  Rekeying so ONE key does all...
Rekeying so ONE key does all... by notaguru
Started on: 04-17-2014 08:20 PM
Replies: 28 (724 views)
Last post by: jscott1 on 04-21-2014 12:41 AM
notaguru
Report this Post04-17-2014 08:20 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm thinking about pulling the steering column assembly and re-keying that cylinder to match the outside doors and decklid.
Make sense?
FTF Engineering
Report this Post04-17-2014 09:01 PM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not really... IIRC, the ignition uses a different blank than the rest of the car, so it's not as simple as putting new tumblers in and matching it to the other locks.
In other words, even if the cut pattern is the same, I don't think the key will fit into the slot.
notaguru
Report this Post04-17-2014 09:12 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was thinking of replacing the ignition switch cylinder with one that matches the cylinders of the doors/decklid.
VikingRedBaron
Report this Post04-17-2014 09:16 PM Click Here to See the Profile for VikingRedBaronSend a Private Message to VikingRedBaronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck finding that cylinder
FTF Engineering
Report this Post04-17-2014 09:54 PM Click Here to See the Profile for FTF EngineeringSend a Private Message to FTF EngineeringEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not saying it can't be done, but I would be very surprised if you find a cylinder that meets that requirement.
If you can, that would be cool though...
seajai
Total ratings: 52
Report this Post04-17-2014 10:37 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM ignition lock cylinders use a square top key and the door/trunk cylinders use the round key. The grooves on the sides of the keys are different so they won't physically fit in the opposite cylinders regardless of the tumblers inside. You might have more luck trying to swap the guts in the doors to take a square top key. I'd go talk to a locksmith to see what's possible.
ericjon262
Total ratings: 67
Report this Post04-17-2014 10:45 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
LMC truck makes lock cylinders for the doors that uses an ignition key blank, might be possible to retrofit the cylinders into our mechanisms...
P/n 36-0690
1st class A**hole.
FieroJimmy
Report this Post04-17-2014 10:55 PM Click Here to See the Profile for FieroJimmySend a Private Message to FieroJimmyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not all are different, I've keyed several cars to a single key each. Currently my GT uses a single key. It's mostly a question of finding a key blank that will fit both cylinders, you can't necessarily use one of your existing keys.
It's been 7 or 8 years since I did it, but it is certainly do-able.
notaguru
Report this Post04-17-2014 11:17 PM Click Here to See the Profile for notaguruClick Here to visit notaguru's HomePageSend a Private Message to notaguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a very small milling machine (Unimat). It would be trivial to remove material along the long axis of KEY A to it would fit into either SLOT A or SLOT B. Then it's a matter of pulling the cylinder and moving the pins around...
In fact, that's what I've just decided to do.
KillerFrogg
Report this Post04-17-2014 11:23 PM Click Here to See the Profile for KillerFroggSend a Private Message to KillerFroggEdit/Delete MessageReply w/QuoteDirect Link to This Post
actually, you would have to remove material from both sides of the key. A is Z shaped and B is S shaped. To remove enough material to get it to work, you would basically loose the entire bottom half of the key.
Why not remove the ridge from inside the ignition lock, so that you can just use an exterior key?
You would then need to get a set of exterior keys cut as ignition keys, but you would only have to modify one lock. Or you could modify the outside locks, and just use a standard ignition key for everything.
I think either would work just the same. Just a matter of what you want to do.
[This message has been edited by KillerFrogg (edited 04-17-2014).]
KillerFrogg
Report this Post04-17-2014 11:27 PM Click Here to See the Profile for KillerFroggSend a Private Message to KillerFroggEdit/Delete MessageReply w/QuoteDirect Link to This Post
KillerFrogg
Member since Apr 2013
*Sorry for the double post*
Also do not forget about the key lock tumbler right at the back of the key. That one is deeper than any of the other tumblers for anything else on the car, so when you are in the locks for the outside of the car, you may want to just remove that tumbler all together. With that notch still on the key, the key will lock in the ignition, but because you have removed that tumbler on all of the other locks they will ignore it.
dobey
Total ratings: 371
Report this Post04-17-2014 11:57 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Or just buy a cylinder set for a modern Pontiac that already uses a single key, and fit the cylinders into the Fiero?
sricka01
Report this Post04-18-2014 02:18 AM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Just install keyless entry if you have PDL. Be less effort?
FieroJimmy
Report this Post04-18-2014 06:49 AM Click Here to See the Profile for FieroJimmySend a Private Message to FieroJimmyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing has to be modified. Just take a door/trunk cylinder and the igjition cylinder to somewhere with a selection of key blanks, and test them till you find one that will insert into both, then recode the cylinders to match. It's not that hard, no cutting, or milling, or custom work of ajy kind.
