  88 2.5L running issue :( please help (Page 2)
88 2.5L running issue :( please help by gtxbullet
Started on: 11-08-2012 11:30 PM
Replies: 45 (2420 views)
Last post by: calvan5154@att.net on 05-23-2022 01:04 PM
Report this Post08-01-2013 08:10 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by gtxbullet:
no change with wd40.
have codes 15 - coolant temp
24 - speed sensor
33 - map sensor (only happens when it stalls)
42 - ignition
Have you go through the diagnostic troubleshooting flow charts in the service manual for each individual code?
the issue has to be in the wires.
Assume nothing. Verify everything.
Follow the diagnostic flow charts...
gh0stmach1ne
Report this Post03-13-2016 03:43 AM Click Here to See the Profile for gh0stmach1neSend a Private Message to gh0stmach1neEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you ever figure anything else out? I'm currently sitting in an 88 2.5 with similar issues.
88 Fiero Notchie
Report this Post11-21-2021 11:29 AM Click Here to See the Profile for 88 Fiero NotchieSend a Private Message to 88 Fiero NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah Im curious. My 88 duke is acting similar but my computer is feeding me no codes. No flashing when I cross the terminals. I have another 88 duke and it threw me codes with is good the standard 3 blinks to make sure everything is in order. I moved the ECM and same deal, no codes.
88 Fiero Notchie
Report this Post05-05-2022 10:14 PM Click Here to See the Profile for 88 Fiero NotchieSend a Private Message to 88 Fiero NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same same, I have 2 cars doing this same thing. One was fine before but I swapped some parting including the ICM and coils off my good running car along with my ECM, MAT and entire throtile body. The car with the issue still had the problem so i moved it all back and the good running car developed the same symptoms. I think its an issue with the ICM. It got fried or soemthing. is there a way to test an ICM for issues? Car still runs but pops/missed and wont hold an idle, also hard to start.
gtxbullet
Report this Post05-05-2022 10:31 PM Click Here to See the Profile for gtxbulletSend a Private Message to gtxbulletEdit/Delete MessageReply w/QuoteDirect Link to This Post
The issues I was having went away.
My guess was a ground issue.
Considering I've had every part off the frame/car at least once, including an A/C all powered option interior harness and engine harness.
calvan5154@att.net
Report this Post05-23-2022 01:04 PM Click Here to See the Profile for calvan5154@att.netSend a Private Message to calvan5154@att.netEdit/Delete MessageReply w/QuoteDirect Link to This Post
long story short I put my 2.5L back in my 88 and sold my 3.4L swap to buy a fastback daily driver.
here's the details:
Starts fine, idles good for a couple minutes
after a couple minutes the idle rpm's sort of wander very oddly. not reving up and down, but gradual
when driving it sometimes wants to stall (and does) while shifting into another gear (manual) or when coming to a stop.
when I'm stopped in traffic the rps kick down then up A LOT, to the point I need to keep my foot on the gas so kids don't think I want to race them...lol
when the engine is running it sounds like it's very slightly putt putting.
here are the things that are new or have be tested and have ZERO ISSUES:
brake booster (and all connections between the booster and the engine)
fuel pump - new
Pump Strainer - new
fuel filter - new
fuel pressure regulator - new
Every engine seal and gasket was replace (full deconstruction and rebuid - this problem was happening before I did this)
MSD Coil Packs
ignition module - new
Crank Sensor - new
Spark Plugs - new
Spark Plug Wires - new
Power and Ground cables - new
PCV - new
EVAP System has been checked and bypassed - issue doesn't go away
EGR - new
Computer (PCM) has been swapped (1988 5-speed and 1987 5 speed, no change)
no catalytic convertor (though I'm going to be putting a high flow unit on to quiet it down again
