  will 87 headlight motors work in an 86?
will 87 headlight motors work in an 86? by northstar
Started on: 09-14-2013 12:02 PM
Replies: 6 (353 views)
Last post by: James Bond 007 on 09-14-2013 06:47 PM
northstar
Report this Post09-14-2013 12:02 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
ive heard of people doin this what all do I need and how hard is it to do??ALSO WILL MY DRIVER SIDE HEADLIGHT MOTOR FIT ON THE PASSENGER SIDE.. I HAVE AND 86 AND 2 PASSENGER SIDE MOTORS AND ONE BAD DRIVER SIDE ,,ARE THEY INTERCHANGEABLE??
[This message has been edited by northstar (edited 09-14-2013).]
steve308
Total ratings: 59
Report this Post09-14-2013 12:15 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
You need the complete wire harness from the 87 and the shorter bolts from the 87 to mount the motors to the buckets. There is a great how to in the FAQ section that will guide you thru the change. It is worth the time and effort !
Report this Post09-14-2013 12:16 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
See my Cave, Gen 2 HL Motor
follow links at bottom
northstar
Report this Post09-14-2013 12:18 PM Click Here to See the Profile for northstarSend a Private Message to northstarEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks for the reply if it were as easy as just switching a few things I would but not that motivated,,will the passenger side motor on an 86 fit the driver side or are they side specific? thanks
NetCam
Report this Post09-14-2013 01:13 PM Click Here to See the Profile for NetCamClick Here to visit NetCam's HomePageSend a Private Message to NetCamEdit/Delete MessageReply w/QuoteDirect Link to This Post
As far as I know, there isn't a way to swap the motors over, they are side specific. I did the Gen 1 to Gen 2 swap about a month ago, and it took me a couple of hours tops. There was nothing really difficult about it, on a scale of 1 -10 on difficulty I would rate it a 3. Check this link here, it has a really good writeup on how to do the swap. The toughest part for me was taking the hood off without a helper (And trust me, you do want to take the hood off).
https://www.fiero.nl/forum/A...060811-2-071514.html
If you don't want to swap the harness, here's a good article on how to convert a Gen 1 harness to work with Gen 2 motors.
https://www.fiero.nl/forum/A...090907-2-087182.html
I'd highly recommend getting rid of your Gen 1 motors. Gen 2 are faster, quieter, easier to work on and more reliable.
[This message has been edited by NetCam (edited 09-14-2013).]
rbell2915
Report this Post09-14-2013 06:28 PM Click Here to See the Profile for rbell2915Send a Private Message to rbell2915Edit/Delete MessageReply w/QuoteDirect Link to This Post
Agree totally. But my father and I didn't bother taking the hood off lol
James Bond 007
Total ratings: 263
Report this Post09-14-2013 06:47 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
You got to have everything,wireing harness (one or two screws hold that on at the firewall).Motors and brackets.Basically everything.
