  brake bleeding (Page 1)
brake bleeding by Foley
Started on: 09-18-2012 04:25 PM
Replies: 46 (4144 views)
Last post by: Dennis LaGrua on 05-13-2021 05:56 AM
Foley
Report this Post09-18-2012 04:25 PM Click Here to See the Profile for FoleySend a Private Message to FoleyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, i just finished replaceing calipers, rotors and pads all around... wondering if im going to need to bleed brakes? had people tell me both yes and no... so am i!? thanks
Report this Post09-18-2012 04:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
How could you possibly replace the calipers and not get air in the system?
Go bleed your brakes. It needs to be done occasionally anyway. I'm doing mine today on a "project" Fiero as well.
[EDIT] Remember to use the proper sequence (which is Fiero specific) - LR RR RF LF
[This message has been edited by Patrick (edited 09-18-2012).]
Stainless1911
Report this Post09-18-2012 05:11 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep. I just did mine. I used the hand vacuum pump to start, then went back around all fours the old fashioned way because I dont trust the pumps. They are good enough to get things started but because I can still see bubbles, they aren't done. Once I dont see any bubbles, then and only then will I say the brakes have been bled.
Stainless1911
Report this Post09-18-2012 05:13 PM Click Here to See the Profile for Stainless1911Send a Private Message to Stainless1911Edit/Delete MessageReply w/QuoteDirect Link to This Post
Stainless1911
Member since Apr 2012
Why? I was always taught that you start farthest away and work your way in. The instructions to the pump says the opposite! It says to start closest and work your way out.
Marvin McInnis
Total ratings: 227
Report this Post09-18-2012 05:14 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Foley:
... had people tell me ...no...
After replacing the calipers? You need to find a new technical advisor ASAP.
Yes, your brakes need to be bled all around. Take your time; do it right.
Report this Post09-18-2012 07:47 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Stainless1911:
Why?
Why not?
I was also taught to start with the furthest caliper from the master when bleeding and to work your way closer (as you were taught). So, what are you going to follow... how you were taught or what the directions from some cheap pump tells you?
Marvin, more words of wisdom please!
Marvin McInnis
Total ratings: 227
Report this Post09-19-2012 11:04 AM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
... more words of wisdom please!
"Want to make God laugh? Tell him your plans." ~ Woody Allen
[This message has been edited by Marvin McInnis (edited 09-19-2012).]
Report this Post09-19-2012 02:23 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heh heh... Not quite what I had in mind Marvin, but it'll do!
Foley
Report this Post09-19-2012 06:49 PM Click Here to See the Profile for FoleySend a Private Message to FoleyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys any idea how much fluid im going to need?
Marvin McInnis
Total ratings: 227
Report this Post09-20-2012 12:15 PM Click Here to See the Profile for Marvin McInnisClick Here to visit Marvin McInnis's HomePageSend a Private Message to Marvin McInnisEdit/Delete MessageReply w/QuoteDirect Link to This Post
... any idea how much fluid im going to need?
Go ahead ... splurge and buy a whole quart of DOT3/4 brake fluid. That is more than enough to bleed and flush an entire system. Don't be tempted to use some old fluid that has been sitting on the shelf, opened, for several years. Brake fluid is hygroscopic; it readily absorbs moisture from the air.
FieroCustom
Report this Post01-02-2013 11:16 PM Click Here to See the Profile for FieroCustomClick Here to visit FieroCustom's HomePageSend a Private Message to FieroCustomEdit/Delete MessageReply w/QuoteDirect Link to This Post
As for the sequence: LR, RR, RF, LF is correct. The LR caliper is the farthest away due to the brake line being ran down the passenger side to the rear brakes. This means that the driver's side caliper is the farthest from the master cylinder. Next farthest would be the RR, then the RF and lastly, the LF with the shortest run of piping to the master cylinder. You may now resume your normally scheduled program...
John
1955 Chevrolet 210 Sedan (Shopping list in progress)
1988 SE seized duke...next engine...1996 LQ1 found
~Future 1990 Fiero Clone?
