   New member wants to instal a v8 (Page 1)
New member wants to instal a v8 by Roger Walling
Started on: 05-02-2020 01:52 PM
Replies: 49 (1247 views)
Last post by: jscott1 on 05-26-2020 09:11 PM
Roger Walling
Report this Post05-02-2020 01:52 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hellow, I have just joined your forum after looking at many of your posts trying to get my 4 cyl. running.
I finally got it running and as they are known to do, it caught fire.
Not much damage though as I had my fire ext. ready.
However that was the last straw, I now want to install a low HP SB crate motor in it.
This is a pic. It is a street machine and lots of fun driving.
I am looking for some clear pic's of an engine installed in an 84.
Thank you.
AND a big thankyou to every one that had posted on diagnosing a unrunning engine that has helped me get mine running.
I don't think my pic went through, I will try later.
Easy8
Report this Post05-02-2020 02:23 PM Click Here to See the Profile for Easy8Send a Private Message to Easy8Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the fun of fieros. Glad you got yours running, sad to hear it caught fire. As far as putting a low HP small block crate motor goes I would tell you this. Forget a crate motor and put a caddy 4.9 in it. The swap is the easiest to do. You get plenty of low end torque with the V8 sounds with out all the extra pieces and work of any other swap. Search here and you will see lots of info on how easy the swap is.
Report this Post05-02-2020 02:41 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I second the 4.9.
Gobs of torque, no adapter plate, lightweight aluminum block, no need to hack the spaceframe as with the iron SBC.
Roger Walling
Report this Post05-02-2020 05:25 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you for the quick response.
I did a little quick reading and someone said that I do not need an ECM, is that true?
(or do I use mine )
Thunderstruck GT
Total ratings: 99
Report this Post05-02-2020 05:32 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
4.9 NoStar probably the worst engine GM ever made next to the HT4100. Go with an LS or SBC, you'll only do it once and it will be bulletproof. Do a Google search on Caddy engines. > https://itstillruns.com/cad...roblems-6637955.html
Cadillac Northstar Engine Problems
•Oiling Issues. Far and away, most of the Northstar's issues have to do with oiling. …
•Oil Consumption. It's not unusual for pre-2000 engines to go through as much as a quart of oil every 500 miles. …
•Carbon in the Cylinders. …
•Blown Head Gaskets.
They left out Warped heads, cracked heads, head bolts pull out of the block, and the 3 piece block with NO GASKETS that always leaks.
Report this Post05-02-2020 05:33 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I add my name to the 4.5L/4.9L V8 swap club. Best performance at the lightest weight, and lowest cost per dollar, while still getting 27-29 hwy MPG. . Even if you purchase a ready made plug and play harness, you should be able to complete this swap, engine and all, for under $2,000. Locating a V6 cradle will simplify things.
Roger Walling
Report this Post05-02-2020 05:34 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought the North Star was a later engine?
Report this Post05-02-2020 05:43 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was...
the 4.9 is a pushrod engine, the Northstar is 4.6L and quad valve and dohc. Completely different engines.
Since you are not looking for a rocket ship, the 4.9 is definitely easier and cheaper than the SBC, but the SBC, Northstar, and LS4 have a lot more performance potential. The 4.9 also isn't an easy engine to make look clean and clutter free, which may or may not be of interest to you.
All gauges, cruise, AC and Fuel pump will work without any ECM... that is once of the nice things about the Fiero. They are very basic from an electrical perspective and easy to swap whatever you want into.
[This message has been edited by fieroguru (edited 05-02-2020).]
Roger Walling
Report this Post05-02-2020 05:59 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was...
Does that mean that I leave in my ECM or remove it?
Report this Post05-02-2020 07:24 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stock fiero ECM is normally removed when non-stock engines are swapped in. If the new engine is fuel injected, then the ecm to run the new engine is installed.
sourmash
Total ratings: 50
Report this Post05-02-2020 07:36 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another vote for the 4.9 or 4.5 engine. It's said to be one of the easiest swaps. Mine loves the interstate, gets good mileage and still has a bunch of torque down low for red lights. Having a V8 in a Fiero is an oddity to most people you meet.
Raymac85
Report this Post05-02-2020 11:02 PM Click Here to See the Profile for Raymac85Send a Private Message to Raymac85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Go with the 4.5/4.9 it is a awesome engine. I have a 4.5l in my 86GT that was built by johns 4.9 performance. Gobs of power and very fun. Super easy install.
85 SE v6
86 GT 4.5l v8
Raymac85
Report this Post05-02-2020 11:03 PM Click Here to See the Profile for Raymac85Send a Private Message to Raymac85Edit/Delete MessageReply w/QuoteDirect Link to This Post
Raymac85
Member since Apr 2016
85 SE v6
86 GT 4.5l v8
cvxjet
Report this Post05-03-2020 12:34 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just out of curiosity, what is the weight difference between the 2.8 and the Cad 4.9? Do you gain much weight?
sourmash
Total ratings: 50
Report this Post05-03-2020 08:16 AM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is from John's 4.9 site":
"The overall weight of the Cadillac 4.9 engine is 360 lbs.* A Chevy 2.8 V-6 engine weighs in at 350 lbs and a small block Chevy V-8 is about 550lbs.* With its square bore and stroke ratio, the 4.9 port fuel injected engine delivers 200hp and 275 ft/lbs of torque."
