  3800 gurus
3800 gurus by Shill
Started on: 09-17-2013 06:59 PM
Replies: 9 (330 views)
Last post by: aaronkoch on 09-19-2013 09:36 AM
Shill
Report this Post09-17-2013 06:59 PM Click Here to See the Profile for ShillSend a Private Message to ShillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Had some thoughts recently about a 3800 NA W/ ITB's. Anyone done this before and have some numbers compared to the factory SC engines with let's say a 3" pulley and proper cooling?
sco77
Report this Post09-17-2013 08:30 PM Click Here to See the Profile for sco77Send a Private Message to sco77Edit/Delete MessageReply w/QuoteDirect Link to This Post
Since the intake isn't much of a problem with a 3800 I would think the gains wouldn't be that impressive, also I don't know how something like that would even be tuned, might be outside of the limitation of the 3800 PCM. The intercooled 3.0" SC would definitely be faster by a long shot.
86 Fiero GT 4spd - L67 swap: VS cam, GenV Build Progress
98 GTP - Some mods
darkhorizon
Total ratings: 451
Report this Post09-17-2013 11:29 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
alpha N mode would work ok. Tuning it is not particularly easy to do because most of the alpha n tables are missing... but it would run fine. I helped a camaro guy use alpha n before.
Shill
Report this Post09-18-2013 12:33 AM Click Here to See the Profile for ShillSend a Private Message to ShillEdit/Delete MessageReply w/QuoteDirect Link to This Post
After some research, seems if I want itbs an ls1 is much cheaper with better results
aaronkoch
Report this Post09-18-2013 11:18 AM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I may ask the obvious question, WHY do you want ITB's? There really isn't any advantage to having them, and SO MANY disadvantages to having them.
darkhorizon
Total ratings: 451
Report this Post09-18-2013 03:00 PM Click Here to See the Profile for darkhorizonSend a Private Message to darkhorizonEdit/Delete MessageReply w/QuoteDirect Link to This Post
lololololol
How did you determine it was "much cheaper" to setup more throttle bodies on a v8 than a V6? How did you determine that they would produce "better results"?
LOL
Shill
Report this Post09-18-2013 03:51 PM Click Here to See the Profile for ShillSend a Private Message to ShillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please tell me you would not be excited to see that in the back of your fiero.
Tuna Helper
Report this Post09-18-2013 04:21 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by darkhorizon:
lololololol
LOL
You'd have equal runner lengths, equal plenum volumes, etc. The downside is that plenums and runners are usually tuned to a specific bandwidth, so it may run worse at lower speeds than a single throttle body setup. Plus, you have to "sync" them, each tb/cylinder should pull the same amount of vacuum as the others.
Justinbart
Total ratings: 119
Report this Post09-18-2013 04:38 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
It may look all cool and complicated to some but it would still be slow as **** .
Turbo 3800 E85 F23 5spd spec5
11.17@132.6
aaronkoch
Report this Post09-19-2013 09:36 AM Click Here to See the Profile for aaronkochSend a Private Message to aaronkochEdit/Delete MessageReply w/QuoteDirect Link to This Post
yeah, it looks cool, but then it rains and your motor hydro-locks. Or, you forget to cover your car and a dust storm rolls through, game over. Or you have a really awesome looking paper weight because you can't ever get it running right.
The risk/reward number is too high for my blood.
