  need help. parts/ mods/ general + build tread with pics (Page 1)
need help. parts/ mods/ general + build tread with pics by concorde01
Started on: 08-06-2014 04:44 PM
Replies: 46 (834 views)
Last post by: concorde01 on 08-15-2014 06:27 PM
concorde01
Report this Post08-06-2014 04:44 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
so i picked up my 85 2m4 for 150 yesterday. 4cyl. 4spd. garbage interior. the main harness plug is melted and am replacing it. here is a list of things i need help with.
1. the driver seat is shot. foam and all. i want to redo them myself with a good dark black cloth. i also want to keep the speakers in the head rest. but with new ones of course. does anyone sell a kit with foam and cloths so i can do it myself? locale shops are all telling me 800+!!!!!!!!!!! not on a $150 car.
1b...Found a set of seats!
2. i am wanting more power. i thought of a 3.4 swap. but found an old tread about using a mercruiser marine 3.0 140hp marine motor as is same motor block and will bolt in. then found out that the mercruiser marine 3.7 is the same motor but with v8 pistons and made from aluminum. ranging from 170-195 hp. i like the idea because marine motors are made to stay at hi rpm like 4k for long periods of time. if i did that i would find a edelbrock 2.5 intake and header and use a tbi on it. so has anyone done this type of motor in there car?
2b...I will be doing a 3.4 swap
3. i need a set of fi-air-o scoops so i can do a custom dual intake. i am not paying 400+ for a set.
4. i want to instal custom led tail lights and am looking for a flat panal to replace the tail lights. one piece panel. is is not a fast back.
5. i want a nicer rear bumper. any ideas for a easy swap?
PLEASE IF YOU REPLY TO THIS THREAD START YOUR REPLY WITH THE NUMBER OF THE QUESTION YOU ARE ANSWERING. pleasepleaseplease! thank you. and if anyone else has question or advice just ask. this will be my build and idea thread for this entire car! but pics and post about mod ideas are welcome and wanted. ty and pics will be posted of every step of work i do
[This message has been edited by concorde01 (edited 08-12-2014).]
concorde01
Report this Post08-06-2014 05:03 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok how do i post pics?
fastblack
Total ratings: 50
Report this Post08-06-2014 06:59 PM Click Here to See the Profile for fastblackSend a Private Message to fastblackEdit/Delete MessageReply w/QuoteDirect Link to This Post
PIP
concorde01
Report this Post08-06-2014 07:09 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
[img][/img]
concorde01
Report this Post08-06-2014 07:14 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
Member since Jul 2014
concorde01
Report this Post08-06-2014 07:15 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
concorde01
Report this Post08-06-2014 07:16 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
concorde01
Report this Post08-06-2014 07:19 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
these are the scoops i need. they can be damaged. if you have a set please pm me.
concorde01
Report this Post08-06-2014 11:03 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
and i am looking for this front end. used
concorde01
Report this Post08-07-2014 11:00 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
i am looking for a pisa zr2 dash if anyone has one.
concorde01
Report this Post08-07-2014 09:39 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
anyone?
concorde01
Report this Post08-07-2014 09:54 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
i need a diagram for this plug as mine is melted. i am just trying to get it running and dont know what HAS TO BE HOOKED UP to do it. also i think work was done to the car. it has a 4cyl. the back says 2m4 on the deck lid but says se on the sides. also the wires on the 2 halves of the plug do not match each other the car is a 85
concorde01
Report this Post08-07-2014 10:01 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
also badle need a vacume and egr diagram aswell as info on what can be removed and still run. this car is cobled together so anything helps
concorde01
Report this Post08-07-2014 10:22 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
ok vin decoder says it is a
1984 Pontiac Fiero 2dr Coupe SE Sport 4-Spd
concorde01
Report this Post08-08-2014 10:26 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
also i intend to use one fi-air-o scoop to feed air to the motor and the other to force air threw the engine bay. my car has the solid pieces on the sides
Report this Post08-08-2014 11:37 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thinking a different factory Fiero rear bumper would be easiest.
That front end is made by Norms fiberglass.
[This message has been edited by 2.5 (edited 08-08-2014).]
concorde01
Report this Post08-08-2014 12:05 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
and it lookd to be pricy si imma wait. i an\m trying to get a zr2 dash first. what bumper is that
KurtAKX
Total ratings: 128
Report this Post08-08-2014 12:24 PM Click Here to See the Profile for KurtAKXSend a Private Message to KurtAKXEdit/Delete MessageReply w/QuoteDirect Link to This Post
2.
It does not bolt in, the block is nowhere near the same. The bellhousing face of the 3.0 Mercruiser is the same as the small block Chevy.
You're even farther off the mark now. The 3.7 is a Ford-based design.
Even if you get past the obvious logistical hurdles of the different bellhousing and not having a place for the OEM front engine mount to bolt on, you won't be putting a 2.5 intake or exhaust on it- the marine 3.0 is not a cross-flow cylinder head design and none of those parts fit.
