  brake bleeding (Page 2)
brake bleeding by Foley
Started on: 09-18-2012 04:25 PM
Replies: 46 (4143 views)
Last post by: Dennis LaGrua on 05-13-2021 05:56 AM
Mike in Sydney
Report this Post05-07-2021 02:16 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Omitted - Dual posting
[This message has been edited by Mike in Sydney (edited 05-07-2021).]
Mike in Sydney
Report this Post05-07-2021 02:17 AM Click Here to See the Profile for Mike in SydneySend a Private Message to Mike in SydneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mike in Sydney
Member since Sep 2011
Originally posted by hunter29:
Yes, everyone says LR RR but my 86 FSM says RR LR as well, so is the book wrong?
Uh huh. Wrong, not right, incorrect, deviating from truth or fact; erroneous. I know. Patrick and I had the discussion a couple of years back. It is LR, RR, RF, LF.
hunter29
Report this Post05-07-2021 07:24 AM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
I get it guys, Thanks ... so for me the question is do I need to bleed them again? I just did it a few days ago and have not had a chance to drive the car. I did RR LR, do I really need to do it again?
Opinions please...
Report this Post05-07-2021 04:01 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Opinions please...
In some ways it depends on what brake work was done.
But you can also think of it this way, it never hurts to do it again. Something else alot of people don't do is change their brake fluid just because its time to change it. It should be changed for regular maintenance and should not be dark brown like it is in many peoples reservoir.
Report this Post05-07-2021 06:26 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
This method that now works best for me--Speed Bleeders
Just for reference the Russell Speed Bleeders that fit the Fiero calipers are
P/N 639580
size is: 10mm x1.530 I had to use an 11mm wrench to tighten or loosen them.
Remove old bleeder with a 10 MM wrench. Screw speed bleeders in all the way in but not too tight. Put 1/8" clear plastic hose on bleeder about 30" (loose end in a soda bottle) , then back off about 1/2 turn, step on brake pedal about 6 or 7 times. When the clear plastic hose shows no bubbles you are done. Tighten bleeder closed just snug but not too tight. Then move on to the next wheel in proper recommended sequence. I have found that this method of bleeding works best if your brake booster has vacuum so I start after each wheel to recharge.
I did all four wheels without jacking up the car. With 5 spoke aluminum wheels I was able to reach in there an get it all done. A lift is of little use here as this one man operation requires getting in the seat and pumping the brake pedal after each wheel bleed. With stock Fiero wheels you will most likely need to take them off to bleed.
ZaraSpOOk
Report this Post05-12-2021 11:32 PM Click Here to See the Profile for ZaraSpOOkSend a Private Message to ZaraSpOOkEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since the MC on an 88 is split between front and back, would it really matter if you did the front first?
just askin, I always do mine rear first then front out of habit
BTW, after installing speed bleeders, I put them on all my vehicles, so quick and easy
Report this Post05-13-2021 05:56 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front and rear brakes can be considered two separate systems on the MC but reality is that the entire system works as one. Front and rear brake lines all funnel through the proportioning valve. As such we start bleeding the farthest caliper away from the MC and work our way closer.
