  Installed new LED front parking/turn lights
Installed new LED front parking/turn lights by 1Packrat
Started on: 01-12-2016 02:02 AM
Replies: 3 (314 views)
Last post by: theogre on 01-12-2016 06:13 PM
1Packrat
Report this Post01-12-2016 02:02 AM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
They are about twice as bright as the original lights. The color is amber and contain 24 LEDs.
Report this Post01-12-2016 02:37 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does marker still blink right? If not, your not done.
See my Cave, LED Marker Light
1Packrat
Report this Post01-12-2016 03:25 PM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes they do. I had added the bridge rectifier when I installed the leds in the marker lights.
That story is found HERE
For the parking/turn it required a 50v 6watt load resistor to be installed.
Report this Post01-12-2016 06:13 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Resistors are not rated for volts and 6w is far too low. If is like most of them then should be 50W 6Ω wire wound in an Aluminum shell.
Aluminum power resistor are rated at X Watts with a heatsink. At minimum should mount them to the car's frame because each 6Ω resistor at 14VDC eats 2.3A (A=V/R) and dumps around 33 Watts. (W=V²/R)
