  installing urathane cradle bushings
installing urathane cradle bushings by Lou6t4gto
Started on: 12-04-2013 05:46 PM
Replies: 13 (437 views)
Last post by: Boostdreamer on 12-09-2013 04:58 PM
Lou6t4gto
Report this Post12-04-2013 05:46 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are the any Options on "HOW" to get the "rubber out" of the front bushings of the Cradle ?
bomluuk
Report this Post12-04-2013 05:52 PM Click Here to See the Profile for bomluukSend a Private Message to bomluukEdit/Delete MessageReply w/QuoteDirect Link to This Post
A lot of people heat them with a torch and then just push them out. I drilled holes in them and broke them off piece by piece. Pain the butt.
fieroaddicted
Report this Post12-04-2013 06:42 PM Click Here to See the Profile for fieroaddictedSend a Private Message to fieroaddictedEdit/Delete MessageReply w/QuoteDirect Link to This Post
i burnt mine out with torches. Sometimes they will come flying out apparently, although it has never happened to me. lol Once they start to get hot enough, it will build pressure and vent it out the side. Once it started to move, i gave them a tap with a hammer and they fell out. I did my a arms the same way
Total ratings: 260
Report this Post12-04-2013 06:53 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The low effort method is to use a propane torch or hotter, heat the metal sleeve until the rubber liquifies around the sleeve, then you can just tap them out or they will eventually slide out on their own. Hot, smoking, burning bushing can bounce anywhere, so work outside or in a well ventilated area and plan accordingly.
The high effort methods vary, but you either drill, cut, chop, or use a press to force the bushing out of the sleeve.
I use the propane torch method and prop the torch or position the sleeve so I can sit back, watch the smoke show, and wait for the bushing to pop out on its own.
Lou6t4gto
Report this Post12-04-2013 07:36 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tried cutting, drilling , using a press, finally gave up and used the heat wrench. was trying to avoid the smoking, smelly Burning rubber.,, I don't know what's in there, but once it lit up, it was like there was pressurized propane in the rubber, it shot out a flame a foot long, for about 15 seconds ! (good thing I put them on concrete blocks and raked the ground where I was doing it.) That was "Interesting" to say the least !
katatak
Total ratings: 82
Report this Post12-04-2013 10:29 PM Click Here to See the Profile for katatakSend a Private Message to katatakEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm a little late but I've always burned them out - I set the cradle on some stands on it's side and place a 5 gallon bucket with a couple inches of water underneath - lite the rubber and let her go. When the flaming mass of rubber slips out, it's captured and extinguished - most of the "dripping mess" and soot ends up in the bucket too making clean up a lot easier - I use the same method when doing control arms as well.
jimmo
Report this Post12-05-2013 06:57 AM Click Here to See the Profile for jimmoSend a Private Message to jimmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
My first one shot so nicely so I had to video the second one. The bucket of water is a great idea. Here is the video in slow motion http://www.youtube.com/watc...fv0&feature=youtu.be
Lou6t4gto
Report this Post12-06-2013 01:21 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right past the Fuel Tank ! That's scarey ! So, with the New urethane (on the way), I just "Tap" them in ?
Lou6t4gto
Report this Post12-07-2013 05:37 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
OK, got the new urathane bushings. Gotta ask, WHY, on something that you " Don't want it to Move " at all, would you put grease on everything ?? I can understand it on Control arms, sway bars (they are supposed to move), But what is the" wisdom" of doing it on Cradle bushings ?? Thanks
ag9123
Report this Post12-08-2013 08:33 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm curious why you wouldn't go with Rodney's aluminum cradle bushings? Absolutely no movement with those!
Lou6t4gto
Report this Post12-08-2013 11:56 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
tell ya the truth, never crossed my mind ! any Idea WHY they say to grease the urethane for something that's Not supposed to move ?
Report this Post12-09-2013 01:15 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Grease helps keeping water out. The shell and sleeve can rust if you don't grease a little.
Polly to shell/sleeve isn't sealed and water could get into any voids.
Al parts can have same problem. Worse, Al parts in steel can have problems because of "dissimilar metal"/Galvanic/Electrolysis corrosion. Finish of Al parts might help or not, Depend on several factors. Even heavy Anodize finish can fail to protect when road salt is in the mix.
Lou6t4gto
Report this Post12-09-2013 02:28 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
now makes sense. thanks
Boostdreamer
Total ratings: 98
Report this Post12-09-2013 04:58 PM Click Here to See the Profile for BoostdreamerSend a Private Message to BoostdreamerEdit/Delete MessageReply w/QuoteDirect Link to This Post
How I removed the old rubber bushings with pics -
Page 4 of my build thread:
https://www.fiero.nl/forum/F...2/HTML/121056-4.html
Jonathan
