   343SC Spintech Muffler sound quality on the 3800 swap? (Page 2)
343SC Spintech Muffler sound quality on the 3800 swap? by Dennis LaGrua
Started on: 06-30-2015 05:10 PM
Replies: 45 (2891 views)
Last post by: Dennis LaGrua on 12-08-2020 11:57 AM
Report this Post07-23-2015 01:16 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is an illustration of how the Spintech 343SC will fit. Pretty close to stock look with no trunk mods.:
[This message has been edited by Dennis LaGrua (edited 07-23-2015).]
Tom Slick
Report this Post06-03-2017 09:25 PM Click Here to See the Profile for Tom SlickSend a Private Message to Tom SlickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was able to get my Spintech muffler to only protrude about 1/2" below the heat shield. With a creative bend of a 3" exhaust donut on the head pipe you can get that muffler to higher up. The muffler is only 9" H and 4" W. The jury is still out on the sound.
Got any pics of the "creative bend" of the 3" exhaust donut?
I'm trying to install the 343SC and get it tuck up enough without half of the muffler
hang to low.
Thanks
[This message has been edited by Tom Slick (edited 06-03-2017).]
longjonsilver
Report this Post12-07-2020 08:50 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Riddick85:
I have a MagnaFlow muffler that has one in on one side and outs on both sides just like the stock fiero muffler is. It is very quiet at all times. All I can hear is my supercharger screaming behind me when I get on it. I can't remember the part number right now though
i like the idea of quiet. Magnaflow makes this muffler: #12266 2 1/2" in, dual 2 1/4 outs 5"x8"x18" What problems might i have fitting this muffler behind my otherwise stock 3800SC?
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
Report this Post12-07-2020 05:24 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
jon
Anything longer than about 13" is going to make fitting that muffler in place difficult. It can be done but it usually results in having to eliminate the trunk side heat shield as a muffler longer than about 13" will not fit in the space that the cradle allows. The Spintech is the lowest sounding muffler for its size that we've tried. If you want further sound reduction the exhaust pipes can be wrapped in DEI heat wrap. That tends to make them somewhat like resonators. The Spintech exhaust is not exactly quiet but you can have a conversation in the car while driving. Its far lower than when we had the Flotech Afterburner muffler installed. That muffler was extremely loud and gave a loud drone.
longjonsilver
Report this Post12-08-2020 09:46 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dennis. Question:
Is there some reason you recommend DEI?? This is cheaper:
https://www.amazon.ca/SWI-T...%2Caps%2C166&sr=8-10
Report this Post12-08-2020 11:57 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cannot give you an opinion on the lower cost heat wrap. Is it identical material, the same density ???? If it is the same material then by all means it should work. All I can say for sure is that by wrapping the pipes it did provide some sound relief. It was pretty hard getting an acceptable exhaust tone from the 3800