Report this Post08-08-2014 12:49 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
The items you are on the lookout for I would also check in the mall and put up a wanted thread there too.
https://www.fiero.nl/cgi-bin...ysPrune=2&LastLogin=
concorde01
Report this Post08-08-2014 01:10 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
damn. bad info then owell ill just do a 3.4 swap
TopNotch
Total ratings: 60
Report this Post08-08-2014 02:58 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
Mr. Mikes
concorde01
Report this Post08-08-2014 03:00 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok ty I will look there.
Neils88
Total ratings: 56
Report this Post08-08-2014 07:33 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Mr Mikes seats are very high quality and you're guaranteed to be happy with them...but you will pay quite a bit for them. Given the other (expensive) mods you are talking about, I think it is the best option for you since you seem to be doing a full upgrade. No point skimping on interior appearance.
If you really want to save money on the seats, you could try the junkyards or pick n pulls....maybe you'll get lucky.
concorde01
Report this Post08-08-2014 08:50 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
the [assenger seat is nice so i may just replace the driver. is there a way to make them black? also i hooked the wiring back up but no power still. is it possible to run a toggle switch to battery then the fuel pump. antoher to the coil and a push button for starting? if im right the tbi delivers fuel bashed on the amount of trottle and vacume? i wont have lights or anything but i just want to see how it runs so i can decide if its even worth the work
concorde01
Report this Post08-09-2014 09:22 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok so i looked at my car today...my battery junction box has nothing going to it. what goes to it besides the second wire from the battery
concorde01
Report this Post08-09-2014 09:29 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
i will be pulling all wiring from the back of a 85 2m4. is it the same as my 84?
Report this Post08-10-2014 12:11 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No
concorde01
Report this Post08-10-2014 12:19 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok what needs to be done so it works
TONY_C
Report this Post08-10-2014 09:08 AM Click Here to See the Profile for TONY_CSend a Private Message to TONY_CEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to get an 84 factory service manual and find a rear harness from an 84. the wiring for 84s are unique and the other years don't interchange. The location of the C500 connector is also unique to the 84, the other years have it close to the battery.
[This message has been edited by TONY_C (edited 08-10-2014).]
concorde01
Report this Post08-10-2014 09:23 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have access to a 84 just an identical 85 what are the options
Report this Post08-10-2014 09:30 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would ditch the 84 and find a later year......
concorde01
Report this Post08-10-2014 09:41 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
That takes money. Something I don't have
concorde01
Report this Post08-10-2014 11:18 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
Why not just upgrade to the 85 wiring and computer
concorde01
Report this Post08-10-2014 11:50 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
And I am not giving up on a $150 car
concorde01
Report this Post08-10-2014 10:53 PM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
concorde01
Ok I got it running. Won't start with key so did temp push button. Tax says max at idle. Door hood and deck open light work but that's it. Headlights work but no tail or blinkers
concorde01
Report this Post08-12-2014 01:10 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
so i picked up my 84 2m4 for 150 yesterday. 4cyl. 4spd. garbage interior. the main harness plug is melted and am replacing it. here is a list of things i need help with.
fierosound
Total ratings: 286
Report this Post08-12-2014 09:07 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tail lights https://www.fiero.nl/forum/Forum1/HTML/091686.html
[This message has been edited by fierosound (edited 08-12-2014).]
jmbishop
Total ratings: 169
Report this Post08-12-2014 09:21 PM Click Here to See the Profile for jmbishopSend a Private Message to jmbishopEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are way too far ahead of yourself.
Step one: Repair the car as is and work out the bugs, if you can do this then your ready to move on. We are here to help.
Step two: Check and make sure you have step one done, if not pretend step two doesn't exist and don't try to go on to three.
Step three: Watch the mall, ebay and craigslist and post WTB adds with what your willing to pay, don't expect us to find it for you.
[This message has been edited by jmbishop (edited 08-12-2014).]
concorde01
Report this Post08-13-2014 09:13 AM Click Here to See the Profile for concorde01Send a Private Message to concorde01Edit/Delete MessageReply w/QuoteDirect Link to This Post
all i want to fix on the car is the lights. the motor and tranny wil be sold. next month i will be picking up my new 3.4. and preping it for the swap. btw amazing tail lights. i would love a panel that uses corvette taillights. then i could get led lights i say the led lights made for the cr but i like the corvette syyle lights but i cant find anyone that makes one for the notchback
85 SE VIN 9
Report this Post08-14-2014 07:47 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
1. Summit Racing has seats and brackets. They're not Fiero and don't have speakers, but they look like decent replacements. Speakers can be found at TFS and on ebay, Mr. Mike's web site explains how to replace or retrofit them.
2. 3800 SC. Phondawgz wiring harness.
4. There is a long saga of a thread about a guy who designed a nice panel for the Vette lights, then died. People have tried and tried to get someone to use his molds, etc., but calls are not returned and so on.
[This message has been edited by 85 SE VIN 9 (edited 08-14-2014).]
