I'm having trouble finding 42# or 42.5 injectors for the 95 Camaro 3.4. Anyone I speak to only confirms the stock fuel injector. A part number or compatible part would be much appreciated.
I am currently using the Ford 19 lb injectors on a turbo 3.4 push rod engine with about 7-8 psi of boost. It was very rich until some custom tuning work was performed. Are you certain that you really need the 28 lb injectors? If so I would appreciate your sharing this specific size requirement so that I can consider upgrading mine.
If your injectors are Ford, then they are more like 22# injectors since they are rated at 19# @ 12v and the Fiero runs closer to 14v. More voltage = more flow.
Wrong. With the exception of a SLIGHTLY slower opening time, voltage will not change injector flow. Ford injectors are typically rated at 43.5psi and most GM injectors seem to be talkd about in a 50psi scale.
Originally posted by darkhorizon: Wrong. With the exception of a SLIGHTLY slower opening time, voltage will not change injector flow. Ford injectors are typically rated at 43.5psi and most GM injectors seem to be talkd about in a 50psi scale.
Funnily enough the math works out the same...so who cares who is actually right.