1988 T-Top Coupe rocking 41 MPG!
1986 SE Project Mayhem
1999 F350 Crew Dually ~17mpg city 22 hwy
Wife's 2001 Saturn SL1 51MPG high score
hypo327
Report this Post01-04-2013 05:16 AM Click Here to See the Profile for hypo327Send a Private Message to hypo327Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, don't use old brake fluid...I found this out the hard way, when I was back in high school (about 50-years ago...lol.) This is why I always buy small bottles, so I don't have allot sitting on the shelf and end up throwing it out. After changing calipers, you usually end up using the whole small bottle, and since you don't want to store it, use it all up to bleed them more, to get all the bubbles out as much as possible. just make sure you refill your reservoir after about three bleeds. Remember fluid is cheep, but your brakes may save your life!
make sure your helper and you communicate or you will end up starting all over again. Have him pump it up and hold it with good pressure. Let him know that when you open the bleeder valve that his foot will go all the way to the floor and tell him to hold it there, until you close the bleeder valve. Tell him to pump it up again and hold it, after you close the valve. Repeat this as many times as necessary until there is absolutely no more bubbles for 3-more bleeds. If your fluid is dirty...bleed it all out until clear! I attach a clear surgical hose to the valve and run it in a bottle. The bottle will also tell you how much fluid has been drained from the reservoir, and when to refill your reservoir. I also leave the box end wrench on the valve until I'm done...makes it easier. You only need to open it about a quarter turn! When you're all done, you should have lots more peddle! Whenever you bleed...bleed them all to make sure all bubbles are gone an your fluid is clean. Hint...Whenever you refill the reservoir, make sure the rubber diaphragm is on evenly and your cap is back on tight, or you will be starting all over again and bleeding the whole system to get the air out that you let into the reservoir!
Another hint: Make sure you don't get any fluid on your paint our it will leave a permanent mark where it ate the paint. Be very careful when you are refilling your reservoir, not to spill it! Keep an old towel handy to wipe up any fast, that might spill.
[This message has been edited by hypo327 (edited 01-04-2013).]
Tekwiz
Report this Post01-04-2013 07:05 PM Click Here to See the Profile for TekwizSend a Private Message to TekwizEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any time a connection is opened in a brake system, the system must then be bled, no exceptions.
By far the easiest way to bleed brakes is with a vacuum brake bleeder. These run on compressed air & suck the fluid out through the bleeder fittings, so only one person is required. Just make sure to check & fill the master cylinder often when using a vacuum bleeder...they can empty it fast.
Many auto parts stores lend or rent specialty tools like this, if you have a source of compressed air.
thesameguy
Report this Post01-04-2013 07:12 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can also use the Motive Power Bleeder -
http://www.motiveproducts.com/
Make it a one-man job and pretty painless. The master cylinder on old GM cars is kind of a hassle with this unit because it's tough to get a seal on the master cylinder cover. I could never get it to work right with my T/A, even using the expensive metal (instead of plastic) adapter. I read somewhere that instead of using their silly chains to hold the thing on, use a massive c-clamp. I tried that method on my Falcon and it worked *perfectly* - and I had to use it multiple times as I was redoing all the brake lines and found a couple leaks. Never had any issues. As soon as my new calipers come in, I'll try it on the Fiero too.
Edit: I must have read the bit about the c-clamp on their own site -
We got the following tip from users that work on their classic Corvettes. We like the tip so much we're
passing it on to you. Instead of using the chains cut a piece of 2x4 or some metal bar stock in the same length as the
1105 adapter. Lay the 2x4 or bar stock onto the top of the adapter lengthwise and then use a c-clamp to hold the
adpater in place. It works great and is much faster to use than the chains. In 2011 we started to make the 1105 out of
cast aluminum. On the newer 1105 you will not need to use a 2x4 or bar stock, just use a c-clamp.
[This message has been edited by thesameguy (edited 01-04-2013).]
thesameguy
Report this Post01-12-2013 10:13 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thought I would follow up on this...
