  muffler in cat converter position
muffler in cat converter position by DMendez7
Started on: 10-16-2013 08:36 PM
Replies: 6 (313 views)
Last post by: DimeMachine on 10-19-2013 09:24 AM
DMendez7
Report this Post10-16-2013 08:36 PM Click Here to See the Profile for DMendez7Send a Private Message to DMendez7Edit/Delete MessageReply w/QuoteDirect Link to This Post
Would there be major problems if a muffler is installed in the cat position and straight pipes used in the original muffler position? 88 Gt 2.8. Sound and performance wise? I really want a borla muffler lol
86 toy
Report this Post10-17-2013 10:05 AM Click Here to See the Profile for 86 toySend a Private Message to 86 toyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a magnaflow muffler in place of the cat on my 88 when it still had the 2.8.. i built some tubing to replace the factory muffler.. it sounded awesome.. i say go for it!
--Mark--
Yellow 88 GT 3400 5speed
Need headers? click here!
Blacktree
Total ratings: 350
Report this Post10-17-2013 10:50 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Conventional wisdom says to put the muffler as close to the end of the exhaust system as possible, for best performance. But if performance isn't a great concern, then no biggie. That said, with the muffler closer to the engine, it may deteriorate faster, due to the higher heat level. The exhaust gases cool off and slow down as they flow through the pipe.
dobey
Total ratings: 371
Report this Post10-17-2013 12:10 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have any good reason to get rid of the cat instead of replacing it with a new one, and to not keep the muffler in the stock location?
uhlanstan
Total ratings: 427
Report this Post10-17-2013 12:51 PM Click Here to See the Profile for uhlanstanSend a Private Message to uhlanstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never place muffler in the cat location, this will really hurt performance ,, the only place to install a muffler is as Blacktree said ,as far back as possible
the proper borla is the best performance option,next is the Dyno max turbo single outlet,,ask Borla customer servce for best unit,,call them!!
the new cats will not hurt performance
auto part store has pipe extention as smooth as possible ,hard ware store has installation hardware
when you cut the old muffler or cat off ,,retain as much pipe length as possible,file down welds
NetCam
Report this Post10-18-2013 07:59 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
If getting rid of the cat wouldn't it make perfect sense to put a straight pipe where the cat is and leave the muffler alone? Just my 2 cents...
DimeMachine
Report this Post10-19-2013 09:24 AM Click Here to See the Profile for DimeMachineSend a Private Message to DimeMachineEdit/Delete MessageReply w/QuoteDirect Link to This Post
A good new cat will not hurt performance. Moving the muffler to where the cat is will not materially alter your HP on a 2.8. The 3800 crowd puts the muffler REAL CLOSE to the manifold and 300+ hp is not uncommon.
84/87 NB, 3800SC, E-85, VS Cam, 2.8 Pulley, 4T65E-HD, HP Tuners, AEM Wideband, Regal GS Gauges, S-10 Brake Booster. 1/4 mile -11.85 at 114mph