The footnote links to this site below:
*www.gomog.com/allmorgan/engineweights.html
Roger Walling
Report this Post05-03-2020 08:35 AM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
So when I buy the engine from a salvage yard, I have to get the ecm and cut out part of the wiring harness in order to connect it up?
Thank you fieroguru.
Roger
Report this Post05-03-2020 08:56 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, the ECU from the donor engine needs to be used. It will fit in the stock Fiero location.
Roger Walling
Report this Post05-03-2020 10:54 AM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can you just plug it into the Fiero connections?
Report this Post05-03-2020 11:33 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you buy a custom harness specifically designed to install engine A into a Fiero, then the answer is yes. Install the custom harness on the engine, put engine into Fiero, connect the Fiero 203, 500, battery, and ground connections and you will have an engine swap that will run electrically (still need to address mounts, fuel, cooling, exhaust, etc.).
If you want to go the DIY route, to connect any engine to the Fiero, there are 3 primary connection points.
ECM connections (most are different for each engine type, but these will come with the factory harness for whatever engine you are going to install).
Fiero 203 connector (this is in the center conlsole area by the ecm) is the wiring source for Injector power, fuel pump, check engine light, oil pressure gauge, Speedo, AC and torque converter lockup).
Fiero 500 connector (on the front engine firewall on the 84, by the passenger strut tower on the 85-87) is the wiring source for starter, ignition, alternator gauge, temp gauge, cooling fan, reverse lights.
At the bare minimum, the new engine and its donor harness will need to connect to the Fiero 203 and 500 connectors, but most other non-fiero engines do not use those specific connectors. The needed wires exist in the donor engine harness for all the systems and sensors that need connected to the 203 and 500 connectors, but you will need to isolate those wires in the donor harness and terminate then at the proper pin locations in the Fiero 203 and 500 connection points. It isn't difficult work, but it does require the ability to read wiring schematics, not be intimidated by a harness with 50 to 100+ wires, and have the skills and tools to make the proper electrical connections (twisted wire with tape won't work long).
There are many ways to do this. Strip the Fiero harness to just the 203 and 500 wires then splice them into the donor harness. Take the donor harness and repin its wires to fit the 203 and 500 connectors, a combination of the two, or a complete disassemble of both to reroute the wires where you want them to improve the overall appearance of the engine.
The time you take making everything neat, tidy, and clean looking will pay dividends every time you pop the decklid to show off your engine (and with a V8 in the back, people will stop you and ask to see it all the time!).
[This message has been edited by fieroguru (edited 05-03-2020).]
Roger Walling
Report this Post05-03-2020 08:21 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think the way that I will go is to buy the harness.
I would like to post a pic of my car, as it is not the most conventional car.
It is in fact, 4' longer and the passenger sits behind the driver in a compartment that is about 2' wide and the rear has been narrowed 8".
I tried to post the pic, but no luck so far.
I just posted a pic in the AACA web site (https://forums.aaca.org/ ) in the general discussion section with the heading below.
"84 Fiero now running.
By Roger Walling, Thursday at 06:52 PM"
Roger
[This message has been edited by Roger Walling (edited 05-03-2020).]
David Hambleton
Report this Post05-03-2020 09:14 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
For your viewing convenience:
[This message has been edited by David Hambleton (edited 05-03-2020).]
Total ratings: 461
Report this Post05-03-2020 09:43 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by David Hambleton:
For your viewing convenience...
Now that is different!
You need to be logged in to the site Here first... and then simply click the Upload Image button located immediately below the text posting box.
[This message has been edited by Patrick (edited 05-03-2020).]
Roger Walling
Report this Post05-04-2020 06:04 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dave, Thank you for posting my Pic's here. I was hoping someone would post them.
[This message has been edited by Roger Walling (edited 05-04-2020).]
David Hambleton
Report this Post05-04-2020 07:43 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by Roger Walling: Dave, Thank you for posting my Pic's here. I was hoping someone would post them.
You're welcome. I used the Pennocks Image Poster (icon at the bottom center below) to load the pics as-is from the AACA site. No resizing was needed.
Rickady88GT
Total ratings: 200
Report this Post05-04-2020 11:21 PM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the best 4.9 build thread?
I have done a 4.9 swap but I did not take a lot of pictures or do a lot of notes.
Total ratings: 461
Report this Post05-04-2020 11:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used the Pennocks Image Poster (icon at the bottom center below) to load the pics... No resizing was needed.
Dave, as much as I promoted the use of PIP here over the years, the new Upload Image feature that Cliff has implemented is way better. It allows uploading of mega-pixel images and automatically re-sizes them. PIP can be put out to pasture now.