I hooked up my Motive to the Fiero today, and pretty much just made a mess. I have a Blazer master cylinder, and the Motive "American" adapter was just not quite big enough to fit over the reservoir. After a few seconds, the seal failed and blew ATE Super Blue all over the place. DOH.
There is a 3rd party that sells an aluminum adapter I used to use with my Trans Am, and it worked great on the bigger master cylinder. If you have the original MC, you won't need it. If you don't, you will.
I can't remember where I got that thing, but I'll dig it up and post a link.
The clutch master cylinder reservoir uses the same threads as most European cars, so that was easy.
Aside from the mess I made, the Motive bleeder worked perfectly. Bleed all four corners and the clutch in less than an hour.
ElTee
Report this Post01-12-2013 11:26 PM Click Here to See the Profile for ElTeeSend a Private Message to ElTeeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've tried a few different methods to bleeding the system, and found that gravity bleeding by far worked the best. Wish I could get the $70 back for the Craftsman brake bleeder I bought. Good Luck!
jetman
Total ratings: 272
Report this Post01-13-2013 01:24 PM Click Here to See the Profile for jetmanClick Here to visit jetman's HomePageSend a Private Message to jetmanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I love the one man speed bleeder screws, absolutely love them, hope the person who invented them is living a life of luxury.
That little tidbit is worth it's weight in gold for the uninformed.
eunospeed
Report this Post05-23-2013 09:23 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guys, sick of a soft pedal after gravity, vacuum and pedal bleeding the brakes on my Formula. So I'm looking at a pressure bleed next. I saw this Motive kit and I believe it will work on our cars. Take a look at it and give your thoughts......
http://www.speedwaymotors.c...Cylinders,33861.html
eunospeed
Report this Post05-23-2013 09:28 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
eunospeed
Member since Sep 2002
http://motiveproducts.3dcar...l-Adapter_p_130.html
Just read thesameguy's input above and it looks like the 1105 adapter is improved. Thoughts?
eunospeed
Report this Post05-28-2013 09:44 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just ordered it........ Results will be posted.
hobbywrench
Report this Post05-29-2013 01:23 PM Click Here to See the Profile for hobbywrenchSend a Private Message to hobbywrenchEdit/Delete MessageReply w/QuoteDirect Link to This Post
I use an H-Frt vacuum can . One port requires air pressure ( 20 psi in), the other port produces vacuum . Hook the vacuum port to a plastic brake bottle. The brake bottle has two spouts. One to the bleed nipple, the other to the vacuum input. When the plastic bottle fills 3/4, dump it. I run about 2 small bottles of brake fluid thru. You need an air compressor and a regulator turned down to around 20 psi. Kinda noisy and not the fastest. Rock hard pedal. One man operation. Brake pedal is not touched.
[This message has been edited by hobbywrench (edited 05-29-2013).]
crashyoung
Report this Post05-29-2013 11:00 PM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I bleed my brakes or clutch, I remove the bleeder screw, coat it with copper anti-seze, and reinstall it.
The anti-seze keeps it clean so I can remove it next time, and seals the threads from leaking air.
I slip a clear tube over the nipple of the bleeder screw and put the other end of the tube in a jar to the bottom of the jar.
As I bleed the brakes, the air goes out the tube, but when you release the pedal, only fluid gets sucked back in.
I also keep a close watch on the reservoir, as it has to stay full.
After bleeding, I tighten the bleeder with an open end wrench, take off the tube and torque the bleeder with a six point socket.
If I am flushing the system, you can watch the fluid as it leaves, and you might get a glimpse of water that gets trapped in the system.
I also save the old fluid, it makes a great penetrating oil.
thesameguy
Report this Post05-29-2013 11:23 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Assuming the 1105 covers the stock master cylinder reservoir (which I think it will, but you'll need to measure as I don't have one) it'll be fine. Otherwise, you need the 1115. *Seriously* go buy a big c-clamp and 6" of square tube stock from wherever and use that to cinch it to the reservoir. The chains and hooks they provide are worthless. A c-clamp without the tube stock won't seal properly. Sucks to spend an extra $10 to make this work, but it simply won't work right without the extra parts IME. I have bled *dozens* of cars using my Motive bleeder. In fact, I'm on my second pump as the one I bought in 2001 died in '08 or '09. I use the crap out of my Motive!
