  Which Heater core shall i use????
Which Heater core shall i use???? by kikinz24
Started on: 09-01-2013 10:57 AM
Replies: 7 (416 views)
Last post by: kikinz24 on 09-02-2013 08:57 AM
kikinz24
Report this Post09-01-2013 10:57 AM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok i recently started working on my swap on my 87 gt... well i tore my interior out for a complete scrub down... and my heater core is leaking... my question is.... which heater core should i use for my replacement.. now i see is significant difference between one with a/c and one without. (price wise).. the car is a factory a/c car... but im removing everything a/c involved... its a 3800sc drive train im running.. and i deleted the ac.... so pretty much my question is will the non a/c heater core work????
RWDPLZ
Total ratings: 306
Report this Post09-01-2013 11:18 AM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's not a matter of heating or cooling capacity, but of physical fit. The with AC core is designed to fit in that box and use those hoses. Same with the non-AC version.
benoitmalenfant
Report this Post09-01-2013 11:37 AM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ditto what RWDPLZ said.
If you want to get the non-ac one, you'll also need to change the heater box (this includes changing the head-unit as well, install control cables etc.) so the non-ac HC can fit in.
The non-ac HC are typically more expensive than the A/C ones (I checked RockAuto and TFS), so if I were you, I'd stick in a new AC HC and call it a day, much simpler than having to mess with the heater box.
For example @ RockAuto:
SPECTRA PREMIUM / COOLING DEPOT Part # 94498 W/ AC -- 30.79$
SPECTRA PREMIUM / COOLING DEPOT Part # 94499 w/o AC -- 81.79 (!!!!!!) (That's one of the largest difference I've seen)
VISTA-PRO Part # 398204 {#8204} w/o AC-Heater Only -- 46.79$
VISTA-PRO Part # 398203 {#8203} w/AC -- 49.79$
Ben
87 GT / 88 GT
84 Indy #1863
Blacktree
Total ratings: 350
Report this Post09-01-2013 12:00 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Like mentioned above, the heater core has to fit the ductwork. If you retain the "with A/C" ductwork, but just remove the A/C hardware, you'll still need a "with A/C" heater core.
kikinz24
Report this Post09-01-2013 09:00 PM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok good point guys. I wasn't sure if they had different heater boxes or not. Ill just go with the rock auto one then.
Total ratings: 154
Report this Post09-01-2013 09:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
By all means, take along your old heater core to compare to the new one. I've found that some of the chain auto parts heater cores are a bit smaller than needed and they won't stay in place in the box.
benoitmalenfant
Report this Post09-01-2013 11:35 PM Click Here to See the Profile for benoitmalenfantSend a Private Message to benoitmalenfantEdit/Delete MessageReply w/QuoteDirect Link to This Post
FYI, don't know if you took out your evaporator in the process of deleting the AC but if you want to plug the hole where the pipe of the evaporator comes out of the heater box to connect to the accumulator you can either re-use the old black putty/caulk that was there or buy new one from 3M.
Check this post and the following from Randye:
https://www.fiero.nl/forum/F...ML/124499-2.html#p41
[This message has been edited by benoitmalenfant (edited 09-01-2013).]
kikinz24
Report this Post09-02-2013 08:57 AM Click Here to See the Profile for kikinz24Send a Private Message to kikinz24Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys ill check it all out
[This message has been edited by kikinz24 (edited 09-02-2013).]
