⚠️ Warning: If the IAC is out of TB/TBI and connected to wiring and turn On I-key then can wreck the motor. More so w/ A-B shorted to "close the valve" as other half isn't there.
Could try IAC links above... may not help.
Get a "noid light" for IAC. This light "replaces" the motor to see if ECM turns on/off/blinks the 2 lights.
If light does nothing then likely have a problem w/ ECM or wiring.
"low mile" 30+ year old car can have heat related and other problems w/ iffy ECM.
Solder joints can crank open.
Old GM OBD1 ECM can have a factory defect.
Either/both can happen when hot, cold or always killing part to whole ECM.
If ECM is "Dead" must save the PROM/MEMCAL inside to move to new ECM.
also See my Cave,
ECM Heat------------------
