  fuel pump
fuel pump by Sean GT
Started on: 07-22-2015 03:22 PM
Replies: 5 (822 views)
Last post by: Sean GT on 07-22-2015 10:39 PM
Sean GT
Report this Post07-22-2015 03:22 PM Click Here to See the Profile for Sean GTSend a Private Message to Sean GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the rubber sleeve that goes over the fuel pump necessary?
My fuel pump quit so I took it out and the rubber sleeve had turned into a
black goo, and part of it had broken away in chunky goo.
I have cleaned the tank but don't want to have to do it again because of the sleeve.
The pump was less than five years old.
Thank you in advance.
Report this Post07-22-2015 03:34 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Things that turn into black goo in the fuel system are not made out of the right material for sitting in gasoline. If you are talking about the fuel line, it must be the 'submersible' kind. What is a sleeve? Do you have a picture?
TopNotch
Total ratings: 60
Report this Post07-22-2015 04:18 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some Fiero fuel pumps have a rubber sleeve over the pump itself, to reduce noise. The sleeve is supposed to be submersible, but maybe some aren't. But in any case, it is not necessary. The old one in my 86 SE had a sleeve -- the new replacement did not, and it has worked fine for years.
Total ratings: 465
Report this Post07-22-2015 05:29 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
What condition was the short piece of hose on the assembly? Or did yours have the pulsator?
That's a non-Fiero assembly I found on the 'net, but it's a similar setup.
Hudini
Total ratings: 165
Report this Post07-22-2015 05:53 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the new pump comes with one then use it. If not then do not worry about it. The new pumps are designed much better than the old pumps. My Bosch replacement pump even said to remove the pulsator as the new pump is a different design and does not use it.
Do replace the fuel sock though. That thing prevents sucking big bits into the pump.
Sean GT
Report this Post07-22-2015 10:39 PM Click Here to See the Profile for Sean GTSend a Private Message to Sean GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
It has a pulsator on it. (1986 GT)
It was the sleeve that covers the pump itself that deteriorated.
I am going with the Bosch replacement and will not use the pulsator.
I will also replace the fuel strainer and fuel filter.
Thanks for all the replies