Csjag
Report this Post04-18-2014 07:19 AM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wonder what the reason was initially for making them separate?
racingfortheson
Report this Post04-18-2014 07:27 AM Click Here to See the Profile for racingforthesonSend a Private Message to racingforthesonEdit/Delete MessageReply w/QuoteDirect Link to This Post
When someone finds out what blank is used less us know. That way I don't have to go bug the people at the locksmith shop, lol.
sardonyx247
Total ratings: 219
Report this Post04-18-2014 07:42 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is an old topic.
It has been done before, the way it was done IIRC was they cut another line down the length of the key.
I forget who did it but it was a long time ago.
Try search, you may be able to find it.
Edit to add: there are two different door key blanks for the Fiero, some Fiero keys will not in other Fieros. I know this for a fact as my 2 87s will not fit each other.
Looking at them now, I bet one door key might fit one of my IGN locks, I will have to try tomorrow if I remember.
[This message has been edited by sardonyx247 (edited 04-18-2014).]
FieroJimmy
Report this Post04-18-2014 12:02 PM Click Here to See the Profile for FieroJimmySend a Private Message to FieroJimmyEdit/Delete MessageReply w/QuoteDirect Link to This Post
The markings on my GT key say "Access+" and "7R" . That may or may not work in your cylinder, as stated above not all cylinders use the same blank pattern.
Total ratings: 260
Report this Post04-18-2014 01:06 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Web Electric used to have a write up where he ground a new groove into his key to allow the mod. Buddycraigg just had a locksmith take an A+B blank and cut it for his doors, then have the locksmith rekey the ignition switch to match.
https://www.fiero.nl/forum/A...030819-2-034335.html
css9450
Total ratings: 87
Report this Post04-18-2014 03:18 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Probably some logistical reason... By having two keys, the ignition cylinder could be installed in the steering column (or dash on older cars) without having to be matched to the cylinders being installed in the doors and trunk. Particularly convenient if the steering columns come pre-assembled from some other factory.
NetCam
Report this Post04-18-2014 05:27 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not sure if there was any truth to the story, but a long time ago I heard that because of the small number of tumblers there weren't that many combinations of keys. By having 1 key for the doors and another for the ignition, there was a much smaller chance that somebody could end up having a key that could get into your vehicle and start it. A friend of mine in Vancouver was able to open the doors of my neighbours pickup truck with his door key, but the ignition key didn't match.
jscott1
Total ratings: 415
Report this Post04-18-2014 06:41 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
In my opinion...they went to two keys just to make our lives miserable.
A long time ago GM had two keys but one would work the ignition and door and the other worked the trunk and glove box. Then they started keying the ignition key to be all by itself. I think the theory was you could give your door key to your kid or someone to get something out your car, or trunk but not drive off.
I shaved off my door handles so I have a trunk key and ignition key.
JJFieroFan
Report this Post04-18-2014 07:44 PM Click Here to See the Profile for JJFieroFanSend a Private Message to JJFieroFanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would it be possible to install push button start so the key was not needed? If You did this You would want to have a secure alarm system. I have keyless entry so I am good as is, just wondering.
Total ratings: 461
Report this Post04-19-2014 11:09 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
This makes as much sense as anything, along with the idea of the columns being assembled elsewhere.
I used to be a locksmith, in a previous life. You could carry enough keys to open most any GM car on three 4" rings.
GM went to "one key fits all" about the same time that they added to the number of tumblers (and started making 'transponder" keys.)
dobey
Total ratings: 371
Report this Post04-19-2014 11:32 AM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Definitely plausible. I remember one time when I was a little kid, coming out of the grocery store with my mother, we got into the wrong Malibu. Was the exact same color and car, and the door key worked perfectly.
jscott1
Total ratings: 415
Report this Post04-19-2014 07:14 PM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
This happened to me as well. Back in the 90s we had a fleet of Corsicas and a buddy and me got in the wrong one and the key opened the door and started it... we drove off as some other guy was screaming at us that we were stealing his car. I wouldn't have believed it if I didn't see it with my own eyes.
sardonyx247
Total ratings: 219
Report this Post04-20-2014 03:50 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
LOL, my door key from one of my 87s fits the IGN lock on my other 87, I didn't try the other way.
So yeah it is possible and sometimes real easy.
on the after note, my friend had a GN and started it up one time, then said wiat this is my Jeep key. Both keys still had the 'knock-out' in them and the codes even matched.
tshark
Total ratings: 68
Report this Post04-20-2014 09:53 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
jscott1
Total ratings: 415
Report this Post04-21-2014 12:41 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
My brother had a ('73?) Challenger with a 318. One day, someone came up, unlocked it with a key, and drove off. Bye, bye car.
According to my 5 minutes of research if you steal a car with the keys it's not a felony. It's considered joy riding. So thieves love GM cars for joy riding. Some Chryslers also used the saginaw column and therefore have the same crappy ignition switch. You would think they would have fixed that at some point. Now with the lawsuits, they finally might.
