Hello, I have a few questions, I have gone to Archies web site and looked at the links for the directions, and install, but the photo's are small and hard to see the detail for the questions I have..
#1 the directions say to put the alt, a/c v belt pulley on the crank balancer (this is taken from the link on the site)
---------" Install the harmonic balancer pulley to the engine as close as possible to the timing chain cover with out rubbing against it. Usually the distance from the face of the pulley to the end of the crank will be about .300". "
I can't tell by the photo's but it sounds like the v belt pulley is going over the balancer outside diameter, and not bolted onto the front face of it, like most crank pulleys, is this the case, if so how does this clear the timing pointer on timng covers, or the bolt on type?? and what size diameter is the balancer used, ?? my engine I'd use for this was balanced with the balancer on it now, and the swap kits list a balancer as part of the parts list.. so need a little help with the details on that..
#2 oil pans, what fits, most small block chevy's have a 4qt pan, the 2nd gen vette pans are 6qt and truck pans are 5-6qt but have a longer sump what have you used, I ask as the duke had low qt oil pan so!!!!!!!!!!
#3 flex plates the parts list ,list a flex plate and a flexplate adapter, is the flexplate a standard chevy plate and the adapter bolts between that and the torque converter, or is the flexplate supplied different than the chevy piece, ??
#4 what transaxle does this work with?? just the th125 or does the 4t40 (not 100% that that is the model of the 4 speed swapped into these to replace the 3 speed ), ???
#5 has anyone measured the crank centerline, to the decklid underside?? this help know if the intake will clear without mods
#6 starters, there was a tilton and a powermaster listed from what I've seen, has anyone used any other starters with good luck, like say the 90's g.m. gear reduction starter, used on trucks .
#7 exhaust the photo's it looks like g.m. early vette /truck ram horn center dump manifolds are they, and has anyone used block hugger type headers? the heads on this engine I'd like to use have large ports and angle plugs..
#8 The links on his site show a a/c compressor bracket, is this a have to use part or just included for those with a/c..
#9 water pumps, the site photo isn't clear is it a short pump or the 70 up car long pump ?
#9B has anyone tried an electric water pump instead of the mechanical pump and it's long drive system??
#10 springs,(rates) what have people use to hold up the extra weight at the rear..
#11 will the 84 wiring get in the way
Thanks for any info on this.. so I know what I'm in for, and if requirements will make it a "no go" with the engine on hand ..
[This message has been edited by E.Furgal (edited 02-03-2015).]