Remember that you only need 5-10psi in the can to bleed brakes. More than that and you can blow out seals. I usually start at 8psi and pump it back up at 4-5psi. Brakes on the Fiero are still great.
Report this Post05-30-2013 01:55 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If air got in the MC because tank went dry then you can bleed them until hell freezes and never get air out.
Can try to jack up rear of car til MC is level then bleed as normal. Sometimes works...
Often need to Bench Bleed the MC, reinstall MC, then bleed as normal.
This assumes you didn't "pedal bleed" the system and killed the MC... If you did that then you need a new MC.
See my Cave, Brake Service and Bleeding MC notes
Edit:
Low pedal or soft/spongy pedal... Terms are confusing but not interchangeable.
Bleeding can fix soft/spongy pedal.
Low pedal is normal brakes but need more pedal travel. Low pedal is often cause by too much pad clearance, often Fiero rear pad w/ caliper piston problems. Rebuilt caliper often use Rebuild Pistons. Rear piston was design as one shot use then junk them when bad.
[This message has been edited by theogre (edited 11-02-2015).]
eunospeed
Report this Post06-04-2013 09:33 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got tired of working on it and took her to a brake shop. They say its the new rear drivers caliper which I replaced because of a leak. Tech said there's a gap between the piston and the pad and closing the gap causes the peddle to be spongy. In other words, i have to push the peddle pretty far to close the gap enough for the caliper to have effect. Says its the parking brake mech causing the piston to not work properly. You guys have given great advice, any experience with this issue? Is this why guys go with front calipers on the rear?
eunospeed
Report this Post06-04-2013 09:38 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
eunospeed
I guess I should have read theogre's "edit" portion closer........ Sounds like my issue. Any fix?
eunospeed
Report this Post06-04-2013 10:09 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
eunospeed
eunospeed
Report this Post06-05-2013 03:26 PM Click Here to See the Profile for eunospeedSend a Private Message to eunospeedEdit/Delete MessageReply w/QuoteDirect Link to This Post
FIXED!!!!! Got to give a shout-out to my friends at Ashley's Tire and Brake in Lexington KY. I now have a great peddle, stops like a charm. They say to use the parking brake every time I park her and keep my fingers crossed that the problem doesn't come back. Good for now!
Lambo nut
Total ratings: 257
Report this Post06-05-2013 04:32 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you replace the calipers one at a time and let them gravity bleed when installing, no more bleeding will be needed after the install is complete. That might have been the "No" answer. I do it all the time. Even replace hoses and not done more then let the fluid run through, replace on the caliper, let the fluid run out, tighten bleed screw, done. Just don't let the master cylinder suck air.
And I have never had to bleed the brakes on an occasional basis. Not sure where that info comes from.
And yes, proper Fiero order is, LR, RR, RF, LF.
Kevin
mrstan
Report this Post11-01-2015 10:55 PM Click Here to See the Profile for mrstanSend a Private Message to mrstanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone tried the pressure bleeding method of pushing the fluid back up into the master cylinder? I just read an article on this and they say it is great as long as the car does not have an ABS system.
It makes sense to me in that it is pushing the fluid uphill and dragging the air with it to the master cylinder as well. This is done at each wheel it seems and works backward from the gravity method.. Here is ad on ebay that I caught my attention:
http://www.ebay.com/itm/One...-3500-/281836349094. I am not sure of the size of the brake bleeder though..
Any thoughts?
Report this Post11-02-2015 01:29 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any thoughts?
Bad idea for non-ABS too.
All the crap in the lines and calipers goes thru combi valve and MC bore.
Air trap in the MC is a big problem.
MC bore will act as a wide river or lake and allow the dirt etc to sink to bottom. GM Quick Take-up MC used in Fiero won't like this either. QT valve has very small parts.
Combi valve has small holes to plug and part to stick.
