
Report this Post10-26-2015 01:25 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you mean oil pressure or fuel pressure?
Total ratings: 465
Report this Post10-26-2015 02:54 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
How many times have you changed the fuel pump in that GT?
You changed it in 2005 according to this thread... Wont start after shut down
And then earlier this year HERE you said you changed it "less than five years ago".
And now you've changed your fuel pump a third time... and you're still having problems?
Have you considered converting to propane?
CarolinaRigman
Report this Post10-26-2015 10:42 PM Click Here to See the Profile for CarolinaRigmanSend a Private Message to CarolinaRigmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
In my Fiero I considered nitroglycerin a couple of times.
