  2nd generation Vibe/Matrix wheels...
2nd generation Vibe/Matrix wheels... by Doober
Started on: 02-26-2014 09:36 PM
Replies: 8 (395 views)
Last post by: Reallybig on 03-01-2014 03:37 PM
Doober
Report this Post02-26-2014 09:36 PM Click Here to See the Profile for DooberSend a Private Message to DooberEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone installed them?
[img]https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-frc3/t1/1655957_10203312530757270_1836760203_n.jpg[/img]
dematrix86gt
Report this Post02-26-2014 09:45 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
those dont look bad for a MFG wheel. just looked them up, they come painted , satin and polished
[This message has been edited by dematrix86gt (edited 02-26-2014).]
hookdonspeed
Total ratings: 131
Report this Post02-26-2014 10:04 PM Click Here to See the Profile for hookdonspeedClick Here to visit hookdonspeed's HomePageSend a Private Message to hookdonspeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
are they the right pattern? if so what size?
Doober
Report this Post02-27-2014 12:46 AM Click Here to See the Profile for DooberSend a Private Message to DooberEdit/Delete MessageReply w/QuoteDirect Link to This Post
They're a 17", pretty sure stock size was 215/50/17. According to the site below, all Vibes are 5x100.
http://www.discountedwheelw...attern_Reference.cfm
Score!
I found some in Phoenix that are $75 each, and are supposedly in A (great) condition according to car-part.com, downside is I don't have any money for 'em
According to:
http://matrixowners.com/ind...be-gt-hub-bore-size/
the Vibe's hub bore is about 54mm, and from what I can find the Fiero is ~57mm... but...
http://adaptitusa.com/referencebook.htm
that lists both cars as having the same bore size... so they may just be a direct bolt-on Since I'm currently employed at a semi-large (probably one of the largest) parts/service centers, if I get the chance I may see if I can get the next customer with a Vibe or Matrix in the same year range to let me see if the wheels would simply bolt on
ennored
Report this Post02-27-2014 11:54 AM Click Here to See the Profile for ennoredSend a Private Message to ennoredEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/A...030204-2-027227.html
And I don't think ALL Vibes are 5x100. I think the GTs were different at least.
[This message has been edited by ennored (edited 02-27-2014).]
Total ratings: 461
Report this Post02-27-2014 06:21 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Vibe and Matrix are Toyota products.
Every Toyota wheel that I've ever heard of, in 5x100, needed to be bored to fit our cars. Including those.
dematrix86gt
Report this Post02-27-2014 11:26 PM Click Here to See the Profile for dematrix86gtSend a Private Message to dematrix86gtEdit/Delete MessageReply w/QuoteDirect Link to This Post
i just looked at that pic again. its not bolted up.
daveg
Report this Post02-28-2014 06:14 PM Click Here to See the Profile for davegSend a Private Message to davegEdit/Delete MessageReply w/QuoteDirect Link to This Post
Late model Vibe Gt and Matrix' with the larger 2.4l engine have 5x114.3 bolt pattern.
Dave
Reallybig
Report this Post03-01-2014 03:37 PM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put celica gts wheels on my fiero a while back. Had the 5x100 and 54mm cb. Rather than bore them to 57cb i used 1/4" spacers and relied on the bolts for centering the wheels. It vibrated bad at highway speeds so i sold them rather than go through the hastle of having them bored to 57mm. Make sure the offset doesn't make them stick out or in too far for the wheel wells before you invest too much money!