Roger Walling
Report this Post05-05-2020 09:43 AM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Testing the "upload Image" "button"
Patrick, Thanks for the info.
Roger
Opp's, I must have done something wrong, back to school on this one.
I finally got it right
Thanks!
[This message has been edited by Roger Walling (edited 05-06-2020).]
Total ratings: 461
Report this Post05-05-2020 01:41 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
[img
]https://images.fiero.nl/userimages/Roger%2520Walling/DSCN0363.JPG[/img]
Roger, edit your post and get rid of the gap in the image link!
I don't know how you managed to get that gap there in the first place, but it's very easily rectified.
[This message has been edited by Patrick (edited 05-05-2020).]
Roger Walling
Report this Post05-05-2020 03:48 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think that I did what you suggested but no go.
Total ratings: 461
Report this Post05-05-2020 10:14 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You removed the gap... but you also removed a bracket (after the first img).
liv4God
Report this Post05-06-2020 03:14 AM Click Here to See the Profile for liv4GodSend a Private Message to liv4GodEdit/Delete MessageReply w/QuoteDirect Link to This Post
Everyone is providing excellent advice on the matter. I just want to add in, price and amount of work wise, the sbc requires a bit of dough if you buy all the swap parts, or a bit of work if you do all the fabricating yourself. And by a bit, I mean a lot. It's an excellent choice and totally worth the work/money if you want a high power build because there is so much aftermarket support, mods etc to build up to pretty much any power level you want (and it can be done without hacking the frame). But like pretty much everyone else mentioned, if you want a low power v8 (still more power than the Fiero 4cyl or v6 of course) the Cadillac 4.9 is a better value.
TXGOOD
Total ratings: 87
Report this Post05-06-2020 01:29 PM Click Here to See the Profile for TXGOODClick Here to visit TXGOOD's HomePageSend a Private Message to TXGOODEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone has a new V8 Archie kit that they are selling on Facebook for what seems like a pretty good price.
Look a few posts down here.: https://www.facebook.com/groups/FieroFleaMarket/
Report this Post05-06-2020 07:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't call 275 ft lbs of 4.9L torque low power. Its a 63% increase in torque over what the 2.8L has at about the same weight. I believe that with the improved full flow exhaust systems that many of us have you may be pushing 280 or 285ft lbs at the flywheel. It won't be as fast at an LS2, 3 or 4 or a classic SBC but if you consider all factors; weight, cost, mileage, smooth cruising, high reliability and ease of swap, the 4.9L is a pretty good overall choice. If you want a higher revving engine that's very similar then try the 4.5L Allante engine. Before all is sad and done, decide, if you want to spend $10K on a swap or less than $2k?
sourmash
Total ratings: 50
Report this Post05-06-2020 07:44 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
A SBC in today's world seems like a waste of effort. For the expense you coulda had a better LS swap is what everyone would say.
Report this Post05-07-2020 08:36 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The weight penalty of a cast iron small block and the change in balance of the car are two big negatives for me.
The 4.9 makes 225 pounds at 1700 - that's a huge gain compared to the 2.8.
Instant throttle response.
Roger Walling
Report this Post05-07-2020 09:16 AM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
As I have my fuel tank in the rear luggage compartment, I an concerned with the heat from the rear exhaust manifold.
I have been told that ceramic coating the manifolds inside and out will reduce the heat transfer by 50%.
Is there insulation that I could line the rear compartment that would reduce the heat transfer even more?
I plan on installing air scoops in the side of the fuel compartment and maybe even a blower to vent the heat.
I have never seen what the exhaust system looks like in a V8 installation, where does one place the muffler and the tailpipes?
A pic or a diagram would be very helpful in order to avoid any mistakes on my part.
Thank you,
Roger.
fierosound
Total ratings: 286
Report this Post05-07-2020 10:36 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pics of a Caddy 4.9 install:
https://www.fiero.nl/forum/Forum1/HTML/091172.html
https://www.fiero.nl/forum/Forum2/HTML/129733.html
[This message has been edited by fierosound (edited 05-07-2020).]
Roger Walling
Report this Post05-07-2020 02:10 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, very helpful
Roger
Roger Walling
Report this Post05-10-2020 03:52 PM Click Here to See the Profile for Roger WallingSend a Private Message to Roger WallingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have noticed that at least one person had routed his exhaust to exit in front of the rear wheels.
Would this give more room for a larger (and quieter) ex system?
I don't think that I will need a cat. converter.
Rickady88GT
Total ratings: 200
Report this Post05-11-2020 07:23 AM Click Here to See the Profile for Rickady88GTSend a Private Message to Rickady88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4.9 that I did used a Fiero style exhaust system and was not loud. I also used two of the heat shields between the exhaust and trunk. I simply doubled them up (stacked them). In addition, I used some heat shielding mat material inside the trunk under the carpet. The trunk is safe from heat and is totally stock, no modifications to it's size or shape.