If you have a caliper stick because is full of dirt is relatively easy to clean out then get a new seal kit. (Let's ignoring rear piston problems for Fiero and some others for this.)
I've been using Gravity bleeding for decades... A bit slow but never have problems.
Larryinkc
Report this Post11-02-2015 08:18 AM Click Here to See the Profile for LarryinkcSend a Private Message to LarryinkcEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just changed all the calipers on my 88. I used a hand pump vacuum bleeder with standard bleeder screws to get most of the air out of the calipers and lines. I installed a speed bleeder in each caliper after the vacuum bleed.
After all the calipers had speed bleeders I bled each caliper again with the speed bleeder until all the air was out. Very easy to do and brakes are great.
My vacuum bleeder looks like this set.
http://www.ebay.com/itm/Bra...231738874924&vxp=mtr
[This message has been edited by Larryinkc (edited 11-02-2015).]
Report this Post11-02-2015 06:49 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe that pressure bleeding works great BUT if you use a pressure bleeder (with the tank reservoir) getting a seal on the plastic MC tank with the flat plate (with the rubber surface) provided is very hard to achieve. That plate works great on MC's with metal tanks but not the Fiero plastic tank.
The Mightyvac suction bleeder seems to work the best but you must use heavy grease on the bleeder screws to insure that air doesn't get past them. Like Theocre said never let the tank go dry and use fresh fluid.
creaky78
Report this Post12-01-2019 07:29 AM Click Here to See the Profile for creaky78Send a Private Message to creaky78Edit/Delete MessageReply w/QuoteDirect Link to This Post
Agree!! I've bled a lot of brake systems, this method works best, just requires a little patience.
Report this Post12-01-2019 08:40 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had good luck with the Russell speed bleeders. They are basically one way check valve bleeder screws. Just install them back them out 1/2 turn to open them, pump the brake 4 or 5 times then tighten them closed.
OldGuyinaGT
Report this Post12-01-2019 11:24 PM Click Here to See the Profile for OldGuyinaGTSend a Private Message to OldGuyinaGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was always taught on other cars that the sequence was RR, LR, RF, LF, because the farthest caliper or cylinder (presumably because the longest line should be bled first). I know the longest line on the Fiero is to the LR. But the '88 FSM lists the usual RR, LR, RF, LF. Got me to thinking (uh-oh!) I can see where you would want to bleed the rears and then the fronts, but does it really matter which rear (or which front) you do first? Presumably you're purging all air from each line anyway. I used the usual sequence and everything seems just fine.
hunter29
Report this Post05-06-2021 08:50 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looking for comments on the above post..
hunter29
Report this Post05-06-2021 09:07 PM Click Here to See the Profile for hunter29Send a Private Message to hunter29Edit/Delete MessageReply w/QuoteDirect Link to This Post
hunter29
Member since Feb 2020
Yes, everyone says LR RR but my 86 FSM says RR LR as well, so is the book wrong?
Skybax
Total ratings: 78
Report this Post05-06-2021 09:53 PM Click Here to See the Profile for SkybaxSend a Private Message to SkybaxEdit/Delete MessageReply w/QuoteDirect Link to This Post
My money is on the book being wrong, wouldn't be the first time (see 86-87 GT & 88 GT rear wheels being 30mm offset and not 35mm as the book states).
Yes most cars the RR is the furthest from MC, but the Fiero LR being farthest away from MC, but I think you're splitting hairs.
PS: What I find is the #1 thing never mentioned in brake bleed threads, especially when it comes to older cars, is you should tape a hockey puck or something similar to the floor below the brake pedal, so that when you are bleeding the pedal doesn't go all the way to the floor, because that cylinder the in MC bore and its seals are used to traveling a certain distance in the bore for many years, and if you max it out while bleeding you can run the seals into murky area where the seals don't normally travel, and while this adds a little more time to your bleed procedure it can prevent ruining a MC.
Report this Post05-06-2021 09:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by hunter29:
...so is the book wrong?
Do you believe everything you read?
It's already been explained in this thread why "the book" is wrong.
